  • *Users: 0
  • *Guests: 57
  • *Total: 57
Author Topic: Calibration Pro Eyepoint-setting/Eyepoint position  (Read 439 times)
Offline bravolima
  • Forum GURU
  • B 737 Homecockpit-Pilot
  • First Name: Bernhard
  • Home Location: LSZH
« on: September 07, 2018, 01:29:32 PM »
Hello,
I recently optimized my Visual with the new Version 3.04 of Calibration Pro from Fly Elise. (390 cm Diameter, 3 BenQ Beamer with overcross Setting). The result is very good so far, the warping seems to be distinctive improved in comparison with my older Version 3.1 and I am very happy with it.
One thing remains:
when coming closer to the runways, I have the impression I am a little bit to high. Even in fully automated approaches this impression remains even though the VASI looks right. Two weeks ago I had a jump on a Airbus 320. Remembering  the visual Impression from that experience - I was concentrated on that -  I will ask you should I  and how to improve my setting.
The data:
Eye Position: 140 cm
Horizon on the projection wall: 140 cm
Hight of the projection: 155 cm
projection above the horizon line 65 cm
projection below the horizon line 90 cm
The projection was done with crosshair-laser and several automap steps. Columns were adjusted with crosshair-lasers too. With crosshair-laser the horizonal lines were only leveled slightly over the three projections.
Shall I vary eypoint-setting? For instance 15-20 cm lower? Does it have optical-geometric effect at all or do I have to accept the result as it is?
Bernhard (LSZH)
« Last Edit: September 07, 2018, 01:30:14 PM by bravolima »
PREPAR3D v4.2 FDS MIP, CDUs, Clocks, Shell, Liners,Tiller; FLIGHTILLUSION Brake-pressure, jaw-damper CPFlight: Overheads, Pedestal; MCP EFIS, OPENCOCKPIT Pedals; FCS: linked Yokes (modified); Weber-Seats on RAIL, ProSim B737 & Project Magenta with TSR, Aivalsoft EFB Version 2, Navigraph, FSC, BenQ1080 3 Beamer-Visual
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • First Name: Jim
  • Home Location: KMCO
Re: Calibration Pro Eyepoint-setting/Eyepoint position
« Reply #1 on: September 07, 2018, 05:24:38 PM »
Are you referring to the eyepoint adjustment within P3D or the Immersive Display Pro eyepoint?
The way I have done it is to adjust the eyepoint so that when sitting in the pilot seat I actually just look straight ahead and shift the eyepoint until the origin aligns with my looking straight ahead. I could possibly give you those numbers this weekend if I bring up the software. I've never done it by entering distances.
What is also key is to ensure you have the correct eyepoint values entered into P3D for the flight model. The two combined should remove the issues you mentioned.
Offline bravolima
  • Forum GURU
« Reply #2 on: September 07, 2018, 07:38:21 PM »
in Display Pro respectively in Calibration Pro I made no alterations Eyepoint there, it is 0/0/0. Eyepoint and Eyeposition (view straight ahead) are aligned to the centerline of Calibration pro. In P3D as well no changes were made. Thought this is inside the flightmodel
Bernhard (LSZH)
COUNTDOWN TO WF2019
Free Jet Ranger.
by geneb
[Today at 06:16:52 PM]
items/oem from overhead
by gufau
[Today at 12:49:15 PM]
Hi everyone!
by jskibo
[Today at 08:05:33 AM]
[Today at 03:35:11 AM]
Shipping Woes
by Caflyt
Official WF 2019 Route
by dougsnow
by Trevor Hale
More ?'s - annunciators?
by kattz
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
My next sim?
by fsaviator
by blueskydriver
by navymustang
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
