  • *Users: 0
  • *Guests: 21
  • *Total: 21
Author Topic: My project, 737 in the basement.  (Read 1241 times)
Offline Goteborg
  • CockpitBuilder
  • Aviation Enthusiast
  • First Name: Jimmy
  • Home Location: Gothenburg
« on: August 05, 2018, 11:51:18 AM »
Hi, all cockpitbuilders.
I'm totally new to the forum and recently got a thumbs up from my wife
to start this project, thought that I could as well try to dock
parts of the object in a separate thread and may receive feedback from all the knowledge gathered here.
Is fully aware that it will take time, and it will not be completely free :)
The reason that the choice fell at 737 is that it is the plane I fly the most online, and that the range of parts and guides that touch the 737 is big.
Will try to build as many components as possible myself to keep the cost down. Right now i am keeping on clearing up a surface in the basement that will be my cockpit, so I can start by building MIP furniture and have started with a first component Gear Leaver.
I have access to a sheet metal shop, so much of the projects in the future will be manufactured there. Here are the parts of the first project.
assembly together
some wiring
the finished Product, and it works. Will add switch for locked position later on.
My programming skills are quite limited so I have a steep learning curve in front of me. But I have to start somewhere.
« Last Edit: August 05, 2018, 11:54:18 AM by Goteborg »
Offline kurt-olsson
  • First Name: Peter
Re: My project, 737 in the basement.
« Reply #1 on: August 05, 2018, 12:20:30 PM »
Snyggt jobbat!
Really nice work. Let me know if i can help with the programming. What platform will you use?
« Last Edit: August 05, 2018, 12:20:56 PM by kurt-olsson »
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #2 on: August 05, 2018, 01:03:21 PM »
Hey Jimmy,
Welcome to Cockpit Builders! Home of the best cockpit builders in the world!
You're starting off great and having access to a metal shop is a big bonus. Use the search box and look for CNC plans, you'll find just about everything for the B737, and if not, just ask in a post.
Please post often and provide lots of pics, that is the best way to get help, as well as help others. Good karma goes far on this website and you'll get lots of it, as the members here are a great group of people that will do whatever they can too help each other...
Kind Regards,
Offline Goteborg
  • CockpitBuilder
  • First Name: Jimmy
« Reply #3 on: August 06, 2018, 11:11:29 AM »
Snyggt jobbat!
Tack!
Thank you, do not say what you will regret when you wake up a day with 450 questions in your inbox  ;D
I am currently looking at and considering which path to choose.
Today I'm flying with FSX-SE, but I will not start a project like this around FSX, so the choice is between P3D and XP11.
What feels best for the moment is P3Dv4, ProSim and OpenCockpits IOCards. However, I have to investigate more before placing an order.
Inputs in this topic is more than welcome.
« Last Edit: August 06, 2018, 11:22:58 AM by Goteborg »
Offline Goteborg
  • CockpitBuilder
  • First Name: Jimmy
« Reply #4 on: August 06, 2018, 11:15:49 AM »
Hey Jimmy,
Kind Regards,
Thank you, and agree.
Have spent many hours reading this forum before joining. Extremely nice cockpits and the knowledge gathered here are superior.
Should try to keep the camera near as soon as there is something worth taking on. :)
« Last Edit: August 06, 2018, 11:25:31 AM by Goteborg »
Offline Goteborg
  • CockpitBuilder
  • First Name: Jimmy
« Reply #5 on: August 13, 2018, 06:01:37 AM »
So now it begins, I've used Peter's (buildaboeing.com) dimensions that can be found here.
https://buildaboeing.com/2013/04/15/mip-panel/
Builds the structure of the 12mm MDF and MIP panel in 6mm MDF. Choose to do this in wood for simplicity. Also ordered the BOEING 737 MIP PANEL KIT from Flightimulatorparts.com so now I await some supplies of buttons and switches, while I wait, I'm looking for monitors that match and paint.
« Last Edit: August 13, 2018, 12:44:53 PM by Goteborg »
Offline Goteborg
  • CockpitBuilder
  • First Name: Jimmy
« Reply #6 on: September 09, 2018, 11:32:47 AM »
It progresses slowly, color on. Will paint again once all visible components and screens are installed. Counting on some bad luck here and there before everything is in place. :/
Installed computer, some old saitek gadgets to fly throughout the construction time.
