  • *Users: 3
  • *Guests: 12
  • *Total: 15
Author Topic: My project, 737 in the basement.  (Read 1580 times)
Offline Goteborg
  • CockpitBuilder
  • Aviation Enthusiast
  • First Name: Jimmy
  • Home Location: Gothenburg
« on: August 05, 2018, 11:51:18 AM »
Hi, all cockpitbuilders.
I'm totally new to the forum and recently got a thumbs up from my wife
to start this project, thought that I could as well try to dock
parts of the object in a separate thread and may receive feedback from all the knowledge gathered here.
Is fully aware that it will take time, and it will not be completely free :)
The reason that the choice fell at 737 is that it is the plane I fly the most online, and that the range of parts and guides that touch the 737 is big.
Will try to build as many components as possible myself to keep the cost down. Right now i am keeping on clearing up a surface in the basement that will be my cockpit, so I can start by building MIP furniture and have started with a first component Gear Leaver.
I have access to a sheet metal shop, so much of the projects in the future will be manufactured there. Here are the parts of the first project.
assembly together
some wiring
the finished Product, and it works. Will add switch for locked position later on.
My programming skills are quite limited so I have a steep learning curve in front of me. But I have to start somewhere.
« Last Edit: August 05, 2018, 11:54:18 AM by Goteborg »
Offline kurt-olsson
  • First Name: Peter
Re: My project, 737 in the basement.
« Reply #1 on: August 05, 2018, 12:20:30 PM »
Snyggt jobbat!
Really nice work. Let me know if i can help with the programming. What platform will you use?
« Last Edit: August 05, 2018, 12:20:56 PM by kurt-olsson »
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #2 on: August 05, 2018, 01:03:21 PM »
Hey Jimmy,
Welcome to Cockpit Builders! Home of the best cockpit builders in the world!
You're starting off great and having access to a metal shop is a big bonus. Use the search box and look for CNC plans, you'll find just about everything for the B737, and if not, just ask in a post.
Please post often and provide lots of pics, that is the best way to get help, as well as help others. Good karma goes far on this website and you'll get lots of it, as the members here are a great group of people that will do whatever they can too help each other...
Kind Regards,
Offline Goteborg
  • CockpitBuilder
  • First Name: Jimmy
« Reply #3 on: August 06, 2018, 11:11:29 AM »
Snyggt jobbat!
Tack!
Thank you, do not say what you will regret when you wake up a day with 450 questions in your inbox  ;D
I am currently looking at and considering which path to choose.
Today I'm flying with FSX-SE, but I will not start a project like this around FSX, so the choice is between P3D and XP11.
What feels best for the moment is P3Dv4, ProSim and OpenCockpits IOCards. However, I have to investigate more before placing an order.
Inputs in this topic is more than welcome.
« Last Edit: August 06, 2018, 11:22:58 AM by Goteborg »
Offline Goteborg
  • CockpitBuilder
  • First Name: Jimmy
« Reply #4 on: August 06, 2018, 11:15:49 AM »
Hey Jimmy,
Kind Regards,
Thank you, and agree.
Have spent many hours reading this forum before joining. Extremely nice cockpits and the knowledge gathered here are superior.
Should try to keep the camera near as soon as there is something worth taking on. :)
« Last Edit: August 06, 2018, 11:25:31 AM by Goteborg »
Offline Goteborg
  • CockpitBuilder
  • First Name: Jimmy
« Reply #5 on: August 13, 2018, 06:01:37 AM »
So now it begins, I've used Peter's (buildaboeing.com) dimensions that can be found here.
https://buildaboeing.com/2013/04/15/mip-panel/
Builds the structure of the 12mm MDF and MIP panel in 6mm MDF. Choose to do this in wood for simplicity. Also ordered the BOEING 737 MIP PANEL KIT from Flightimulatorparts.com so now I await some supplies of buttons and switches, while I wait, I'm looking for monitors that match and paint.
« Last Edit: August 13, 2018, 12:44:53 PM by Goteborg »
Offline Goteborg
  • CockpitBuilder
  • First Name: Jimmy
« Reply #6 on: September 09, 2018, 11:32:47 AM »
It progresses slowly, color on. Will paint again once all visible components and screens are installed. Counting on some bad luck here and there before everything is in place. :/
Installed computer, some old saitek gadgets to fly throughout the construction time.
My plan is to build one component at a time, install it and thus get a more realistic simulator bit by bit.
