  • *Users: 1
  • *Guests: 45
  • *Total: 46
Author Topic: P3D v4 Multichannel, still an expert request for an optimal setting  (Read 798 times)
Offline sisoffi
  • CockpitBuilder
  • Aviation Enthusiast
  • First Name: Simone
  • Home Location: Venice
hello, I still open a post on the multichannel so that someone can really indicate a solution.
It is unthinkable to have to invest thousands of dollars for a system where so few sterile indications in the learning center are such that they can not afford to continue with a system that is free from stuttering.
I have done research in months and I wrote also post about it to find solutions but to date, there is not yet a system that allows you to fly and not have problems of stuttering on the visuals of the clients.
First of all:
1. minimum system requirements for a multichannel network.
In a domestic system, current computers allow performance. I last i7 or Ryzen generation CPU with 8 and more GB graphics cards such that even in medium-high setup conditions the system should run really well. Let's leave out the Lan network that has been tested and no problems and the Windows10 64bit operating systems are minimal and well optimized. In the learning center is well indicated that:
"For best performance, the client machines should be used to synchronize the frame of the display with the appropriate display. may fall out-of-sync with another display adjoining This is especially probable more than another client renderer a series of the same work. the frame flip may be delayed If hardware synchronization is not possible ng noticeably out of sync. CPU bound, or to limit the frame rate of the Host to provide enough time for all clients to finish GPU work. "
Browsing in other posts, investigating the genlock cards, however, this answer, to my own doubt:
"If the multichannel system is configured for network synch, the host should wait to start the next frame until all slaves are done with the current frame. In this case, channels should never be more than 1 frame off from each other, but each screen will still refresh as soon as that system is done rendering its frame. Gen-lock would help guarantee that all monitors flip the frame buffer at the same time. That would reduce visual tearing but would not reduce stutters. If your systems are prone to occasional stutters with a single channel, the problem will be worse as you add channels because every time anyone channel stutters, they will all stutter together. If your system is going to be running significantly lower than your output's refresh rate and/or you plan to make rapid camera movements, gen-lock would be preferable."
and here my first doubt is not knowing whether to invest in unconventional video cards such as GeForce or AMD, but I should adopt GPU genlock Quadro or ATI pro. Which model suggests? need a very boost Quadro or ATI pro card?
(There is no video comparison from Prepar3D for a hypothetical example of Multichannel setup with also Hardware used?)
2. FPS Syncronization
I tried all kinds of experiments: first with normal monitors, then fullHD and now with 4k TV, which by the way, I lowered the hertz to 30 that would be the perfect thing for every client PC blocking and always keeping 30fps in vysnc and TB ON I would have perfect fluidity. perfect!
The speech falls if the host that hosts my panels for avionics and only one external view in minimal settings and fps unlimited with no vsync with monitors are at 60hertz.
The conclusion that all the system's visuals are at the same update frequency either at 30Hz or 60Hz (but even in this case with normal systems and not with genlock cards I have not yet found the perfect smooth).
The Network.cfg from host there is : FrameSyncRate=30 that I saw is the only thing that can be changed on these files. If I try to put the fps sync to 0 the systems are not synchronized. I noted momentary low fps to 15 on clients (half from 30) while host running in unlimited frames.
3. AllowSharedAircraft=1
What is the purpoe of this line? shared for why? to show the effects on clients like landing lights?
in my case I have enabled and installed the same payware plane for both clients in such a way as to have the landing lights effect as well. The problem to share aircraft is if I open gauges and panels from cockpits the same info will send to clients and have the gauge or panel open on clients :(
4. Purpose of the multichannel
Is it really necessary to use a multichannel system with a host PC with minimal settings where it could be used as an external view? in home cockpits, usually programs such as prosim or magenta project turn the avionics into a client without having another prepar3D in use at minimum settings.
What would then be the optimal choice for having an ideal multichannel setup?
many thank
Simone
Offline FredK
  • I may as well be Staff!
  • 737NG Cockpit Builder
Re: P3D v4 Multichannel, still an expert request for an optimal setting
« Reply #1 on: August 18, 2018, 09:49:29 PM »
Simone
Have you investigated using WideView and WideTraffic for multichannel?
It is easy to step up and works fine with P3D. Very smooth with great FPS and slider performance on the clients.
It is also inexpensive.
I do not use my WV server as a visual, although there is an option to do so.
Offline sisoffi
  • CockpitBuilder
« Reply #2 on: August 19, 2018, 03:32:55 AM »
thank you frank,
i went before from videview (obsolete) and after opus better in performance
but I want to leave out in order to have a unique system very well performed also with the great view group.
The advantage of multichannel is also the share aircraft with all traffic syncro and the effects like landing lights.
Many people i see leave wideview and opus for the multichanel purpose but for me remain a mystery the smooth.
Simone
Offline navymustang
  • Simulation Engineer
  • Forum GURU
  • First Name: Jim
  • Home Location: KMCO
« Reply #3 on: August 19, 2018, 09:00:05 AM »
Simone - you actually can have landing lights fully synched with WideView. It took me a year to figure it out with help from others on this forum. But it does work.
I also agree with you that it would be nice to use all the built in features of P3D without adding WideView and WideTraffic. Just wish I could get it to work.
Offline FredK
« Reply #4 on: August 19, 2018, 09:47:31 AM »
Regarding P3D "built-in" multi-channel......l
I have to admit that I have never tried it myself.....but....