My plan is to build one component at a time, install it and thus get a more realistic simulator bit by bit.
The parts from Flightimulatorparts have arrived, are very pleased with the quality. More gadgets, buttons cables come by mail more or less daily so I hope soon I have everything to start the soldering machine.
Determined to buy P3Dv4, I do not know yet if Prosim is the right way to go. So for now, I will use arduino and mobiflight to get started. Simple and cheap solutions.
Offline jmlohrenz
  • Forum GURU
  • First Name: Jason
  • Home Location: MN, USA
« Reply #7 on: September 20, 2018, 09:06:22 AM »
Prosim is a Cadillac, if you cant afford it there are other options. I'm using iflys 737. They have a cockpit builders edition which is about half the cost. Most things are simulated and thus far I haven't run into any problems..just not all the bells and whistles as prosim, and you are much more dependent on fsuipc offsets for everything. I'm using a combination of mobiflight and FDS interface cards and software to make it work.
Jason
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #8 on: September 21, 2018, 05:48:19 AM »
Nice bit of Behringer audio gear in the MIP i see!
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
New supplier for your sim
by Fcoq
[Today at 01:44:54 AM]
Join me on Vatsim Tonight
by Trevor Hale
[February 20, 2019, 06:16:29 PM]
Operating System Blues
by FredK
[February 20, 2019, 11:10:59 AM]
For Sale: Jetmax 737 TQ - Texas, USA
by MistyBlue
[February 19, 2019, 02:19:22 PM]
by MistyBlue
[February 19, 2019, 02:17:28 PM]
FSUIPC 5 Button Limitations
by GyverX
[February 18, 2019, 05:33:55 PM]
Virtual FO software
by fsaviator
[February 18, 2019, 02:36:20 PM]
Throttle
by 727737Nut
[February 17, 2019, 09:14:54 AM]
737 NG Throttle Levers
by mickc
[February 17, 2019, 05:02:01 AM]
For sale: A set of faceplate panel for pedestal
by mickc
[February 17, 2019, 05:01:07 AM]
FlyAB Simparts: A new supplier for your OEM needs
by Trevor Hale
[February 16, 2019, 10:51:54 PM]
B737-800 Flight Sim for sale $85,000.00
by Rob_b
[February 16, 2019, 12:47:11 AM]
by iwik
[February 15, 2019, 06:47:11 PM]
by Joe Lavery
[February 15, 2019, 05:39:06 PM]
Anyone seen OEM 737-900 ER Throttle Quadrant?
by Fly_AB
[February 15, 2019, 10:32:18 AM]
For Sale: P&P Opencockpit VHF, Transponder, and ADF
by Fly_AB
[February 15, 2019, 09:08:24 AM]
737 DIY MIP For Sale
by Trevor Hale
[February 14, 2019, 11:03:35 AM]
For Sale Prosim 737 v2.03 License
by mdavenport
[February 12, 2019, 04:00:00 PM]
by navymustang
[February 10, 2019, 12:50:48 PM]
[February 10, 2019, 09:31:17 AM]
Revolution Simproducts out of business?
by fsaviator
[February 09, 2019, 12:18:30 PM]
For sale: CPFlight MIP737SE
by Fly_AB
[February 08, 2019, 11:29:26 PM]
For sale: Engravity sixpack pairs --- SOLD
by Fly_AB
[February 08, 2019, 08:32:04 PM]
by MjTom
[February 08, 2019, 08:00:54 AM]
by Trevor Hale
[February 08, 2019, 07:41:50 AM]
737 Demonstrator For Sale
by Trevor Hale
[February 08, 2019, 07:39:34 AM]
Looking for B737NG or A320 SIM for Home Use
by KingAviation
[February 08, 2019, 03:17:35 AM]
Zibo 737 FlightControl Dataref/Commands
[February 05, 2019, 05:34:35 PM]
by FredK
[February 05, 2019, 12:58:20 AM]
Flight Control Panel A Side
[February 04, 2019, 04:34:38 PM]
