  • *Users: 0
  • *Guests: 59
  • *Total: 59
Author Topic: Active Sky 16 Networked to P3D V4 ?  (Read 990 times)
Offline brianwilliamson
  • Forum GURU
  • Junior Builder
  • First Name: Brian Williamson
  • Home Location: GOLD COAST --AUSTRALIA
« on: October 14, 2018, 07:52:08 PM »
I have had Active Sky 16 for some time but have not ventured to the networking side to the Sim Cockpit.
After reading the manual on networking I am a little confused as to whether it is possible to run it on my setup, which is a server running P3d V4  (with minimum view) and 3 computers running the 3 Views only via 3 projectors, as I think some of you are running similar setups.
Can anyone tell me if they have tried to run AS16 on this type of setup, as the way they describe in the manual how to do this, seems only to apply to one server and one client.
Many thanks......................Brian W.
Offline jmlohrenz
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Jason
  • Home Location: MN, USA
Re: Active Sky 16 Networked to P3D V4 ?
« Reply #1 on: October 21, 2018, 10:31:48 PM »
The quick answer is no.  AS will work in a networked setup for one computer.  IE running AS16 on computer 1, and your simulator on Computer 2.  Computer 1 runs the application and sends all the weather data to Computer 2.  They do not have any setup currently where it would work with multiple 'client' computers.
  • Forum GURU
  • Junior Builder
« Reply #2 on: October 22, 2018, 02:01:26 AM »
Thank you very much for the reply.
I had that suspicion that it would not do a multi screen, so that sort of fixes that idea of using AS16 !!
As  far as I am aware, that is the only program compatible with Jeehells software for the Airbus Radar.
Ok again many thanks......................Brian W.
Offline FredK
  • I may as well be Staff!
  • 737NG Cockpit Builder
« Reply #3 on: October 22, 2018, 09:24:55 AM »
Hi Brian
I can confirm that conclusion is true.
But.....It is possible to run AS on your server,  and then run FSGRW separately for your clients only using one of the clients as the FSGRW server.
I have investigated that arrangement, and it works fine.  The downside of course is that it is one more program that you have to run.
It is the exact same general weather information that the two programs are drawing from the local weather stations.  However if you are interested in synching specific cloud formations in your visual display with the weather scan on your ND (for example, using AS with SimA) that will not work since it is subject to each weather program's individual visual depiction of the general weather scheme.
« Last Edit: October 22, 2018, 09:25:26 AM by FredK »
  • Forum GURU
  • Junior Builder
« Reply #4 on: October 23, 2018, 07:46:10 PM »
Thanks Fred. It all gets complicated the more one adds to the sim and of course the more errors we can get.
I have gotten  to that stage of trying to keep it as simple as possible, without having to pull one of the computers out and work on it for a week to get things back to square one !!
So I think I will rely on using the weather settings in WideView for the time being.
Cheers.............Brian W.
  • Forum GURU
  • Junior Builder
« Reply #5 on: October 24, 2018, 12:59:36 AM »
Fred. I just set FSReal Wx Pro up on my home computer and have to say it looks exceptional on it, and simple !!
I also noted that you were running it on your sim. Just wondering how you set it up on the server/clients etc. and are you using WideView ?
Regards....Brian W.
Offline FredK
« Reply #6 on: October 24, 2018, 08:31:25 AM »
Hi Brian
I am using FS Global Real Weather (which is different from FSReal Weather Wx Pro).
FSGRW can be networked.  It is an advantage using it with WideView since weather is transferred to the clients independent of WideView via a separate "network bridge".  Thus WV operates much more smoothly since it has less data traffic to be concerned with.
FSGRW is really a must for WideView users. I encourage you to try it.  It is not an expensive program.  Just follow the directions within the program for a network setup....easy enough to do.
Fred
Offline navymustang
  • Simulation Engineer
  • First Name: Jim
  • Home Location: KMCO
« Reply #7 on: October 24, 2018, 03:10:43 PM »
I am always so curious to the resulting quality of weather when layering in all these support programs, versus just using P3D weather.
Is it really worth it?  I fly with just P3D weather as built through the Prosim 737 IOS.
  • Forum GURU
  • Junior Builder
« Reply #8 on: October 24, 2018, 03:38:22 PM »
Thanks Fred...........I did not realise that there was another similar program with a similar name.
Nice to have a first hand report from someone with similar setups, so we know it works ok.
Will give it a try.
..........Brian W.
Offline FredK
« Reply #9 on: October 24, 2018, 07:07:19 PM »
Hi Jim
The payware weather programs do provide extra detail concerning the types of weather formations, winds aloft, and turbulence, etc.   Some of these (but not all) will also replace the appearance textures etc....FSGRW does not.
Is it worth it you say?  As with many aspects of this hobby that is in the eye of the beholder.  What may ring one person's bell will not tinkle another's.  So only you can answer that question for yourself.  There obviously is a sizable market for them though, so there is some bell ringing going on for sure.
Independent of that FSGRW does provide a value for WideView multi-channel users since it is the only program that can be networked independent of P3D that also syncs cloud depictions across the multi-channel views perfectly.  There is a substantial performance boost doing it that way.  That is the reason that I use it.
Offline navymustang
  • First Name: Jim
« Reply #10 on: October 24, 2018, 09:26:47 PM »
Fred, thanks for the response. Yes, I get great synch between PCs for weather just using P3D. And I guess since I am more training focused where visibility and basic cloud formations is perfectly acceptable, I'm just fine. You are so right, it is in the eye of the beholder.
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by XOrionFE
[April 18, 2019, 10:22:51 PM]
by jackpilot
[April 18, 2019, 07:04:18 PM]
Teensy LC Throttle Quadrant
by RayS
[April 18, 2019, 03:38:14 PM]
by navymustang
[April 18, 2019, 08:25:11 AM]
by 757Simulator
[April 18, 2019, 04:20:53 AM]
Old Projector(s)
[April 18, 2019, 02:34:54 AM]
[April 17, 2019, 05:10:03 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
TV Screen Position
by Trevor Hale
[April 15, 2019, 07:17:07 AM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
Aerosoft Australia 747 MCP
by 737simAdelaide
[April 14, 2019, 05:16:58 AM]
CPFlight 737 EL MCP For Sale
by 737simAdelaide
[April 14, 2019, 05:12:54 AM]
CPflight radios B737.
by avan1001
[April 14, 2019, 04:12:07 AM]
Anyone can recognize this material?
by 757Simulator
[April 14, 2019, 03:21:26 AM]
F18 military trainer cockpit for sale
by navymustang
[April 13, 2019, 10:19:06 PM]
by patiju
[April 13, 2019, 01:02:33 PM]
FLIGHT ILLUSION gauges
by patiju
[April 13, 2019, 12:58:25 PM]
wanted FDS CDU
by 757Simulator
[April 13, 2019, 03:35:00 AM]
CAD assistance
by Timothy Denner
[April 12, 2019, 11:30:41 PM]
737 MAX
by mickc
[April 12, 2019, 07:20:35 PM]
Cpflight MCP737PRO
by Trevor Hale
[April 12, 2019, 09:12:36 AM]
95% finished Diamond DA62 build
by jskibo
[April 12, 2019, 09:01:31 AM]
Building a 737 MAX
by KennethGreene
[April 11, 2019, 05:37:23 PM]
Prosim and RSP TQ interfacing
by Lomaric
[April 11, 2019, 05:33:46 PM]
PCFlights.com?
by Trevor Hale
[April 11, 2019, 03:11:27 PM]
