  • *Users: 2
  • *Guests: 51
  • *Total: 53
Author Topic: Joaquin's KBOS Scenery  (Read 1186 times)
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« on: February 22, 2018, 04:03:14 PM »
Joaquin,
Had a look at your Boston scenery today.  Now I must admit that my plan was to go and look at the scenery first then install your Scenery, then compare, however I was too excited and just installed your scenery.
In any case, I will tell you the following..  Its pretty awesome that you took on such a task.  I use to design aircraft for Abacus Software for flightsim, and I know that's not an easy task... Scenery is a different animal and you did an excellent job.
Good for you.
I Like your markings on the taxiways and gates..  Man attention to detail for sure.  Knowing the gate you are pulling into because it is marked on the tarmac is the best part of the scenery.
I have included my favorite view in the attachments.
And one attachment, I am not sure about.  The Delta building seems to be missing something. In cause you forgot about it I thought I would point it out.
I must admit I don;t fly into KBOS often, and I really have never seen pics so I don't know if things are what they are supposed to be, but I thought I would post and you could tell me if its right.
Anyway 150% Cudos to you, Great Job turning a crap Default Airport airport into something a lot more realistic.
I can't wait to see your future versions..
Offline ifeliciano
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Ivan
  • Home Location: Arlington, Texas
Re: Joaquin's KBOS Scenery
« Reply #1 on: February 22, 2018, 07:19:16 PM »
P3D or X-Plane?
Offline Trevor Hale
  • Administrator
« Reply #2 on: February 22, 2018, 08:41:18 PM »
Its Prepar3d..  One of our own members did it and you can download it from this thread!
http://www.cockpitbuilders.com/community/index.php?topic=6891.msg49722#msg49722
« Last Edit: February 22, 2018, 08:41:57 PM by Trevor Hale »
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #3 on: February 22, 2018, 11:15:09 PM »
Thanks Trevor y Joaquin!
« Last Edit: February 27, 2018, 02:07:13 AM by ifeliciano »
Offline Sam Llorca
  • Aviation Enthusiast/Private pilot
    • Flight experience simulation center
  • First Name: Samuel
  • Home Location: Sarasota, Florida. U.S.A.
« Reply #4 on: February 23, 2018, 06:01:19 AM »
That's awesome Joaquin!!!!
Thank you!
Cheers.
Offline jfuenmayor
  • Forum GURU
  • First Name: Joaquin
  • Home Location: Miami
« Reply #5 on: February 25, 2018, 08:46:48 PM »
Hi to all:
Thanks for all the kind comments. I was out of town for the weekend and just returned
this afternoon so I could not reply to you guys before.
Indeed it is a bit labor intensive but it was worth it. My son is working on
his Masters degree in Mechanical Engineering at Tufts and I visit there  quite frequently. During a long taxi to RWY 22L  I noticed how bad the stock airport was, not to mention that the taxiways were all wrong.
With regards to the Delta Building, I did not model it as I point it out on the README.txt file, mainly due to the fact that I do not yet have the software to include more realistic buildings, which is another another beast in itself.
I am posting my last revision which corrected a few omissions and a wrong a texture on the taxiway R sideline. It is now easier to do since the bulk of the work is already done.
I tried to compile it with the P3D v4.2 SDK but on the first try I was not successful due to some texture issues. In time, I will figure it out though, but I do not know if it will make any significant difference.
I am posting then last revision here.
Enjoy
Offline jfuenmayor
  • Forum GURU
« Reply #6 on: February 25, 2018, 08:50:10 PM »
And above I meant the "latest" not the last ;)
Offline Trevor Hale
  • Administrator
« Reply #7 on: February 26, 2018, 05:18:28 PM »
LOL,
I think I speak for many of us when I say thank you for your efforts..  I will install the revision.
Offline jfuenmayor
  • Forum GURU
« Reply #8 on: February 27, 2018, 11:41:36 PM »
Hi Trev and everyone:
I am releasing what I call version 1.0 hehe, I had
to add a copyright clause after some research. It is still
shareware but what I am trying to do with this, is to avoid
people out there to profit from this work. I have done it with
great pleasure to contribute to our great community.
I hope everyone understands this. If anyone notices anything that can
be improved, please let me know so I can address it in my spare time.
I have included some pictures of the scenery in the zip file.
