  • *Users: 2
  • *Guests: 8
  • *Total: 10
Author Topic: trouble with monitor! Keystone?  (Read 634 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« on: July 20, 2018, 08:39:10 AM »
After mounting my monitor in the MIP i fired up X-plane and was dissapointed because when my head is above the monitor the image fades away fast! I have to look at the monitors center position for best image.
How do you resolve this problem?
What settings should i try to put on the monitor?
« Last Edit: July 20, 2018, 08:39:48 AM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
Re: trouble with monitor! Keystone?
« Reply #1 on: July 20, 2018, 09:48:55 AM »
Looks like the monitor can handle it if i pit my head lower the screen but not ovwr it. I have flipped it so i guess the monitor cant be flipped....
Offline Joe Lavery
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #2 on: July 20, 2018, 10:25:40 AM »
Hi Peter,
All monitors have a field of view angle, and some are much wider than others. However verey few can be flipped because they are designed to be viewed from the front at almost eye level. Once you go beyond this field of view the picture fades very quickly, as you have found out.
There are monitors out there designed with a much wider field of view but they tend to be very expensive. You only have to stand to the side of any monitor and you will soon see what the viewing angle is.
I don't beleive there is any internal settings that will change this field of view, it's limited by the way the screen was manufactured. Although in general higher resolution screens tend to have a wider field of view.
www.pcpilot.net
Offline navymustang
  • Simulation Engineer
  • Forum GURU
  • First Name: Jim
  • Home Location: KMCO
« Reply #3 on: July 20, 2018, 04:33:07 PM »
You are correct, there are no settings to make this change. It is the mechanical characteristics of the screen itself. The only solution is purchasing an LCD that has the wider horizontal field of view. Who ever said this hobby was cheap?   :)
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #4 on: July 20, 2018, 07:43:54 PM »
I actually have this issue, but have solved it by rotating the monitors accordingly.  most monitors can be viewed from left or right, and top down, but not bottom up.  Sometimes flipping the monitor one way will make it good for the captain to see it but crappy for the first officer to see it.
I believe this was mentioned briefly when you went to order your monitors either way its a crappy situation for you.  Most of the time manufacturers will specify 160 degrees FOV or 180 degrees FOV, but its not always the case.
Offline kurt-olsson
  • First Name: Peter
« Reply #5 on: July 21, 2018, 02:55:11 AM »
It appears that its ok to look from above down but not down up as you say Trevor. The problem is that i will have to redo the mounting and if i have the monitor the right way the cables connector is in the way for my MIP, but its just to find something clever to tackle this problem...
Offline kurt-olsson
  • First Name: Peter
« Reply #6 on: July 21, 2018, 04:34:29 AM »
BINGO
just turning it back upside down made the fading go away. You can have your head as high as you want how close as you want but you can not have it LOWER than the monitor, then it fades out directly.
Pheeew... so nice to see a clear PFD! =)
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
Wanted: 737 CDU
by Fabian
[Today at 07:07:59 PM]
Flight Scoring Platforms....
by bernard S
[Today at 05:55:18 PM]
SALE! Airbus A320 trainer, located near Gatwick UK
by nic
[March 21, 2019, 09:35:58 PM]
Help with wiring up FDS map light
by Skysurfer170
[March 21, 2019, 02:36:03 PM]
by navymustang
[March 21, 2019, 09:38:45 AM]
by blueskydriver
[March 21, 2019, 07:42:41 AM]
Great US switch supplier
by Bob Reed
[March 20, 2019, 09:21:11 PM]
Great video on a Caravelle project
by Lomaric
[March 20, 2019, 06:10:00 PM]
Holy Grail ?
by bernard S
[March 20, 2019, 06:05:06 PM]
Join me on Vatsim Tonight
by Trevor Hale
[March 20, 2019, 09:08:36 AM]
737 MAX
by FredK
[March 19, 2019, 11:07:27 PM]
Sim Speaker System in a small package...
by sagrada737
[March 19, 2019, 01:32:30 PM]
Prosim and RSP TQ interfacing
by jfuenmayor
[March 18, 2019, 02:04:20 PM]
OEM 737 classic liners for sale
by Gallie
[March 18, 2019, 09:54:39 AM]
B737-200 throttle quadrant for sale
by Gallie
[March 18, 2019, 08:56:25 AM]
by 757Simulator
[March 18, 2019, 04:20:49 AM]
JetMax TQ for Sale...
by sagrada737
[March 16, 2019, 02:57:19 PM]
Revolution Simproducts V2.0 Plug & Play Throttle help
by jfuenmayor
[March 14, 2019, 10:13:05 PM]
Attention All Members and Guests
by Trevor Hale
[March 13, 2019, 06:25:07 PM]
Creality CR-10S 3d printer.
by sagrada737
[March 12, 2019, 07:57:11 PM]
CPFlight EFIS737Pro2
by Lomaric
[March 11, 2019, 05:18:20 PM]
Homebuilt seats and a question
by Trevor Hale
[March 11, 2019, 01:32:17 PM]
777 Throttle - sold
by mattking247
[March 10, 2019, 07:13:29 PM]
General Aiation FLIGHT GEAR, For sale
by fairchild
[March 10, 2019, 05:17:41 PM]
I HAD an idea for an inexpensive B737 cockpit - Not so inexpensive now!
by bernard S
[March 10, 2019, 01:03:02 PM]
B737 Heads Up Guidance Systems (HUD)
by navymustang
[March 10, 2019, 12:48:09 PM]
JetMax components for sale - ALL SOLD
by 737SimGuy
[March 08, 2019, 02:41:41 PM]
Open Cockpits P&P MCP/EFIS/FMC for Sale - NEW in USA
by Fabian
[March 07, 2019, 12:21:17 AM]
CPFLIGHT GEAR FOR SALE
by ivanroberts77
[March 06, 2019, 10:46:27 AM]
OEM AFDS Module 737-NG
by Reensel
[March 05, 2019, 03:59:47 PM]
