  • *Users: 0
  • *Guests: 67
  • *Total: 67
Author Topic: Goflight 166 radios and power issue  (Read 771 times)
Offline Steenos
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Justin
  • Home Location: KCHA
« on: November 15, 2018, 11:55:54 PM »
Good evening everyone. I was building a 737 sim but found out I had to move and had to sell all of my gear. I found out about go flight because they have a pedestal and I could keep everything on the pedestal and it would be a lot cleaner of a setup that I could move around.
I bought 2x Go Flight 166 radios. One for Com 1 and one for Nav 1.
https://goflightinc.com/product/gf-166-radio-panel/
So I plugged everything in to my USB ports thinking everything would work. Boy was I wrong. I read some forum posts about the GF166 requires a lot of power because of the LED's on the radio. So I went to Best Buy and bought a $30 dollar insignia powered USB hub. Plugged the radios in. Everything was still not working. So I unplugged everything. I plugged just one radio in the USB hub. EUREKA! The radio works just fine and didn't lock me out.
The USB Hub is 5v 3.5amp. As soon as I plug in a second radio everything dies. I bought a second usb hub for the second radio and as long as they're both on separate hubs they work! But, at 30 dollars a hub and if I wanted to have 4 radios in total that's a lot of money.
Forgive my ignorance but I don't know power very well. I don't know how much the Radio draws because the users manual doesn't tell me anything. Is there any way to have just one hub be able to produce that much power and be a little cleaner than having multiple usb hubs for just one radio?
Any help would be greatly appreciated.
Thanks!
Offline blueskydriver
  • First Name: John
  • Home Location: WI
Re: Goflight 166 radios and power issue
« Reply #1 on: November 16, 2018, 02:48:24 AM »
Hey Justin,
That is pretty strange for only one radio to work per hub, I can have 6 or 7 GoFlight Modules plugged into one powered hub without any issues; this includes multiple GF-166A's
What happens when you plug one module or both into the computer's USB port(s)? What is USB port version for your computer 1.0/1.1, 2.0 or 3.0?
What is the model number of these hubs? I'm curious to look them up. Insignia can be pretty cheap in price, but also cheap in manufacturing. I use Belkin Powered Hubs.
By the way, did you see all the GF items I am selling? If you're interested send me a PM. One thing for sure, they would meet your needs for mobility and ease of use. If you can overlook black versus the grey ones... :idiot:
Kind Regards,
Offline navymustang
  • Simulation Engineer
  • Forum GURU
  • First Name: Jim
  • Home Location: KMCO
« Reply #2 on: November 16, 2018, 09:04:48 AM »
Offline Steenos
  • Forum GURU
« Reply #3 on: November 16, 2018, 09:13:12 AM »
Hey John. This is the powered usb hub that I used. Was the only thing I could find at Best Buy. They aren’t cheap. https://www.bestbuy.com/site/insignia-4-port-usb-3-0-hub-black/5631038.p?skuId=5631038
They don’t even light up when I plug them in to the computers usb slot. That’s where I did the forum research for the powered usb hub. You said your belkin you can plug them all in? I really want to have 4 radios. But I also don’t want to have to buy a usb hub per radio.
Navy thanks so much. I’ll chedk that out
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #4 on: November 16, 2018, 10:01:44 AM »
Did you install the GoFlight software so you could assign what each radio would do?
Offline Steenos
  • Forum GURU
« Reply #5 on: November 16, 2018, 10:42:23 AM »
I did Bob.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #6 on: November 16, 2018, 11:00:22 AM »
And it sees both radios and allows you to assignee them while they are both connected to the same hub? I have never had an issue with plugging multiple GF products to the same hub. In fact at one point I had 2 six port hubs with 12 GF units all working happily!
