  • *Users: 2
  • *Guests: 65
  • *Total: 67
Author Topic: boeing overhead circuit breaker back light panel wiring  (Read 470 times)
Offline kondrat
  • Forum GURU
  • Aviation Enthusiast
    • Boeing 777-200LR project
  • First Name: Denis Kondratenko
  • Home Location: Cambridge, Ontario
« on: November 20, 2018, 07:42:52 PM »
Hi all,
Probably an easy question but ...
Just finished my overhead frame and adding switches. Have CB panels mounted (OEM probably from 747) and was ready to connect backlighting. I was able to find 5v cable and ground is common for all the panels.  When I use 5v the panels are very dim. I have to supply almost 12v to see them bright. If I connect 5v to individual panel everything looks good. How to supply the power to the panels using original wiring?
Denis
http://www.flikr.com/project777
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
Re: boeing overhead circuit breaker back light panel wiring
« Reply #1 on: November 20, 2018, 07:46:58 PM »
What sort of power supply are you using to power them? also are you powering the lightplates directly or through a dimmer?
Offline kondrat
  • Forum GURU
« Reply #2 on: November 20, 2018, 08:06:25 PM »
Thanks for help!
I am testing first without dimmer. I have 5v power supply (maybe need something more powerful).
Offline mickc
  • First Name: Mick
« Reply #3 on: November 20, 2018, 11:31:42 PM »
Depends on the capacity of the power supply, i'd say its being overloaded with all panels attached.  There are 20 light plates there, fairly long ones too.
Depending how many bulbs there are per lightpate (judging by the length there could be up to 10-12 per plate, the bulbs pull 60mA each, so thats 0.6-0.7A per plate, so up to 15 Amps  just to run all those plates.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #4 on: November 21, 2018, 08:44:05 AM »
I would nt feed 12v to make it brighter !!!
Use 5V and a good PSU
I use a 1200W PSU which feeds both OVH of the 737.
Offline kondrat
  • Forum GURU
« Reply #5 on: November 21, 2018, 11:14:55 AM »
Thanks guys,
I just bought new PSU and bingo, better result. 5v and much brighter.
Thanks again!
Denis
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by MjTom
[Today at 11:01:18 AM]
by navymustang
[Today at 08:25:11 AM]
Teensy LC Throttle Quadrant
by ElStino737
[Today at 06:56:37 AM]
by 757Simulator
[Today at 04:20:53 AM]
Old Projector(s)
[Today at 02:34:54 AM]
[April 17, 2019, 05:10:03 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:02:26 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
TV Screen Position
by Trevor Hale
[April 15, 2019, 07:17:07 AM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
Aerosoft Australia 747 MCP
by 737simAdelaide
[April 14, 2019, 05:16:58 AM]
CPFlight 737 EL MCP For Sale
by 737simAdelaide
[April 14, 2019, 05:12:54 AM]
CPflight radios B737.
by avan1001
[April 14, 2019, 04:12:07 AM]
Anyone can recognize this material?
by 757Simulator
[April 14, 2019, 03:21:26 AM]
F18 military trainer cockpit for sale
by navymustang
[April 13, 2019, 10:19:06 PM]
by patiju
[April 13, 2019, 01:02:33 PM]
FLIGHT ILLUSION gauges
by patiju
[April 13, 2019, 12:58:25 PM]
wanted FDS CDU
by 757Simulator
[April 13, 2019, 03:35:00 AM]
CAD assistance
by Timothy Denner
[April 12, 2019, 11:30:41 PM]
737 MAX
by mickc
[April 12, 2019, 07:20:35 PM]
Cpflight MCP737PRO
by Trevor Hale
[April 12, 2019, 09:12:36 AM]
95% finished Diamond DA62 build
by jskibo
[April 12, 2019, 09:01:31 AM]
Building a 737 MAX
by KennethGreene
[April 11, 2019, 05:37:23 PM]
Prosim and RSP TQ interfacing
by Lomaric
[April 11, 2019, 05:33:46 PM]
PCFlights.com?
by Trevor Hale
[April 11, 2019, 03:11:27 PM]
