  • *Users: 1
  • *Guests: 56
  • *Total: 57
Author Topic: How to turn all MIP LCDs on at once?  (Read 1085 times)
Offline Marco ERJ
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Marco
  • Home Location: KCVG
« on: July 13, 2018, 09:21:29 PM »
Hi everyone,
Is there a way to turn all MIP LCDs on at once when firing up the flight deck, instead of having to reach out and push the power button on each unit? Typically I think in a real plane you turn on the avionics master and all displays come to life. Curious if anyone has solved for this already...
Any insight?
Thanks everyone!
Marco
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
Re: How to turn all MIP LCDs on at once?
« Reply #1 on: July 13, 2018, 09:50:14 PM »
I have mine connected by relays, which are triggered by Prosim
Most monitors will revert to the last power state when power is connected, so if you have the monitor turned on, and unplug the power, it will turn back on when power is re-connected.
Sometimes you may need to turn this feature on in the control menus of the monitor itself.
Offline Marco ERJ
  • Forum GURU
  • First Name: Marco
« Reply #2 on: July 14, 2018, 11:41:50 PM »
Thanks, Mick!
I am not using Prosim, but I’ll test my LCDs for power state. Then a couple of relays tied to the avionics master switches may do the trick.
Thanks again!
Marco
Offline bernard S
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #3 on: July 16, 2018, 10:41:09 AM »
does not each power bus light up   and they light up according to which bus ?
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #4 on: July 16, 2018, 01:17:53 PM »
All LCDs plugged on the same power bar
All on
Switch the power bar off
All off
next time you switch the power bar on they all light up.
You may add an  FSUIPC fonction  to switch avionics on or off with a dedicated switch/button
Offline bernard S
« Reply #5 on: July 19, 2018, 09:39:52 PM »
seems my point lost.. the crts /lcds on aircraft to NOT come on all at once .. as respective power bus activates then they sequence
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #6 on: July 19, 2018, 09:56:30 PM »
Yes that is correct, and it is modeled by the avionics software (SimA for me)
Starting cold and dark with computers running
Battery bus fires only Capt side PFD/ND/CDU and engine DU with a delay (that you can set)
Then Ext power or APU on bus fire them all  in sequence etc etc
Hard to replicate with no software. ::)
« Last Edit: July 19, 2018, 10:02:26 PM by jackpilot »
Offline bernard S
« Reply #7 on: July 19, 2018, 10:08:29 PM »
eemm  okay so no aircraft power buses functional.in sim a (thats odd ) but then i dont have a 73..   could you not add say a resistor and timer ? to create this effect   justa a thought
Offline mickc
  • First Name: Mick
« Reply #8 on: July 19, 2018, 11:00:03 PM »
I think Jack might be talking about something else.
Most home setups I have seen have all the LCD screens on, but blank when they are "cold and dark"
I know nothing of Sim Avionics software, but with Prosim there are gates available to signal power availability on the different buses.
In my setup, cold and dark is actually cold and dark so nothing is powered, and I have the gates above trigger relays to physically turn on the appropriate screens when bus power is available.
Makes it quite scary when you lose AC power and half your panel goes black!
I'm also using these gates for the emergency standby lighting, where key panels and gauges are backlit with no AC power available, and at a fixed brightness etc, just like the real system.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #9 on: July 20, 2018, 08:06:44 AM »
I think we are talking about the same thing with different words ! lol
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
Great US switch supplier
by Bob Reed
[March 20, 2019, 09:21:11 PM]
by bernard S
[March 20, 2019, 08:32:53 PM]
Great video on a Caravelle project
by Lomaric
[March 20, 2019, 06:10:00 PM]
Holy Grail ?
by bernard S
[March 20, 2019, 06:05:06 PM]
Flight Scoring Platforms....
by RayS
[March 20, 2019, 04:53:05 PM]
Join me on Vatsim Tonight
by Trevor Hale
[March 20, 2019, 09:08:36 AM]
737 MAX
by FredK
[March 19, 2019, 11:07:27 PM]
Sim Speaker System in a small package...
by sagrada737
[March 19, 2019, 01:32:30 PM]
Prosim and RSP TQ interfacing
by jfuenmayor
[March 18, 2019, 02:04:20 PM]
OEM 737 classic liners for sale
by Gallie
[March 18, 2019, 09:54:39 AM]
B737-200 throttle quadrant for sale
by Gallie
[March 18, 2019, 08:56:25 AM]
by 757Simulator
[March 18, 2019, 04:20:49 AM]
JetMax TQ for Sale...
by sagrada737
[March 16, 2019, 02:57:19 PM]
Revolution Simproducts V2.0 Plug & Play Throttle help
by jfuenmayor
[March 14, 2019, 10:13:05 PM]
Attention All Members and Guests
by Trevor Hale
[March 13, 2019, 06:25:07 PM]
Creality CR-10S 3d printer.
by sagrada737
[March 12, 2019, 07:57:11 PM]
CPFlight EFIS737Pro2
by Lomaric
[March 11, 2019, 05:18:20 PM]
Homebuilt seats and a question
by Trevor Hale
[March 11, 2019, 01:32:17 PM]
777 Throttle - sold
by mattking247
[March 10, 2019, 07:13:29 PM]
General Aiation FLIGHT GEAR, For sale
by fairchild
[March 10, 2019, 05:17:41 PM]
I HAD an idea for an inexpensive B737 cockpit - Not so inexpensive now!
by bernard S
[March 10, 2019, 01:03:02 PM]
B737 Heads Up Guidance Systems (HUD)
by navymustang
[March 10, 2019, 12:48:09 PM]
JetMax components for sale - ALL SOLD
by 737SimGuy
[March 08, 2019, 02:41:41 PM]
Open Cockpits P&P MCP/EFIS/FMC for Sale - NEW in USA
by Fabian
[March 07, 2019, 12:21:17 AM]
CPFLIGHT GEAR FOR SALE
by ivanroberts77
[March 06, 2019, 10:46:27 AM]
OEM AFDS Module 737-NG
by Reensel
[March 05, 2019, 03:59:47 PM]
737 Demonstrator For Sale
by mattford1
[March 05, 2019, 03:16:30 PM]
Wanted: FDS 737NG Nav Radio (USB)
by 737NG-Ed
[March 05, 2019, 06:34:07 AM]
Scott (and Rob's...) Chicago 737-300 Build
by Trevor Hale
[March 04, 2019, 08:47:45 AM]
Fly Elise
by jskibo
[March 03, 2019, 11:36:17 AM]