Offline Steenos
  • Forum GURU
« Reply #7 on: November 16, 2018, 11:04:44 AM »
What type of hub did you use Bob? I bought these cheap insignia ones from Best Buy. Cheap manufacturered. Not cheap price. Haha. The software recognizes the radios but no lights on the radio light up.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #8 on: November 16, 2018, 12:36:15 PM »
Justin,
I would put a call into Goflight Support. No way should one unit draw that power, unless something is radically wrong.
You say the radios are recognized but do they adjust frequency in fsim when you turn the controls.
Offline Joe Lavery
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #9 on: November 16, 2018, 01:52:27 PM »
Justin,
I too have 6 go-flight units attached to a belkin hub and they work perfectly.
I would also suggest a call to go-flight, but before that I would try them on another PC and see if you get the same issues.
Just a suggestion.
www.pcpilot.net
Offline Steenos
  • Forum GURU
« Reply #10 on: November 16, 2018, 04:08:32 PM »
Thanks for the info. Can you guys tell me which Belkin hub you have?
Offline Joe Lavery
  • 737 Builder
« Reply #11 on: November 17, 2018, 05:44:23 AM »
Hi Justin,
Well I've fed you false information, after crawling under my MIP it appears that the Go-Flight unis are attached to an Orico powered hub: this one:
https://www.amazon.co.uk/7-Port-Powered-Aluminium-Windows-Adapter/dp/B075FFJLW4/ref=sr_1_5?s=computers&ie=UTF8&qid=1542451248&sr=1-5&keywords=orico+7+port+usb+3+hub
I do have another Belkin one that is attached to some of the other USb devices, Gauges etc. and that is this one:
https://www.amazon.co.uk/Belkin-Ultra-Powered-Power-Supply/dp/B0061RSASU/ref=sr_1_1?ie=UTF8&qid=1542451591&sr=8-1&keywords=belkin+7-port+usb+hub
Sorry for the mixup...  8) ;)
www.pcpilot.net
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #12 on: November 17, 2018, 09:06:27 AM »
They where just cheap ones. BUT... This was several years ago. All my units where the black ones, no grays. It is posable they have changed something in the boards over the years.
Offline Steenos
  • Forum GURU
« Reply #13 on: November 18, 2018, 06:05:22 PM »
The Belkin hub did not work and neither did the 7 port slim hub from best buy. I think I'm figuring out what is going on. These little hubs only have 3 amps total power. A guy on youtube has at least 4 GF 166 radios that he's plugged in and they're all working on this hub.
https://www.amazon.com/Datamation-Systems-Universal-15-Port-DS-SC-PP15/dp/B00FH2I1XO
Holy 625 dollars. Seems a bit overkill. But I can't seem to find anything else that has 2.1 amps per port. I found one on ebay for 200 OBO but doesn't include a power supply. Ugh.
Anyone know of a powered USB hub that supplies 2.1 amps per port? I've been searching google and so far I haven't found anything.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #14 on: November 18, 2018, 06:28:04 PM »
Justin,
Before you keep pouring more money, why dont you get one of those gadgets to measure power. It may not be a power problem, os may be shutting down the USB port.Have you tried them on another computer?Then you will know for sure
what you really need. Even better just contact Goflight and ask them what is the power draw of these radios is.
I can see you ending up with a bunch of hubs and getting nowhere.
Even better, try there support forum, you should get support there.
« Last Edit: November 18, 2018, 06:48:35 PM by iwik »
Offline Steenos
  • Forum GURU
« Reply #15 on: November 18, 2018, 06:42:21 PM »
There's no contact info for goflight. I have a support email but sometimes they don't even respond to my emails. Makes me wonder why I bought them. But I'll try again.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #16 on: November 18, 2018, 06:46:22 PM »
Have you registered at their site and left a support ticket? Sounds to me like you have something wrong with one of those units.
Offline Steenos
  • Forum GURU
« Reply #17 on: November 18, 2018, 07:32:47 PM »
So I'm reading a post about someone having issues with their 166's. Another guy says Run GFWindow8Fixer.exe. Apparently he says this helps with getting the LED's to light up properly. But I don't have this.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #18 on: November 19, 2018, 11:07:32 AM »
Justin,
You may be having problems with USB power management, have a look at this link and make sure
Auto is disabled.
https://www.windowscentral.com/how-prevent-windows-10-turning-usb-devices.