The parts from Flightimulatorparts have arrived, are very pleased with the quality. More gadgets, buttons cables come by mail more or less daily so I hope soon I have everything to start the soldering machine.
Determined to buy P3Dv4, I do not know yet if Prosim is the right way to go. So for now, I will use arduino and mobiflight to get started. Simple and cheap solutions.
Offline jmlohrenz
  • Forum GURU
  • First Name: Jason
  • Home Location: MN, USA
« Reply #7 on: September 20, 2018, 09:06:22 AM »
Prosim is a Cadillac, if you cant afford it there are other options. I'm using iflys 737. They have a cockpit builders edition which is about half the cost. Most things are simulated and thus far I haven't run into any problems..just not all the bells and whistles as prosim, and you are much more dependent on fsuipc offsets for everything. I'm using a combination of mobiflight and FDS interface cards and software to make it work.
Jason
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #8 on: September 21, 2018, 05:48:19 AM »
Nice bit of Behringer audio gear in the MIP i see!
Offline Goteborg
  • CockpitBuilder
  • First Name: Jimmy
« Reply #9 on: April 03, 2019, 09:48:41 AM »
Jason
Hello, late replay but hey kinda forgot about this forum when i joined the cockpitbuilders-discord.
Anyway, i was a few seconds to go for iFly CBE, i got into the forum and started to sort out some questions about programming it, (i already purchused the iFly model) but the support was not satisfying and Trevor on discord kinda pushed me over to prosim so....
There we go, the forum support is absolutley lovley, but i am just going to.. pretend that prosim did not rob me, jeez that was a heavy charge for a pice of non hardware.  :/
« Last Edit: April 03, 2019, 09:49:29 AM by Goteborg »
Offline Goteborg
  • CockpitBuilder
  • First Name: Jimmy
« Reply #10 on: April 03, 2019, 09:52:27 AM »
Yeah, now it is not plugged in anymore but its a peice of equipment leftover from a radiostation i started a couple of years ago, i had to use it to make my microphone to sound somewhat reasonable on vatsim. Now i have a new headset so its out of the picture again.
Maybe i use it later on for handheld microphones or something. who knows :D
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #11 on: April 03, 2019, 02:24:21 PM »
LOL Jimmy,
I am not affiliated with PROSIM-AR at all,  But I believe you made the right choice for your situation.  This way you never go back to the "What IF" and one day if you decide you don't want it....  I am sure there is someone that will gladly take it off your hands (For a small loss of course)
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
Overhead: Where to mount interface cards?
by helloo
[April 25, 2019, 11:46:07 PM]
Where to buy/what size is this connector?
by helloo
[April 25, 2019, 11:44:19 PM]
[April 25, 2019, 04:43:15 PM]
by jskibo
[April 25, 2019, 02:25:50 PM]
by blueskydriver
[April 24, 2019, 03:30:03 PM]
unfinished project 737
by LORENZO
[April 23, 2019, 06:29:47 PM]
747-400 Yoke Color
by bernard S
[April 23, 2019, 04:39:55 PM]
737 MAX Sismo soluciones (SPAIN)
by kkoutoulas
[April 23, 2019, 02:53:50 PM]
TV Screen Position
by iwik
[April 22, 2019, 07:53:38 PM]
Question on B737NG center pedestal instrument availability
by navymustang
[April 22, 2019, 05:05:09 PM]
Wanted - Jetmax B737 TQ
by kattz
[April 22, 2019, 12:57:09 AM]
Multi-Projector color calibration
by jmlohrenz
[April 21, 2019, 05:33:40 PM]
Bernard...info
by FredK
[April 20, 2019, 06:29:17 PM]
by fsaviator
[April 20, 2019, 04:25:12 PM]
by blueskydriver
[April 20, 2019, 11:26:43 AM]
Old Projector(s)
by fsaviator
[April 20, 2019, 10:53:59 AM]
by Karl737
[April 19, 2019, 09:56:23 PM]
by patiju
[April 19, 2019, 06:14:33 PM]
by Steenos
[April 19, 2019, 03:22:12 PM]
by Joe Lavery
[April 19, 2019, 04:59:21 AM]
Teensy LC Throttle Quadrant
by RayS
[April 18, 2019, 03:38:14 PM]
by navymustang
[April 18, 2019, 08:25:11 AM]
by 757Simulator
[April 18, 2019, 04:20:53 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
