Cockpit
* User Profile
Welcome, Guest. Please login or register.
Who's Online
  • *Users: 3
  • *Guests: 49
  • *Total: 52
Our Discord
Author Topic: Calibration Pro Eyepoint-setting/Eyepoint position  (Read 438 times)
Offline bravolima
  • Forum GURU
  • B 737 Homecockpit-Pilot
  • First Name: Bernhard
  • Home Location: LSZH
« on: September 07, 2018, 01:29:32 PM »
Hello,
I recently optimized my Visual with the new Version 3.04 of Calibration Pro from Fly Elise. (390 cm Diameter, 3 BenQ Beamer with overcross Setting). The result is very good so far, the warping seems to be distinctive improved in comparison with my older Version 3.1 and I am very happy with it.
One thing remains:
when coming closer to the runways, I have the impression I am a little bit to high. Even in fully automated approaches this impression remains even though the VASI looks right. Two weeks ago I had a jump on a Airbus 320. Remembering  the visual Impression from that experience - I was concentrated on that -  I will ask you should I  and how to improve my setting.
The data:
Eye Position: 140 cm
Horizon on the projection wall: 140 cm
Hight of the projection: 155 cm
projection above the horizon line 65 cm
projection below the horizon line 90 cm
The projection was done with crosshair-laser and several automap steps. Columns were adjusted with crosshair-lasers too. With crosshair-laser the horizonal lines were only leveled slightly over the three projections.
Shall I vary eypoint-setting? For instance 15-20 cm lower? Does it have optical-geometric effect at all or do I have to accept the result as it is?
Bernhard (LSZH)
« Last Edit: September 07, 2018, 01:30:14 PM by bravolima »
PREPAR3D v4.2 FDS MIP, CDUs, Clocks, Shell, Liners,Tiller; FLIGHTILLUSION Brake-pressure, jaw-damper CPFlight: Overheads, Pedestal; MCP EFIS, OPENCOCKPIT Pedals; FCS: linked Yokes (modified); Weber-Seats on RAIL, ProSim B737 & Project Magenta with TSR, Aivalsoft EFB Version 2, Navigraph, FSC, BenQ1080 3 Beamer-Visual
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • Building a 737-800 full scale cockpit
  • First Name: Jim
  • Home Location: KMCO
Re: Calibration Pro Eyepoint-setting/Eyepoint position
« Reply #1 on: September 07, 2018, 05:24:38 PM »
Are you referring to the eyepoint adjustment within P3D or the Immersive Display Pro eyepoint?
The way I have done it is to adjust the eyepoint so that when sitting in the pilot seat I actually just look straight ahead and shift the eyepoint until the origin aligns with my looking straight ahead. I could possibly give you those numbers this weekend if I bring up the software. I've never done it by entering distances.
What is also key is to ensure you have the correct eyepoint values entered into P3D for the flight model. The two combined should remove the issues you mentioned.
Building a full scale 737-800 AATD for home use. Majority of hardware is from Sismo Solutions, software is Prosim under P3D. An AOPA member and LifeTime member of National Association of Flight Instructors
Please note that I am a self-employed professional cockpit builder that provides consulting to defense contractors and civilian schools and airlines.
Offline bravolima
  • Forum GURU
« Reply #2 on: September 07, 2018, 07:38:21 PM »
in Display Pro respectively in Calibration Pro I made no alterations Eyepoint there, it is 0/0/0. Eyepoint and Eyeposition (view straight ahead) are aligned to the centerline of Calibration pro. In P3D as well no changes were made. Thought this is inside the flightmodel
Bernhard (LSZH)
COUNTDOWN TO WF2019
WORLDFLIGHT TEAM USA
Recent Posts
Official WF 2019 Route
by bernard S
[Today at 04:21:22 PM]
737-800 Front window post size
by kurt-olsson
[Today at 01:19:13 PM]
Worldflight 2019 Open for Business
by Trevor Hale
[Today at 08:28:13 AM]
More ?'s - annunciators?
by kattz
[Today at 05:44:21 AM]
Hi everyone!
by fsaviator
[August 20, 2019, 01:29:02 PM]
Looking for annunciators
by kattz
[August 19, 2019, 10:36:39 PM]
OK, So here we go!
by Caflyt
[August 19, 2019, 02:32:28 PM]
Flight Illusion Boeing Press Gauge for sale
by XOrionFE
[August 19, 2019, 08:40:35 AM]
Shell placement and yoke placement questions
by helloo
[August 18, 2019, 02:37:26 PM]
panel sismo oh
by gufau
[August 17, 2019, 04:17:00 AM]
My next sim?
by fsaviator
[August 16, 2019, 06:54:51 PM]
by blueskydriver
[August 14, 2019, 10:35:26 AM]
Shipping Woes
by Ed
[August 13, 2019, 11:55:37 AM]
Looking for gear lever from 747-400, 757
by navymustang
[August 13, 2019, 10:05:44 AM]
Quick way to attach low res/smaller file size pics in your posts...
by Vincent T.
[August 12, 2019, 09:58:46 PM]
Cant post attachments from my iphone
by Trevor Hale
[August 12, 2019, 09:26:08 AM]
For Sale: Engravity 737 Window Frames
by Caflyt
[August 11, 2019, 05:02:28 PM]
737-800 Arduino X-Plane Build
by kurt-olsson
[August 10, 2019, 01:43:57 PM]
Help identifying a connector
by kurt-olsson
[August 10, 2019, 10:59:31 AM]
items/oem from overhead
by gufau
[August 09, 2019, 12:06:59 PM]
For Sale GoFlight Jet Console, 2 Private Pilot Racks all with GoFlight Modules.
by blueskydriver
[August 08, 2019, 09:40:02 PM]
Flightdeck Solutions Works with X-Plane11
by Michael_B737_ATP
[August 07, 2019, 02:59:21 PM]
Boeing Dual Linked Yokes for sale
by tennyson
[August 07, 2019, 07:34:58 AM]
CPFLight Backlighting
by mickc
[August 05, 2019, 10:09:53 PM]
Three Projector 210 degree with P3D4
by Nat Crea
[August 03, 2019, 08:36:50 PM]
Looking for part numbers from the 737 NG IPC
by mickc
[August 02, 2019, 11:20:49 PM]
WF2019
by Sam Llorca
[August 02, 2019, 09:22:56 PM]
Teensy LC Fuel Panel A (top)
by bernard S
[August 02, 2019, 06:09:00 PM]
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
