  • *Users: 0
  • *Guests: 54
  • *Total: 54
Author Topic: Wanted: OEM gear lever 737  (Read 1830 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« on: April 23, 2018, 04:52:29 PM »
Let me know if anything pops up.
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: Wanted: OEM gear lever 737
« Reply #1 on: April 23, 2018, 06:35:10 PM »
They do ..at insane prices
Besides the mechanism at the back is HUGE and hard to fit in a regular install :o
Offline bernard S
  • I may as well be Staff!
  • Aviation Enthusiast
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #2 on: April 23, 2018, 06:56:15 PM »
how you going to tension it   and power it    curious 😁
Offline kurt-olsson
  • First Name: Peter
« Reply #3 on: April 25, 2018, 03:54:51 AM »
Tension is allready there if i am correct, and power the solenoid with 28v.
Offline archen
  • Forum GURU
    • Anders Simparts
  • First Name: Anders
  • Home Location: Falun
« Reply #4 on: April 25, 2018, 09:00:15 AM »
Try Nick at APHS. He usually have them but at high price.
I've modified a real lever to fit FDS MIP.
Had to change microswitches and mill a few new plates. Also cut it shorter.
 See here
https://riksarchen.wordpress.com/2014/02/22/mip-progress-now-fds-mip-instead-of-simworld/
Anders Simparts
http://www.anderssimparts.com
Offline kurt-olsson
  • First Name: Peter
« Reply #5 on: April 26, 2018, 12:25:48 PM »
Seen one at APHS but too much for me. Hope to find one with reasonable price range.
Offline kurt-olsson
  • First Name: Peter
« Reply #6 on: August 19, 2018, 12:20:20 PM »
BUMP
I am also interested in replicas if its OEM dimensions and look.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #7 on: August 19, 2018, 09:45:27 PM »
The OEM is a huge monster , you would be better off with a nice repro
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #8 on: August 20, 2018, 04:23:40 AM »
If I were you, I'd buy one from Nick at APHS. Even though it might seem high priced, it actually isn't when you consider the time and cost to remove parts from the real planes.
And, in the past I thought the same as most, but after removing items myself I can attest that it's not easy to get things out of 30-40yr old aircraft...
Besides, waiting for someone (another builder) to sell one (or whatever you may be looking for) can take a long time, so paying that little extra for items from Nick is well worth the "not" waiting forever to get one from someone else.
Offline peterkwu
  • Forum GURU
    • fly737ng.com
  • First Name: Peter
  • Home Location: Vienna, VA
« Reply #9 on: August 20, 2018, 05:59:36 AM »
I agree with John that the price is actually reasonable when you think about the cost of removal. Having watched the OEM resale market for 10+ years, I can tell you that the cost of these items has gone up dramatically the past few years. Nick is actually one of the most reasonable sellers of OEM parts at this point in terms of cost.
I have to respectfully disagree with Jack that a reproduction model is just as good as an OEM one. In my opinion there is no comparison. I've had several reproductions (FDS, CockpitSonic etc), and they never seem to make the handle long enough to accurately reproduce the movement of the real thing. The OEM model is also really heavy duty, and gives a much more satisfying 'thunk' when moved from one position to another. I don't know of a reproduction model with a working override trigger or solenoid, if someone does please correct me.
The solenoid is super easy to get working. I published a how-to for converting an OEM lever in 2015:
http://www.fly737ng.com/?p=228
As most OEM levers out there are from classic model airframes, you will also probably want to exchange the old, yellowed, large wheel for a new, smaller, white, NG style one purchased from FDS. Here's another post on how to do that:
http://www.fly737ng.com/?p=301
In summary my advice is to save enough $$$ to buy one from Nick at APHS. You won't be sorry.
Peter
Check on my progress at
Offline mickc
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #10 on: August 20, 2018, 07:27:06 AM »
Exactly what Peter said.
Also if you want to make it completely NG-like, shorten the handle by 1"
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #11 on: August 20, 2018, 08:46:56 AM »
OK OK Guys... you almost convinced me!!  :D
Offline rw
  • CockpitBuilder
  • First Name: Roel
  • Home Location: Amsterdam
« Reply #12 on: August 20, 2018, 03:05:56 PM »
Hi guys,
In the same boat here - been lurking for months for a OEM gear lever (assembly) on Ebay and Dutch second hand websites but was unsuccessful.
Until I found a 737NG lever for only 2800 USD ;D here
And a one inch longer another version for 86 USD here here.
