  • *Users: 1
  • *Guests: 73
  • *Total: 74
Author Topic: CR-10, CR-10S, CR-10S4 and CR-10S5 3d Printer Info and Links...  (Read 592 times)
Offline blueskydriver
  • First Name: John
  • Home Location: WI
Hey Everyone,
Here are some preferred video links I watched when starting out with the CR-10S. Mind you some are for the CR-10, but they do apply to the S model.
These are by San Tube’s channel
https://youtu.be/KTAPC9_HFh0
https://youtu.be/ZAJOjWeyMJg
https://youtu.be/xH26U2asLL4
https://youtu.be/mPyaEi7_fFM
https://youtu.be/wEvIEVAJ_P8
I suggest you watch most of his other videos regarding the CR-10...
Also, I use Simplify 3d software to do all the model setup/print settings and I like this much better over Cura. Please watch all of the training videos for Simplify 3d.
Start Here:
https://www.simplify3d.com/support/videos/
If you have questions about the CR-10, just post them and for other 3d printing questions in general, post those as well. The amount of Cockpit Builders’ members with the CR-10 and/or other models is growing; therefore, there are more knowledgable users, who are building cockpits, that can answer now...
« Last Edit: October 09, 2018, 01:30:55 AM by blueskydriver »
  • First Name: John
  • Home Location: WI
« Reply #1 on: October 09, 2018, 01:29:39 AM »
I will add some more info to this thread soon, now that I got the CR-10S5 and the CR-10S4 coming...
« Last Edit: October 09, 2018, 01:32:02 AM by blueskydriver »
Offline jmlohrenz
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Jason
  • Home Location: MN, USA
Re: CR-10, CR-10S, CR-10S4 and CR-10S5 3d Printer Info and Links...
« Reply #2 on: October 09, 2018, 11:08:09 AM »
https://www.th3dstudio.com/ezabl-kit/
Highly recommend their ABL kit that is plug and play for the CR-10's.  It includes an updated firmware so the system can store the matrix for your bed.  It helps maintain a level bed.
Also, https://www.th3dstudio.com/product/cr-10solidmounts/  to change out the springs to work better with the ABL.
Finally, adding some dampers to the servo motors will do two things, help remove any bed jitter from the shifting of the motors, and make your printer SIGNIFICANTLY more quiet.
I love my CR-10s.  Currently working on a Ford V-8 FlatHead for my dad that is motorized.
  • First Name: John
  • Home Location: WI
« Reply #3 on: October 09, 2018, 01:28:46 PM »
Hey Jason,
Thank you for posting the TH3D info and links. After I watched both videos on the EZABL Connect, I think this would be a very worth wild purchase; especially, there would no more manual leveling of the beds that I do before each and every print...OMG!
Once I get the new S4 here, I will order 4 EZABL Connect units along with the solid mounts and cam mounts...
  • First Name: John
  • Home Location: WI
« Reply #4 on: October 09, 2018, 02:16:21 PM »
Okay, here are some links I promised:
First, even though these items are not specific to CR-10 3D printers, they are what I use to make my prints better on the CR-10.
The vacuum sealer I purchased is from Walmart and it works great, but you must also buy the separate 11"x16" 1 gallon bags for the standard size filament spools.
Here is the Vacuum Sealer:
https://www.walmart.com/ip/Mossy-Oak-Gamekeeper-Vac-Sealer/254961099
Here are the bags:
https://www.walmart.com/ip/Mossy-Oak-GameKeeper-Gallon-Vaccum-Bags/324965059
Next, is the dehydrator units I purchased and modified by cutting out the center sections on three of the four trays. I have four of these units, one for each printer. Why four? Well, I like to dehydrate the filament spool for 12 hours at 40 C before using it for printing; however, if I want to run multiple printers I need multiple dehydrators running. The key or reason to all of this dehydration is eliminating stringy prints or bumps/print zits, and I can fully attest that it works.