Everyone that I know that has tried it claims that it does not work very well.  Also, I have several times posted in the P3D forum asking if there was anyone running it with good results...I have never received a reply, including from LM.  So my conclusion is that the built-in P3D multi-channel is not ready for prime time.
However my conclusion may be wrong....So in the spirit of this thread I post the question again here....Is anyone actually successfully using P3D multi-channel???
Quote
Simone - To be sure....There are limitations with shared aircraft effects using WV, but AI traffic does sync perfectly for me.
« Last Edit: August 19, 2018, 09:49:19 AM by FredK »
Offline navymustang
  • Forum GURU
  • First Name: Jim
« Reply #5 on: August 19, 2018, 12:53:51 PM »
Lockheed demonstrates it routinely at various trade shows for military sims. It always looks good. But they are the designers, they know the tricks.
Offline sisoffi
  • CockpitBuilder
« Reply #6 on: August 19, 2018, 05:00:47 PM »
thank you all for the valuable suggestions.
In fact not even lockheed martin seems to have clear ideas on the multichannel, not giving answers in their forum.
But what I do not understand videview, opu andmultichannel use simconnect, so I find it really strange that there is a difficulty in managing the multichannel.
The traffic among other things works really well in sync with the various PCs and it is not necessary to keep it activated in the clients (just have it in the database).
More than vide view it seems to me that OpusFSI, in addition to being always updated allows me to have more fluidity and allows me to set optimally the the camera views from server.
Offline sisoffi
  • CockpitBuilder
« Reply #7 on: August 21, 2018, 08:38:26 AM »
update 21 August 2018:
I tested a genlock video card (ati pro wx5100 8gb) on a client with only one test on a 4k TV.
Given that, from specifications:
https://www.amd.com/Documents/radeon-pro-wx5100-datasheet.pdf
 the card in question supports up to 4 displays in 5k:
"Drive up to two, 5K (5120x2880 pixel resolution) dual-cable displays @ 60 Hz, or one, single-cable 5K display @ 60 Hz"
first problem:
1. the TV does not go over 1080p at 60hz.
With a normal video card (gtx1070 or Rx580) I got in the two TV views 4k to 30hz. So my tv in uhd 4k scale to 30hz? the specifications of the card indicate:
does it take a particular cable? if the 4k to 60hz is supported, it should be logical to support even lower hertz rollouts, so a cable problem?
Test results:
with a genlock card in a client finally, the fluidity is almost total on ground and in flight. Made a quick test with a scenario like Palermo jetstream that is very light and well optimized, perfect!
But in a flight test Palermo to Rome, approaching Rome returns the stutter.
Ok, could it be a scenario? therefore implies the fact that every case all addons must be optimized?
Many thanks
Simone
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
New supplier for your sim
by fsaviator
[February 20, 2019, 07:59:04 PM]
Join me on Vatsim Tonight
by Trevor Hale
[February 20, 2019, 06:16:29 PM]
Operating System Blues
by FredK
[February 20, 2019, 11:10:59 AM]
For Sale: Jetmax 737 TQ - Texas, USA
by MistyBlue
[February 19, 2019, 02:19:22 PM]
by MistyBlue
[February 19, 2019, 02:17:28 PM]
FSUIPC 5 Button Limitations
by GyverX
[February 18, 2019, 05:33:55 PM]
Virtual FO software
by fsaviator
[February 18, 2019, 02:36:20 PM]
Throttle
by 727737Nut
[February 17, 2019, 09:14:54 AM]
737 NG Throttle Levers
by mickc
[February 17, 2019, 05:02:01 AM]
For sale: A set of faceplate panel for pedestal
by mickc
[February 17, 2019, 05:01:07 AM]
FlyAB Simparts: A new supplier for your OEM needs
by Trevor Hale
[February 16, 2019, 10:51:54 PM]
B737-800 Flight Sim for sale $85,000.00
by Rob_b
[February 16, 2019, 12:47:11 AM]
by iwik
[February 15, 2019, 06:47:11 PM]
by Joe Lavery
[February 15, 2019, 05:39:06 PM]
Anyone seen OEM 737-900 ER Throttle Quadrant?
by Fly_AB
[February 15, 2019, 10:32:18 AM]
For Sale: P&P Opencockpit VHF, Transponder, and ADF
by Fly_AB
[February 15, 2019, 09:08:24 AM]
737 DIY MIP For Sale
by Trevor Hale
[February 14, 2019, 11:03:35 AM]
For Sale Prosim 737 v2.03 License
by mdavenport
[February 12, 2019, 04:00:00 PM]
by navymustang
[February 10, 2019, 12:50:48 PM]
[February 10, 2019, 09:31:17 AM]
Revolution Simproducts out of business?
by fsaviator
[February 09, 2019, 12:18:30 PM]
For sale: CPFlight MIP737SE
by Fly_AB
[February 08, 2019, 11:29:26 PM]
For sale: Engravity sixpack pairs --- SOLD
by Fly_AB
[February 08, 2019, 08:32:04 PM]
by MjTom
[February 08, 2019, 08:00:54 AM]
by Trevor Hale
[February 08, 2019, 07:41:50 AM]
737 Demonstrator For Sale
by Trevor Hale
[February 08, 2019, 07:39:34 AM]
Looking for B737NG or A320 SIM for Home Use
by KingAviation
[February 08, 2019, 03:17:35 AM]
Zibo 737 FlightControl Dataref/Commands
[February 05, 2019, 05:34:35 PM]
by FredK
[February 05, 2019, 12:58:20 AM]
Flight Control Panel A Side
[February 04, 2019, 04:34:38 PM]