I purchased the 86USD one and there seem to be more available.
This is not the whole assembly, so requires additional work to get it functioning. Which will require:
- an axis for rotation
- friction for the rotation
- a backplate for the 3 gear settings (up, down, off)
- a structure to lock handle using solenoid
- a solenoid for gear lock override
- cutting the handle 1 inch short
- adding a smaller (and less yellowish) gear lever knob
Quite some engineering ;)
Upside is that you have full flexibility in fitting it in the MIP. For me this is the main reason, as I will have most freedom picking sizes to most optimal LCD screens for CENTER DU, PFD, ND in terms of resolution, viewing angle and contrast ratio.
Hope this is useful!
« Last Edit: August 20, 2018, 04:37:36 PM by rw »
Offline jeffreyk
  • Forum GURU
  • First Name: Jeffrey
  • Home Location: Veghel
« Reply #13 on: August 20, 2018, 04:34:51 PM »
Roel,
I don't believe that's an NG handle you're having over there.
It seems shorter because the spring is fully released.
If you take a look at actual NG levers you'll see that the rivets of the "wheel" part are very close to the red unlock trigger so not as seen on that eBay page.
Might be wrong but to me it's just a very expensive CL handle.
« Last Edit: August 20, 2018, 04:36:00 PM by jeffreyk »
Offline rw
  • CockpitBuilder
  • First Name: Roel
« Reply #14 on: August 20, 2018, 04:43:24 PM »
Hi Jeffrey,
Seems you're right. Probably must have been a little dizzy due to the price tag ;)
« Last Edit: August 20, 2018, 04:43:57 PM by rw »
Offline Flying_Fox
  • Forum GURU
  • P3D/Win7-64/FDS/3 x Optoma GT1080Darbee
    • My build blog
  • First Name: Nick
  • Home Location: Halifax, Canada
« Reply #15 on: August 20, 2018, 05:02:37 PM »
The best is (expensive) enemy of the good...  ;D
 :2cw:
Offline mickc
  • First Name: Mick
« Reply #16 on: August 20, 2018, 08:52:17 PM »
Roel,
Correct,
This one has been on Ebay for years at the same price  :o :o
The NG levers don't have the cable wheel either, they use a push-pull cable instead of the older cable & drum setup
COUNTDOWN TO WF2019
For sale
by TNT
[July 18, 2019, 07:57:29 PM]
by Philip
[July 17, 2019, 06:47:22 PM]
[July 17, 2019, 02:55:53 PM]
Boeing 737 Dual Linked Yokes
by tennyson
[July 16, 2019, 08:59:28 PM]
by patiju
[July 16, 2019, 02:01:48 PM]
by Mach7
[July 16, 2019, 04:52:26 AM]
Korry 318 gets hot.
by Joe Lavery
[July 16, 2019, 03:49:14 AM]
by blueskydriver
[July 14, 2019, 10:25:43 AM]
by blueskydriver
[July 13, 2019, 03:46:30 AM]
by blueskydriver
[July 12, 2019, 10:53:12 PM]
by fsaviator
[July 10, 2019, 08:35:14 PM]
PM MCP.ini Question...
by ScottThePilot
[July 10, 2019, 12:56:38 PM]
Stab Trim Indicator...
by ScottThePilot
[July 09, 2019, 12:56:42 PM]
Teensy LC Throttle Quadrant
[July 08, 2019, 08:09:41 AM]
[July 08, 2019, 08:05:27 AM]
Anders Simparts - Summer info
by archen
[July 07, 2019, 03:30:31 AM]
by kattz
[July 03, 2019, 09:26:22 PM]
by ifeliciano
[July 02, 2019, 09:58:37 AM]
by mickc
[July 01, 2019, 08:01:04 PM]
Happy Canada Day
by jackpilot
[July 01, 2019, 10:09:40 AM]
MH 370 Article
by FredK
[June 30, 2019, 07:28:41 PM]
by kattz
[June 30, 2019, 06:08:50 PM]
International shipping?
by jackpilot
[June 27, 2019, 08:29:07 AM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
by jackpilot
[June 25, 2019, 08:19:42 AM]
by blueskydriver
[June 24, 2019, 02:29:16 PM]
by Buster99
[June 22, 2019, 04:12:34 PM]
by kattz
[June 22, 2019, 12:40:51 PM]
by jackpilot
[June 20, 2019, 12:26:51 PM]
by kevinsayre
[June 19, 2019, 03:57:33 PM]
