  • *Users: 1
  • *Guests: 55
  • *Total: 56
WORLDFLIGHT 2019 - TEAM USA SUPPORTERS (HERO'S)
Worldflight 2019
Donations Starting Early
With 50 Days Left, it's time to start Counting Down to Worldflight 2019.  Beginning in August, we had 2 kind gentleman lead the way on our quest for donations to this amazing Charity Event.  Over the Past 6 Years, we (This community) Has helped to raise over $25,000.00USD to help the kids and their families of the All Children's Hospital in St. Petersburgh, Florida.  Kicking off the donations this year these Two Hero's are leading the way to another Successful Year.  I personally want to thank these two Gentleman and use this opportunity to have all of you donate to our wonderful cause.
Thank you in advance for your help and please wish us much success for our 2019 event.
  ---Worldflight 2019 HEROS---
 James Williams, Warren Soeldner,  Sam Llorca, Doug Snow, Ryan O'Keefe, Edwin Burton
Thanks to all of you, You are all helping to make Worldflight 2019 a success..
Because of all you wonderful people so far we have raised a total of:
$1245.00 USD
Instructor Station by:Luis Gordo
ISLOGO
What is Instructor Station ?
In flight simulation, an Instructor Operator Station (IOS) is designed to assist the instructor in controlling the simulation training environment and monitoring all aspects of pilot/crew performance in the simulator. The instructor can control, via this software, all functions such as aircraft position and systems, meteorological, environmental, and situational parameters.
The Instructor Station is meant to assist Aviation Professionals, Flight Simulation Enthusiasts and Home Cockpit Builders using Microsoft® Flight Simulator (FS) 2004™, FSX™ and ESP™, Lockheed Martin Prepar3D® and X-Plane®.
The Instructor Station allows setting the aircraft on an approach to a runway of choice under any weather conditions, start-up and shutdown network computers (fully customizable), program or set aircraft system failures at any moment, calculate the amount of fuel required for a flight and load it to the aircraft, record flight performance (approaches, manoeuvres, landings, take-offs, etc.) and plot it graphically, and many other things!
Compatible with all types of aircraft! It is also a great tool for anybody who wants to control the flight simulator externally.
Many features are also available for Project Magenta users (pmSystems, Glass Cockpit, CDU/MCDU, MCP/FCU), AST & FMGS JeeHell users.
Developed by a pilot, engineer & flight simulation enthusiast.
TRY THE DEMO AND ORDER YOUR LICENSE TODAY !!
Author Topic: AYUDAAAA!!!!! CON WIDECLIENT  (Read 874 times)
Offline a320kH
  • CockpitBuilder
  • Aviation Enthusiast
  • First Name: alex
  • Home Location: santiago de chile
« on: August 19, 2018, 04:04:37 PM »
Hola Chicos, soy nuevo y este es mi segundo post, les cuento que estoy fabricando una cabina A320 en base a Jeehell A320 FMGS, y el espectacular IStation de Luis Gordo, el tema es que en el PC donde tengo FSX cuando esta cargado y listo dice: WideServer: waiting for clients  y en el NOTE tengo WIDECLIENT, cuando activo el WideClient me dice connect, pero a los pocos segundos tanto el pc de FSX como el Widclient dice : waiting for clients   connect, waiting for clients   connect y el IStation no me conecta al PC de mas menos FSX.  Ya revise las conexiones de red los FIREWALL y estan desactivados, tambien lo conecte via RJ45 y nada..... ma pueden ayudar si alguien sabe mas menos del tema por favorrrrrrr  :huh: :'(
« Last Edit: August 19, 2018, 04:06:49 PM by a320kH »
Offline FredK
  • I may as well be Staff!
  • 737NG Cockpit Builder
Re: AYUDAAAA!!!!! CON WIDECLIENT
« Reply #1 on: August 19, 2018, 04:41:22 PM »
I do not understand Spanish...but try this....
Make sure that you have the Server IP address entered in the WideClient ini file.
If that line is not there,  simply enter the line per the instruction manual.
Offline luisgordo
  • Moderator
  • Forum GURU
    • Instructor Station
  • First Name: Luis Gordo
« Reply #2 on: August 27, 2018, 01:54:32 PM »
Alex,
I believe we solved this via email.  If not, please advise.
Luis
Offline a320kH
  • CockpitBuilder
  • First Name: alex
« Reply #3 on: August 30, 2018, 08:09:48 PM »
Hola Luis, te envie el correo el cual hablamos, pero aun no me respondes, si lo puedes  revisar por favor gracias
Offline a320kH
  • CockpitBuilder
  • First Name: alex
« Reply #4 on: August 30, 2018, 08:25:38 PM »
Offline luisgordo
  • Moderator
  • Forum GURU
« Reply #5 on: September 07, 2018, 09:47:01 AM »
Alex,
I believe this is solved.  If not, please advise.
Luis
COUNTDOWN TO WF2019
by Vincent T.
[September 14, 2019, 03:08:00 PM]
WORLDFLIGHT 2019 - FLIGHT BIDS
by Vincent T.
[September 14, 2019, 03:00:40 PM]
WORLDFLIGHT 2019 - AVAILABILITY
by Trevor Hale
[September 14, 2019, 07:25:32 AM]
WORLDFLIGHT 2019 - Employer matching for Donations...
by RayS
[September 14, 2019, 12:03:45 AM]
SimFest-West 2019 Videos
by RayS
[September 13, 2019, 07:27:16 PM]
737 MAX Build
by helloo
[September 13, 2019, 04:41:17 PM]
A little pucker factor here, I'm sure... nerves of steel
by RayS
[September 12, 2019, 06:30:45 PM]
727/737 yokes
by Caflyt
[September 12, 2019, 10:26:12 AM]
Which size fuses to use in fuse block supplying FDS boards?
by blueskydriver
[September 11, 2019, 05:56:37 PM]
I finally got the shell pulled off the ATC-810...
by geneb
[September 11, 2019, 07:29:51 AM]
Wanted: Optoma GT1080Darbee Short Throw Projector
by Flightdeck57
[September 11, 2019, 12:24:08 AM]
F16 Simulator For Sale
by blueskydriver
[September 06, 2019, 03:52:34 PM]
Ebay Assistance
by iwik
[September 06, 2019, 02:00:00 PM]
Matrox 3
by jackpilot
[September 05, 2019, 10:45:00 AM]
So I got a big crate the other day...
by geneb
[September 05, 2019, 09:20:22 AM]
Official WF 2019 Route
by fsaviator
[September 05, 2019, 08:20:10 AM]
Are some sellers off their trolly
[September 02, 2019, 12:39:54 PM]
Display Glare FDS w/Pic
by Joe Lavery
[September 01, 2019, 02:33:47 AM]
MCP
by Caflyt
[August 27, 2019, 06:57:41 PM]
Dispatch and Career Add-on
by fsaviator
[August 26, 2019, 10:42:45 AM]
by B763
[August 25, 2019, 04:58:46 PM]
Free Jet Ranger.
by geneb
items/oem from overhead
by gufau
Hi everyone!
by jskibo
Shipping Woes
by Caflyt
by Trevor Hale
More ?'s - annunciators?
by kattz
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