Joaquin
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
[SOLVED]Re: Joaquin's KBOS Scenery
« Reply #9 on: February 28, 2018, 12:59:14 PM »
Joaquin thanks for the scenery. Looks great in the folder images. I do think i'm having a bit of an issue with it, though. The images you included are showing that most gates have a jetway. Mine is only showing 1 or 2 jetways per terminal. Are there any specific settings for Scenery Objects?
Your image:
My image:
Scenery Settings:
Edit: Scenery Complexity needs to be at Very Dense or higher to see multiple jetways.
« Last Edit: February 28, 2018, 01:23:59 PM by ifeliciano »
Offline jfuenmayor
  • Forum GURU
« Reply #10 on: February 28, 2018, 03:17:11 PM »
Hi:
It may be due to the graphics adapter setting in P3D. When adding jetways, its density may be selected from extremely dense, very dense and dense. The Graphics card may need some tweaking since the scenery is quite complex in ground polygons and may be resource intensive. I Compiled it with the jetways set to very dense since its movement is more fluid at the gate, the result may be that some jetways are not displayed in some systems. Try playing with your graphics settings to see what happens and let me know. Remember, most guys here have high end cards :). In any case, I may need to recompile with the jetways set to a lower density.
Joaquin
Offline jfuenmayor
  • Forum GURU
« Reply #11 on: March 02, 2018, 05:14:21 PM »
Just an update that corrects a major error in taxi sign of M and E intersection.
COUNTDOWN TO WF2019
777 Throttle *price reduced*
by mattking247
[December 14, 2018, 08:59:01 PM]
by RayS
[December 14, 2018, 07:28:46 PM]
by ScottThePilot
[December 14, 2018, 12:15:47 PM]
Recipe_for_a_cheap_joystick_encoder.pdf
by MattiasLind
[December 14, 2018, 07:53:57 AM]
Triple channel splitter with professional edge blender $3750.00
by Lee737
[December 13, 2018, 09:41:31 PM]
Santa Flight (Saturday December 15th)
by Trevor Hale
[December 13, 2018, 07:43:04 AM]
Join me on Vatsim Tonight
by Trevor Hale
[December 12, 2018, 05:50:50 PM]
My A320-like cockpit
by MCrevot
[December 12, 2018, 09:41:11 AM]
U.S. holiday booked!
by Trevor Hale
[December 11, 2018, 10:35:15 AM]
New supplier for your sim
by Fcoq
[December 11, 2018, 01:12:29 AM]
X-Plane 737-800 Build
by kenrosefire
[December 10, 2018, 08:55:16 PM]
[December 10, 2018, 04:49:22 PM]
Yoke and Rudder Centering with Dynamic Load Control / Force Feedbacl
by bernard S
[December 08, 2018, 12:14:01 PM]
anyone that can help me out get imperial size bolts??
by Gallie
[December 08, 2018, 11:03:29 AM]
OpenCockpits I/O Cards
by al23
[December 08, 2018, 09:22:52 AM]
Level D B767 For FS9
by Goodenough
[December 06, 2018, 08:19:20 PM]
Thickness of a resl 737-800 Glareshield / MCP Light panel
by Joe Lavery
[December 06, 2018, 01:13:54 PM]
Anyone had any experience with JetMax post the FDS sale?
by nickj
[December 05, 2018, 10:13:20 PM]
KLGA curious !!
by jackpilot
[December 03, 2018, 02:55:38 PM]
Opencockpits boards for sale
by navymustang
[December 03, 2018, 12:57:34 PM]
Does something like this Exist? Projection Glass
by fsaviator
[December 02, 2018, 02:49:40 PM]
Move Project Magenta From FSX to P3D Full cockpit
by ScottThePilot
[December 02, 2018, 12:27:31 PM]
by Extraterra
[December 02, 2018, 06:20:38 AM]
TH2GO Digital vs 3-DV Ports on GPU
by fsaviator
[December 01, 2018, 12:49:54 PM]
Project Magenta with Xplane 11
by Trevor Hale
[November 29, 2018, 03:05:14 PM]
X-plane and SIOC help
by Trevor Hale
[November 29, 2018, 07:43:32 AM]
Prepar3d v4.4 coming to you in 2 days!!!
by Flying_Fox
[November 28, 2018, 10:16:49 AM]
More Throttle Quadrant nightmares.
by iwik
[November 27, 2018, 03:47:31 PM]
Attention All Members and Guests
by Trevor Hale
[November 27, 2018, 02:21:47 PM]
I am now asking for a new world of hurt!
by fsaviator
[November 26, 2018, 11:50:19 PM]
