  • *Users: 3
  • *Guests: 47
  • *Total: 50
Author Topic: USB Hub and Opencockpit's MCP  (Read 473 times)
Offline jmlohrenz
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Jason
  • Home Location: MN, USA
« on: March 11, 2018, 02:45:09 PM »
I sometimes hate technology. Considering I was an IT Director for 18 years I guess that isn't good.  I got a nice Opencockpit MCP v2 on Friday and got it hooked up to my computer just fine.
Switch it over to my Powered USB Hub and it doesn't work.
I've used 'Plugable' brand USB hubs for a while.  Always seem reliable and come with nice strong power supplies to handle demanding USB items.  Any other USB device I plug into the hub works just fine, but the Opencockpit MCP will not.  Once in a great while it'll work, but 9 times out of 10 it will not.
Here's what I've done:
Verified that power management is off on my USB ports (I have Windows 10)
Verified that the Hub is getting a strong 5v from the power supply
Verified that the MCP's power supply is working properly
Verified that other USB devices plugged into this hub work OK
Verified that the MCP works ok by plugging it directly into my PC (works fine, connects to SIOC, and my Sim)
Some things to note:
My hub is USB 2.0
My PC has USB 2, 3, and the newer style C connectors.
My PC will see the MCP through the hub, but say something is wrong with it and will not start.
My PC will see the MCP no problem if it is connected to a 2.0 or 3.0 port on my computer directly.
I know the easy answer is to just have it plugged into my computer, however I have limited USB ports and wanted to use Hubs so I don't have to run everything back to my PC as I begin to develop my cockpit.
If this is just the way it is for this MCP then that's what I'll do.  Just curious from the group if there is a solution or if I am just dealing with a limitation of the device.  There is little documentation / information from Opencockpit on troubleshooting this issue.
Thanks in advance!
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
Re: USB Hub and Opencockpit's MCP
« Reply #1 on: March 11, 2018, 10:23:17 PM »
Jason,
I have used quite a bit of o/c electronics and have found them to be rather fussy. It is really
important to have a good quality hub. Ive used many of the cheaper ones around and have mixed results. Important to make sure the dc supply to the hub is adequate.
In the end i ditched what i had been using because of random dropouts and bought 2 USB 2.0
hubs from Firewire in the US on recommendation from a member(Rays) here and never had anymore problems. They do industrial type units which have been designed properly.
Hope this helps.
Offline jmlohrenz
  • Forum GURU
  • First Name: Jason
« Reply #2 on: March 11, 2018, 11:12:36 PM »
Thanks for the tip.  For now I'll just keep it direct but look to get something better later on when I get into my build further.  Can you provide a link to the one you purchased?
Thanks.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #3 on: March 12, 2018, 02:24:41 AM »
COUNTDOWN TO WF2019
777 Throttle *price reduced*
by mattking247
[December 14, 2018, 08:59:01 PM]
by RayS
[December 14, 2018, 07:28:46 PM]
by ScottThePilot
[December 14, 2018, 12:15:47 PM]
Recipe_for_a_cheap_joystick_encoder.pdf
by MattiasLind
[December 14, 2018, 07:53:57 AM]
Triple channel splitter with professional edge blender $3750.00
by Lee737
[December 13, 2018, 09:41:31 PM]
Santa Flight (Saturday December 15th)
by Trevor Hale
[December 13, 2018, 07:43:04 AM]
Join me on Vatsim Tonight
by Trevor Hale
[December 12, 2018, 05:50:50 PM]
My A320-like cockpit
by MCrevot
[December 12, 2018, 09:41:11 AM]
U.S. holiday booked!
by Trevor Hale
[December 11, 2018, 10:35:15 AM]
New supplier for your sim
by Fcoq
[December 11, 2018, 01:12:29 AM]
X-Plane 737-800 Build
by kenrosefire
[December 10, 2018, 08:55:16 PM]
[December 10, 2018, 04:49:22 PM]
Yoke and Rudder Centering with Dynamic Load Control / Force Feedbacl
by bernard S
[December 08, 2018, 12:14:01 PM]
anyone that can help me out get imperial size bolts??
by Gallie
[December 08, 2018, 11:03:29 AM]
OpenCockpits I/O Cards
by al23
[December 08, 2018, 09:22:52 AM]
Level D B767 For FS9
by Goodenough
[December 06, 2018, 08:19:20 PM]
Thickness of a resl 737-800 Glareshield / MCP Light panel
by Joe Lavery
[December 06, 2018, 01:13:54 PM]
Anyone had any experience with JetMax post the FDS sale?
by nickj
[December 05, 2018, 10:13:20 PM]
KLGA curious !!
by jackpilot
[December 03, 2018, 02:55:38 PM]
Opencockpits boards for sale
by navymustang
[December 03, 2018, 12:57:34 PM]
Does something like this Exist? Projection Glass
by fsaviator
[December 02, 2018, 02:49:40 PM]
Move Project Magenta From FSX to P3D Full cockpit
by ScottThePilot
[December 02, 2018, 12:27:31 PM]
by Extraterra
[December 02, 2018, 06:20:38 AM]
TH2GO Digital vs 3-DV Ports on GPU
by fsaviator
[December 01, 2018, 12:49:54 PM]
Project Magenta with Xplane 11
by Trevor Hale
[November 29, 2018, 03:05:14 PM]
X-plane and SIOC help
by Trevor Hale
[November 29, 2018, 07:43:32 AM]
Prepar3d v4.4 coming to you in 2 days!!!
by Flying_Fox
[November 28, 2018, 10:16:49 AM]
More Throttle Quadrant nightmares.
by iwik
[November 27, 2018, 03:47:31 PM]
Attention All Members and Guests
by Trevor Hale
[November 27, 2018, 02:21:47 PM]
I am now asking for a new world of hurt!
by fsaviator
[November 26, 2018, 11:50:19 PM]