Here are the ones I purchased:
https://www.walmart.com/ip/Mossy-Oak-GameKeeper-4-tray-Electric-Dehydrator/552666446
Lastly, I also purchased some plastic bins that were 4 for $10, and where the standard spool fits perfectly in them, they are these ones here:
https://www.walmart.com/ip/Sterilite-12-Qt-11-L-Storage-Boxes-Teal-Sachet-Set-of-4/142079510
Or, you could do this many and save money:
https://www.walmart.com/ip/Sterilite-Set-4-12-Qt-Storage-Box-Teal-Sachet-Available-in-Sets-of-16-or-Set-of-4/55413816?athcpid=55413816&athpgid=athenaItemPage&athcgid=null&athznid=PWVUB&athieid=v0&athstid=CS020&athguid=466001f5-46cfa622-dfc118c19a18a716&athena=true
Offline Joe Lavery
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #5 on: October 09, 2018, 08:15:23 PM »
I see that a user has printed his own similar bed mounts for the CR10, the design is on Thingiverse.
https://www.thingiverse.com/thing:2683800
www.pcpilot.net
Offline jmlohrenz
  • Forum GURU
  • First Name: Jason
« Reply #6 on: October 10, 2018, 11:06:35 AM »
You should still check your overall bed level.  Many times the glass itself is warped.  If you join the CR-10 group on facebook many recommend either getting 12x12 glass from ikea or Home Depot to help with this.  The ABL does a good job for minor fluctuations in the bed, but if your glass has a serious warp to it, you may still have some issues.
Offline Joe Lavery
  • 737 Builder
« Reply #7 on: October 10, 2018, 12:48:56 PM »
As one of the YouTube video loggers suggested, I bought a pack of mirrors, which tend to be perfectly flat. Since then I haven't had any issues with printing at all.
I used to have trouble with parts coming off the bed while printing, even when I used a glue stick. But then I saw an advert for a product called PrintBite plus, which is brilliant. It holds the part until the bed cools and then you  can simply lift it off. You are right though Jason, getting the bed level is most important.
www.pcpilot.net
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #8 on: October 10, 2018, 01:02:44 PM »
I use a glass Bed (Borosilicate) and PEI Sheet,  Love it...
FlightSimExpo 2019
FsExpo
FlyAB Simparts: A new supplier for your OEM needs
by Trevor Hale
[Today at 10:51:54 PM]
737 NG Throttle Levers
by mickc
[Today at 06:19:56 PM]
For sale: A set of faceplate panel for pedestal
by Ed
[Today at 03:53:26 PM]
Join me on Vatsim Tonight
by Trevor Hale
[Today at 12:10:28 PM]
Throttle
by IFLY3
[Today at 08:49:37 AM]
B737-800 Flight Sim for sale $85,000.00
by Rob_b
[Today at 12:47:11 AM]
by iwik
[February 15, 2019, 06:47:11 PM]
by Joe Lavery
[February 15, 2019, 05:39:06 PM]
by bernard S
[February 15, 2019, 11:34:25 AM]
Anyone seen OEM 737-900 ER Throttle Quadrant?
by Fly_AB
[February 15, 2019, 10:32:18 AM]
For Sale: P&P Opencockpit VHF, Transponder, and ADF
by Fly_AB
[February 15, 2019, 09:08:24 AM]
737 DIY MIP For Sale
by Trevor Hale
[February 14, 2019, 11:03:35 AM]
New supplier for your sim
by Fcoq
[February 14, 2019, 12:18:44 AM]
For Sale Prosim 737 v2.03 License
by mdavenport
[February 12, 2019, 04:00:00 PM]
For Sale: Jetmax 737 TQ - Texas, USA
by MistyBlue
[February 11, 2019, 12:11:31 AM]
by navymustang
[February 10, 2019, 12:50:48 PM]
Operating System Blues
by n4208t
[February 10, 2019, 09:56:52 AM]
[February 10, 2019, 09:31:17 AM]
Revolution Simproducts out of business?
by fsaviator
[February 09, 2019, 12:18:30 PM]
For sale: CPFlight MIP737SE
by Fly_AB
[February 08, 2019, 11:29:26 PM]
For sale: Engravity sixpack pairs --- SOLD
by Fly_AB
[February 08, 2019, 08:32:04 PM]
by MjTom
[February 08, 2019, 08:00:54 AM]
by Trevor Hale
[February 08, 2019, 07:41:50 AM]
737 Demonstrator For Sale
by Trevor Hale
[February 08, 2019, 07:39:34 AM]
Looking for B737NG or A320 SIM for Home Use
by KingAviation
[February 08, 2019, 03:17:35 AM]
Zibo 737 FlightControl Dataref/Commands
[February 05, 2019, 05:34:35 PM]
by FredK
[February 05, 2019, 12:58:20 AM]
Flight Control Panel A Side
[February 04, 2019, 04:34:38 PM]
STEERING AND YOKE 737 PROMO
by alvaro castillo
[February 03, 2019, 09:19:32 PM]
by Extraterra
[February 03, 2019, 02:51:28 PM]
