  • *Users: 3
  • *Guests: 62
  • *Total: 65
Author Topic: Building a MIP out of MDF  (Read 702 times)
Offline Steenos
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Justin
  • Home Location: KCHA
« on: April 16, 2018, 10:00:53 AM »
So I've done tons of research like all of us have on the MIP. If I was to get a FDS MIP it would be over 3k. It's doable but just a lot of money. And the fact that I'm not using PROSIM for my build and XPlane Peter said there wouldn't really be much support.
What I've seen a lot of people do on youtube is just make it out of MDF. Is 10mm basically just .5 inch in the US? I was going to have Lowes cut the pieces to size because I don't have a table saw and use a skill saw to cut the angles.
What are your guys thoughts? Have you built a MIP out of MDF?
Thanks.
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: Building a MIP out of MDF
« Reply #1 on: April 16, 2018, 11:33:05 AM »
First of all, what do you call a MIP ?
The flat front instrument panel
Or the whole structure including the front panel
MFDF is not an easy material to work with. (heavy, messy dust, too thick for the front panel, does not hold screws on the side etc)
From experience, I would recommend starting with something like  this:
https://flightdeck-solutions.myshopify.com/collections/b737ng/products/fds-b737ng-mip-main-2-0
From FDS or any other vendor of your choice. You will avoid several months of frustration with MDF, adjustments, doing and redoing, ...for a questionable result.
Nevertheless, the  structure itself (sides, CDU box, shelving at the back etc) can be built out of MDF with ease, but for the front panel with its many cutouts (display units, bezels, landing gear etc) you would be much better off by ordering it from an outside supplier.
I did that for my previous sim and was happy with it...
No point making the front panels yourself IMHO when you see this:
http://www.cockpitsimparts.co.uk/index.php?id_category=16&controller=category
Last tip, stick with one supplier, mixing products is a sure recipe for trouble!
« Last Edit: April 16, 2018, 12:05:46 PM by jackpilot »
Offline Steenos
  • Forum GURU
« Reply #2 on: April 16, 2018, 12:34:03 PM »
Jack! You're all over it. I just wanted to build the structure and use the panels from cockpitsimparts just exactly like your picture. I've never built one before. But I figured if I got Lowes to cut the pieces to size then I just had to cut out the angles that might make it easier?
I just remember trying to build the overhead frame it was super frustrating trying to get everything to line up. I just thought the MIP structure might be a little easier.
Offline Aerosim Solutions
  • I may as well be Staff!
  • Simulator part supplier
    • Aerosim Solutions
  • First Name: Gwyn Perrett
  • Home Location: Perth, Western Australia
« Reply #3 on: April 18, 2018, 06:49:50 PM »
I suggest the use of 6mm PVC (1/4"), Great material to work with. It paints well with a decent etch primer and you can tap threads into it, glue it, heat and bend it. Most of my structure is PVC.
Cheers Gwyn
Boeing 737NG using Prepar3D v3.35, Prosim737, FDS SYS cards, FDS CDUs, CP Flight EL MCP & EFIS & Aerosim Solutions hardware of course!
Check out my website here -
http://www.aerosimsolutions.com.au
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by bernard S
[Today at 10:32:13 AM]
Display help with FSX
by matta757
[Today at 09:28:55 AM]
Help in building a GTN 650/750 for Reality XP
by blueskydriver
[Today at 01:18:38 AM]
Join me on Vatsim Tonight
by jackpilot
[January 19, 2019, 08:10:07 PM]
Cockpit Components
by awdoman
[January 18, 2019, 01:06:21 PM]
Aerosoft Australia Strikes Again!
by spencerc19
[January 18, 2019, 09:10:41 AM]
12v power supply for map light
by blueskydriver
[January 18, 2019, 07:49:31 AM]
Windscreen/windshield Wipers
by bernard S
[January 17, 2019, 10:50:36 PM]
B767 MIP
by jackpilot
[January 17, 2019, 08:41:47 PM]
by navymustang
[January 17, 2019, 08:30:23 AM]
STEERING AND YOKE 737 PROMO
by blueskydriver
[January 16, 2019, 06:07:16 PM]
YOU CAN HELP SHAPE FLIGHTSIMEXPO: 2020
by Trevor Hale
[January 16, 2019, 01:10:08 PM]
Streaming with Elgato tools.
by RayS
[January 15, 2019, 03:43:59 PM]
by navymustang
[January 14, 2019, 11:07:28 AM]
Wanted: B737 Linked Yoke,
by dvst8r
[January 14, 2019, 10:55:31 AM]
Replace display Flyengravity CDU
by flymo
[January 13, 2019, 01:10:55 PM]
It's been a while. a new picture of my baby!
by Trevor Hale
[January 13, 2019, 09:21:19 AM]
by blueskydriver
[January 13, 2019, 08:25:21 AM]
by blueskydriver
[January 10, 2019, 04:12:26 AM]
Aircraft Registration Placard
by jackpilot
[January 07, 2019, 10:19:13 AM]
How do you manage power amperage for your sim
[January 07, 2019, 10:12:23 AM]
Trim Wheels
by Joe Lavery
[January 07, 2019, 04:18:15 AM]
ActiveSky - across networked PCs anyone
by FredK
[January 06, 2019, 10:54:28 PM]
ACE 737 Pro Yoke stab trim switch issue help needed
by dornier
[January 06, 2019, 08:23:42 PM]
Help In wiring LED and Fan
by GyverX
[January 06, 2019, 03:54:28 PM]
[January 06, 2019, 11:38:46 AM]
B737 OEM Throttle Quadrant and more to come
by archen
[January 05, 2019, 06:27:11 PM]
Wanted: 737 FMC/CDU
by blueskydriver
[January 04, 2019, 07:35:04 PM]
