  • *Users: 3
  • *Guests: 54
  • *Total: 57
Author Topic: 737 Circuit Breaker panel lights  (Read 1091 times)
Offline Winstonc
  • Forum GURU
  • Aviation Enthusiast
  • First Name: David
  • Home Location: Los Angeles
« on: June 14, 2018, 02:04:53 PM »
I will be adding CB panel lights to my cockpit and I am looking for close up pictures of the 4 lights (1 FO side in the roof panel, 1 on each side in the side panel recess and one on the Captain side on the diagonal window rail).
I need detail pictures as I intend to draw them up in CAD and 3D Print / laser cut as appropriate.
If anyone can help, I would be most grateful.
Offline navymustang
  • Simulation Engineer
  • Forum GURU
  • First Name: Jim
  • Home Location: KMCO
Re: 737 Circuit Breaker panel lights
« Reply #1 on: June 14, 2018, 02:14:23 PM »
I believe the two side panel lights are standard Grimes model MS25027-1 lights. This is in the classic, not sure if they changed that for the NG.
Offline Winstonc
  • Forum GURU
  • First Name: David
« Reply #2 on: June 14, 2018, 02:18:12 PM »
Yep, those look right.  Thank you.  2 down two to go.
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #3 on: June 14, 2018, 03:06:50 PM »
You forgot one. There are 5 CB panel lights.
- FO ceiling panel
- FO side panel/below window - grimes p/n 15-0121-2
- FO on floor behind the pilot seat.
- CPT on sliding (DV) window rail
- CPT side panel/below window - grimes p/n 16-0255-1
p/n are from my classic parts, they are also different revision lights, but i dont see a difference.
will try to post some pictures tomorrow.
Michael
Offline Winstonc
  • Forum GURU
  • First Name: David
« Reply #4 on: June 14, 2018, 03:40:48 PM »
Thanks Michael.
Offline navymustang
  • Forum GURU
  • First Name: Jim
« Reply #5 on: June 14, 2018, 04:22:52 PM »
Slightly off topic - the Sismo overhead circuit breaker panel rheostat actually turns on or off (with brightness) the light which is located right above the knob. I know that is not a circuit breaker light. So what actual knob in the aircraft controls that light?
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #6 on: June 14, 2018, 04:35:12 PM »
The light in the FWD overhead frame is the pedestal flood light
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #7 on: June 14, 2018, 05:10:17 PM »
Hi David
Just FYI I did not try to emulate the real lighting, instead I used 2 Wemacs
High load 24v  bulbs were replaced by 12v led equivalents which emit no heat
Offline B737NG
  • Forum GURU
  • Conversion of real 737 nose (N351UA)
    • My site
  • First Name: Steve Wekarchuk
  • Home Location: CYYZ
« Reply #8 on: June 14, 2018, 06:28:06 PM »
Pics here of the breaker lights...
https://1drv.ms/f/s!Av9ocAy5yXqb7T10vqOMJQAksCKU
Steve Wekarchuk
'B737NG'
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #9 on: June 23, 2018, 06:25:42 AM »
Here are some pics of the FO floor breaker light
Dimensions are in CM
cheers,
Michael
Offline Winstonc
  • Forum GURU
  • First Name: David
« Reply #10 on: June 24, 2018, 08:22:26 PM »
Thanks guys for all the info.
This is the link to my latest video on the cb’s
https://youtu.be/6_GRCG5CPxE
Offline B737NG
  • Forum GURU
    • My site
« Reply #11 on: June 26, 2018, 09:31:22 PM »
Looking awesome David. Good thing I'm not a hand model, or I'd have to charge you!  ;D
Steve Wekarchuk
'B737NG'
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by bernard S
[Today at 10:32:13 AM]
Display help with FSX
by matta757
[Today at 09:28:55 AM]
Help in building a GTN 650/750 for Reality XP
by blueskydriver
[Today at 01:18:38 AM]
Join me on Vatsim Tonight
by jackpilot
[January 19, 2019, 08:10:07 PM]
Cockpit Components
by awdoman
[January 18, 2019, 01:06:21 PM]
Aerosoft Australia Strikes Again!
by spencerc19
[January 18, 2019, 09:10:41 AM]
12v power supply for map light
by blueskydriver
[January 18, 2019, 07:49:31 AM]
Windscreen/windshield Wipers
by bernard S
[January 17, 2019, 10:50:36 PM]
B767 MIP
by jackpilot
[January 17, 2019, 08:41:47 PM]
by navymustang
[January 17, 2019, 08:30:23 AM]
STEERING AND YOKE 737 PROMO
by blueskydriver
[January 16, 2019, 06:07:16 PM]
YOU CAN HELP SHAPE FLIGHTSIMEXPO: 2020
by Trevor Hale
[January 16, 2019, 01:10:08 PM]
Streaming with Elgato tools.
by RayS
[January 15, 2019, 03:43:59 PM]
by navymustang
[January 14, 2019, 11:07:28 AM]
Wanted: B737 Linked Yoke,
by dvst8r
[January 14, 2019, 10:55:31 AM]
Replace display Flyengravity CDU
by flymo
[January 13, 2019, 01:10:55 PM]
It's been a while. a new picture of my baby!
by Trevor Hale
[January 13, 2019, 09:21:19 AM]
by blueskydriver
[January 13, 2019, 08:25:21 AM]
by blueskydriver
[January 10, 2019, 04:12:26 AM]
Aircraft Registration Placard
by jackpilot
[January 07, 2019, 10:19:13 AM]
How do you manage power amperage for your sim
[January 07, 2019, 10:12:23 AM]
Trim Wheels
by Joe Lavery
[January 07, 2019, 04:18:15 AM]
ActiveSky - across networked PCs anyone
by FredK
[January 06, 2019, 10:54:28 PM]
ACE 737 Pro Yoke stab trim switch issue help needed
by dornier
[January 06, 2019, 08:23:42 PM]
Help In wiring LED and Fan
by GyverX
[January 06, 2019, 03:54:28 PM]
[January 06, 2019, 11:38:46 AM]
B737 OEM Throttle Quadrant and more to come
by archen
[January 05, 2019, 06:27:11 PM]
Wanted: 737 FMC/CDU
by blueskydriver
[January 04, 2019, 07:35:04 PM]
