  • *Users: 1
  • *Guests: 54
  • *Total: 55
Author Topic: 737-800 flight model  (Read 1281 times)
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« on: February 10, 2018, 10:08:18 AM »
Well I am on the hunt for a good, 737-800 aircraft for P3D v4.. PMDG does not fit this goal! Is there anything else out there that I can use with Project Magenta? I am using their flight model but the thing is made of butter the way it flies through the air. No drag at all and because of that it is almost imposable to control the speed on a descent. I usually end up doing a circle on my way into approach to get me slowed down. So... What is out there? I have not found much....
Offline RayS
    • Anthony Scott Photography
  • First Name: Ray Sotkiewicz
  • Home Location: Seattle, WA
Re: 737-800 flight model
« Reply #1 on: February 11, 2018, 01:21:13 AM »
PM doesn't have any plans to update their flight model? Seems like a rather significant oversight if their incredible software has to be combined with a flight model that is apparently useless....
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #2 on: February 11, 2018, 09:53:35 AM »
It is, to some extent, how the 738 behaves. Speed control has to be managed carefully even in VNAV with decel points.
The best way when you control via the MCP is to reduce the VS from about 1800 to about 500 feet/min 2-3 miles ahead of the decel point and the aircraft will slow down. Spoilers at flight detent can help also .
I used briefly the PM flightmodel before switching to SimA and P3d4 and found it very well balanced.  (just my 2cents Bob)
« Last Edit: February 13, 2018, 03:52:51 PM by jackpilot »
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #3 on: February 13, 2018, 06:19:20 AM »
Apparently a 737 Pilot told Bob yesterday..  You can Slow down, or you can descend.... But you can't do both LOL...
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #4 on: February 13, 2018, 08:02:26 AM »
I was thinking about this topic and it came to me that back years ago the biggest problem I saw was how the PM weights and balance would load into FSX (pre-Prepar3d). For some reason they would load wrong and really affect the characteristics throughout all phases of the flight, no matter what. If you think about it, a nose heavy plane is going to go down fast doing the descent; whereas tail heavy will cause oscillations since the trimming is trying to keep it level or in downward angle, but it just can't quite do it right.
Surely, some will say this is not the problem, but I tested many PM flight models during the beta phases back in those days, as well as even used TopCat, along with PFPX to manipulate the settings. And, what it always came back too was the weight and balance not setup right or transferring into the PM CDU correctly, then how FSX viewed it.
Therefore, I would always go into FSX weight and balance settings to make sure it matched what TopCat was telling the PM CDU to use...this always fixed the problem. Although, there are other things to look at, but I'd suggest for anyone having these problems to start with checking Prepar3d weight and balance settings. Also, if you're using TopCat or another program that injects these values, let me know if it comes over correctly and if it's correct when injected into PM CDU.
Offline crazydunc
  • Forum GURU
  • Aviation Enthusiast
    • Velocity Flight Training
  • First Name: Duncan
  • Home Location: Cheltenham
« Reply #5 on: February 13, 2018, 08:09:15 AM »
Bob,
As we discussed last night (repeating it here for the wider audiences), A couple of our WorldFlight Team are 737NG Pilots for various airlines.
Their input was as Trev has quoted, "you can go down or slow down, but not both".
They all advocated the use of LVL CHG rather than VNAV when descending, to manage the Speed v ATC restrictions.
Dunc
Dunc
FDS 737NG
Offline FredK
  • I may as well be Staff!
  • 737NG Cockpit Builder
« Reply #6 on: February 13, 2018, 08:57:40 AM »
I just want to report that the SimAvionics 737 model in conjunction with the most recent SimA update works extremely well operating in VNAV for me.
VNAV descents have become almost too easy now.  Just monitor speed and apply spoilers as required and you will comfortably get to your target altitude.  All works very smoothly regarding aircraft attitude and performance.   Previously I relied more on using V/S for descents when VNAV seemed to get a bit confused.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #7 on: February 13, 2018, 09:24:23 AM »
I am currently testing the SimA flight model and I must say... What a difference! I can actually manage the speed in a decent. With the PM model I would slow the plane down to 220knts pull back the speed breaks to full and start down. Even in a 1700fpm decent, by 10000 I would be up around 290knts. Not this aircraft. Watch the banana and use the speed breaks and wow. Only thing I am experiencing on this aircraft is that it hand flies VERY differently. Not sure if I am just that used to the PM model or something is wrong. I do not remember Sam's sim flying like this. Left and right is the issue. I expect the plane to start returning to neutral as soon as I let pressure off the yoke but I do not expect it to snap back which this seems to do. This could be FSUIPC settings on my part. I will play with is some more....
Offline Trevor Hale
  • Administrator
« Reply #8 on: February 13, 2018, 11:54:41 AM »
Remember Sam is running ProSim Now and the ProSim model, so that may be the difference also.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #9 on: February 13, 2018, 11:58:33 AM »
I was talking more of the way it "feels" and yes the model is the difference. I want mine to "feel" more like his. It is adjustments I know that I will need to make.
Offline FredK
« Reply #10 on: February 13, 2018, 01:42:59 PM »
Bob -
Also remember that the SimAvionics model is specifically designed to work with the SimAvionics software suite which includes all the A/P tuning.  Otherwise there definitely will be anomalies.
  • First Name: John
  • Home Location: WI
« Reply #11 on: February 13, 2018, 01:46:34 PM »
Hey Bob,
Look at this link and do the 30 day free trial:
https://prosim-ar.com/free-prosim737-trial/
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
[Today at 03:07:35 AM]
unfinished project 737
by LORENZO
[April 23, 2019, 06:29:47 PM]
by _alioth_
[April 23, 2019, 05:48:41 PM]
Overhead: Where to mount interface cards?
by jackpilot
[April 23, 2019, 05:08:22 PM]
747-400 Yoke Color
by bernard S
[April 23, 2019, 04:39:55 PM]
737 MAX Sismo soluciones (SPAIN)
by kkoutoulas
[April 23, 2019, 02:53:50 PM]
TV Screen Position
by iwik
[April 22, 2019, 07:53:38 PM]
Question on B737NG center pedestal instrument availability
by navymustang
[April 22, 2019, 05:05:09 PM]
Wanted - Jetmax B737 TQ
by kattz
[April 22, 2019, 12:57:09 AM]
Multi-Projector color calibration
by jmlohrenz
[April 21, 2019, 05:33:40 PM]
Bernard...info
by FredK
[April 20, 2019, 06:29:17 PM]
by fsaviator
[April 20, 2019, 04:25:12 PM]
by blueskydriver
[April 20, 2019, 11:26:43 AM]
Old Projector(s)
by fsaviator
[April 20, 2019, 10:53:59 AM]
by Karl737
[April 19, 2019, 09:56:23 PM]
by patiju
[April 19, 2019, 06:14:33 PM]
by Steenos
[April 19, 2019, 03:22:12 PM]
by Joe Lavery
[April 19, 2019, 04:59:21 AM]
Teensy LC Throttle Quadrant
by RayS
[April 18, 2019, 03:38:14 PM]
by navymustang
[April 18, 2019, 08:25:11 AM]
by 757Simulator
[April 18, 2019, 04:20:53 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
Aerosoft Australia 747 MCP
by 737simAdelaide
[April 14, 2019, 05:16:58 AM]
CPFlight 737 EL MCP For Sale
by 737simAdelaide
[April 14, 2019, 05:12:54 AM]