Its also available in Win7.
Offline Steenos
  • Forum GURU
« Reply #19 on: November 19, 2018, 12:44:19 PM »
So, doing more research on forums and such with goflight. The software on goflight's website said that it's only for prepar3d. So I didn't download it because I was using XPlane 11. Well I saw a post where someone said you need to run windows8fixer even on windows 10 and that it was in the goflight folder.
So I went back to the website and downloaded the software. I ran the windows 8 fixer and sure enough. Everything was working. I just don't understand what was going on. But that's what everyone said if the lights weren't illuminating properly. Feels good to have everything working though after nights of frustration.
Thanks for all your help.
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
Help with wiring up FDS map light
by Skysurfer170
[Today at 02:36:03 PM]
Flight Scoring Platforms....
by KyleH
[Today at 11:07:01 AM]
by navymustang
[Today at 09:38:45 AM]
by blueskydriver
[Today at 07:42:41 AM]
Great US switch supplier
by Bob Reed
[March 20, 2019, 09:21:11 PM]
Great video on a Caravelle project
by Lomaric
[March 20, 2019, 06:10:00 PM]
Holy Grail ?
by bernard S
[March 20, 2019, 06:05:06 PM]
Join me on Vatsim Tonight
by Trevor Hale
[March 20, 2019, 09:08:36 AM]
737 MAX
by FredK
[March 19, 2019, 11:07:27 PM]
Sim Speaker System in a small package...
by sagrada737
[March 19, 2019, 01:32:30 PM]
Prosim and RSP TQ interfacing
by jfuenmayor
[March 18, 2019, 02:04:20 PM]
OEM 737 classic liners for sale
by Gallie
[March 18, 2019, 09:54:39 AM]
B737-200 throttle quadrant for sale
by Gallie
[March 18, 2019, 08:56:25 AM]
by 757Simulator
[March 18, 2019, 04:20:49 AM]
JetMax TQ for Sale...
by sagrada737
[March 16, 2019, 02:57:19 PM]
Revolution Simproducts V2.0 Plug & Play Throttle help
by jfuenmayor
[March 14, 2019, 10:13:05 PM]
Attention All Members and Guests
by Trevor Hale
[March 13, 2019, 06:25:07 PM]
Creality CR-10S 3d printer.
by sagrada737
[March 12, 2019, 07:57:11 PM]
CPFlight EFIS737Pro2
by Lomaric
[March 11, 2019, 05:18:20 PM]
Homebuilt seats and a question
by Trevor Hale
[March 11, 2019, 01:32:17 PM]
777 Throttle - sold
by mattking247
[March 10, 2019, 07:13:29 PM]
General Aiation FLIGHT GEAR, For sale
by fairchild
[March 10, 2019, 05:17:41 PM]
I HAD an idea for an inexpensive B737 cockpit - Not so inexpensive now!
by bernard S
[March 10, 2019, 01:03:02 PM]
B737 Heads Up Guidance Systems (HUD)
by navymustang
[March 10, 2019, 12:48:09 PM]
JetMax components for sale - ALL SOLD
by 737SimGuy
[March 08, 2019, 02:41:41 PM]
Open Cockpits P&P MCP/EFIS/FMC for Sale - NEW in USA
by Fabian
[March 07, 2019, 12:21:17 AM]
CPFLIGHT GEAR FOR SALE
by ivanroberts77
[March 06, 2019, 10:46:27 AM]
OEM AFDS Module 737-NG
by Reensel
[March 05, 2019, 03:59:47 PM]
737 Demonstrator For Sale
by mattford1
[March 05, 2019, 03:16:30 PM]
Wanted: FDS 737NG Nav Radio (USB)
by 737NG-Ed
[March 05, 2019, 06:34:07 AM]
