  • *Users: 0
  • *Guests: 40
  • *Total: 40
Author Topic: How to turn all MIP LCDs on at once?  (Read 1257 times)
Offline Marco ERJ
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Marco
  • Home Location: KCVG
« on: July 13, 2018, 09:21:29 PM »
Hi everyone,
Is there a way to turn all MIP LCDs on at once when firing up the flight deck, instead of having to reach out and push the power button on each unit? Typically I think in a real plane you turn on the avionics master and all displays come to life. Curious if anyone has solved for this already...
Any insight?
Thanks everyone!
Marco
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
Re: How to turn all MIP LCDs on at once?
« Reply #1 on: July 13, 2018, 09:50:14 PM »
I have mine connected by relays, which are triggered by Prosim
Most monitors will revert to the last power state when power is connected, so if you have the monitor turned on, and unplug the power, it will turn back on when power is re-connected.
Sometimes you may need to turn this feature on in the control menus of the monitor itself.
Offline Marco ERJ
  • Forum GURU
  • First Name: Marco
« Reply #2 on: July 14, 2018, 11:41:50 PM »
Thanks, Mick!
I am not using Prosim, but I’ll test my LCDs for power state. Then a couple of relays tied to the avionics master switches may do the trick.
Thanks again!
Marco
Offline bernard S
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #3 on: July 16, 2018, 10:41:09 AM »
does not each power bus light up   and they light up according to which bus ?
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #4 on: July 16, 2018, 01:17:53 PM »
All LCDs plugged on the same power bar
All on
Switch the power bar off
All off
next time you switch the power bar on they all light up.
You may add an  FSUIPC fonction  to switch avionics on or off with a dedicated switch/button
Offline bernard S
« Reply #5 on: July 19, 2018, 09:39:52 PM »
seems my point lost.. the crts /lcds on aircraft to NOT come on all at once .. as respective power bus activates then they sequence
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #6 on: July 19, 2018, 09:56:30 PM »
Yes that is correct, and it is modeled by the avionics software (SimA for me)
Starting cold and dark with computers running
Battery bus fires only Capt side PFD/ND/CDU and engine DU with a delay (that you can set)
Then Ext power or APU on bus fire them all  in sequence etc etc
Hard to replicate with no software. ::)
« Last Edit: July 19, 2018, 10:02:26 PM by jackpilot »
Offline bernard S
« Reply #7 on: July 19, 2018, 10:08:29 PM »
eemm  okay so no aircraft power buses functional.in sim a (thats odd ) but then i dont have a 73..   could you not add say a resistor and timer ? to create this effect   justa a thought
Offline mickc
  • First Name: Mick
« Reply #8 on: July 19, 2018, 11:00:03 PM »
I think Jack might be talking about something else.
Most home setups I have seen have all the LCD screens on, but blank when they are "cold and dark"
I know nothing of Sim Avionics software, but with Prosim there are gates available to signal power availability on the different buses.
In my setup, cold and dark is actually cold and dark so nothing is powered, and I have the gates above trigger relays to physically turn on the appropriate screens when bus power is available.
Makes it quite scary when you lose AC power and half your panel goes black!
I'm also using these gates for the emergency standby lighting, where key panels and gauges are backlit with no AC power available, and at a fixed brightness etc, just like the real system.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #9 on: July 20, 2018, 08:06:44 AM »
I think we are talking about the same thing with different words ! lol
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by kattz
[Today at 04:38:28 PM]
FDS CDU old
by kattz
[Today at 01:13:46 PM]
Jetmax TQ - motorized it?
by bernard S
[Today at 12:26:45 PM]
Serial Key
by hiflight1
[Today at 05:10:00 AM]
Join me on Vatsim Tonight
by Trevor Hale
[May 15, 2019, 01:58:50 PM]
Gauge circuit
by jackpilot
[May 15, 2019, 01:56:51 PM]
Prosim and RSP TQ interfacing
by jfuenmayor
[May 15, 2019, 08:53:22 AM]
Arduino Mega question Newbie
by Yair1956
[May 15, 2019, 02:23:57 AM]
f18 mfd
by bernard S
[May 14, 2019, 11:15:44 PM]
Multi-Projector color calibration
by fsaviator
[May 13, 2019, 04:32:23 PM]
Immersive Calibration Pro help?
by jskibo
[May 13, 2019, 09:22:00 AM]
X-Plane 737-800 Build
by kenrosefire
[May 12, 2019, 08:37:05 PM]
KBD03 Keyboard Emulator
by Yair1956
[May 12, 2019, 03:52:05 PM]
5 Position Rotary Spring return Switch
by Yair1956
[May 12, 2019, 03:09:25 PM]
Flyengravity desktop MIP
by patiju
[May 11, 2019, 05:11:05 PM]
Pfd display.
by Patt737
[May 08, 2019, 12:48:32 PM]
Mini Sim
by jskibo
[May 08, 2019, 08:36:28 AM]
F16 Simulator For Sale
by blueskydriver
[May 08, 2019, 12:14:40 AM]
Wanted: Collins Style radios
by jkbarr30
[May 07, 2019, 08:23:32 PM]
Crap! 26V on 5V backlight!
by Steenos
[May 07, 2019, 05:33:46 PM]
by Ed
[May 07, 2019, 08:01:22 AM]
Prosim 737 iOS help
by Aztrucker
[May 06, 2019, 11:56:30 PM]
Fly Elise Warping
by jskibo
[May 06, 2019, 11:14:31 AM]
CPFlight 737 NG MCP Pro and Efis Pro (SOLD)
by patiju
[May 05, 2019, 10:52:46 AM]
Operating System Blues
by 727737Nut
[May 03, 2019, 11:54:35 AM]
FOR SALE - 737 Sim items
by flymo
[May 02, 2019, 07:43:53 AM]
Cpflight MCP737PRO (SOLD)
by archen
[April 30, 2019, 02:07:33 PM]
by Trevor Hale
[April 29, 2019, 07:29:12 PM]
Wanted: FDS 737 CDU, EFIS
by archen
[April 28, 2019, 02:32:00 AM]
by navymustang
[April 27, 2019, 05:52:13 PM]
