  • *Users: 1
  • *Guests: 52
  • *Total: 53
Author Topic: Thickness of a resl 737-800 Glareshield / MCP Light panel  (Read 633 times)
Online kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« on: December 02, 2018, 01:21:41 PM »
I am using 8mm thick MDF with vinyl, so my MCP light panel / glareshield is 10mm thick in total.
Does anyone know the real thickness?
I want to use 10mm mdf + 2mm vinyl wrap. But maybe its too thick, maybe you wont notice 2 extra mm?
https://goo.gl/images/w9J36S
« Last Edit: December 02, 2018, 01:26:42 PM by kurt-olsson »
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • First Name: Jim
  • Home Location: KMCO
Re: Thickness of a resl 737-800 Glareshield / MCP Light panel
« Reply #1 on: December 02, 2018, 02:34:12 PM »
The two Glareshields from 737 classics I have are sheet aluminum. Perhaps 4mm maximum thickness
Online kurt-olsson
  • First Name: Peter
« Reply #2 on: December 02, 2018, 04:12:35 PM »
Thanks, i know the Classic is much thinner than the NGs.
Offline mickc
  • Aviation Enthusiast
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #3 on: December 02, 2018, 07:00:40 PM »
The glareshield is 2 major parts, the thin cover that extends to the front windows, and the front bumper section that houses the lighting unit.
That front section above the MCP is approx 1/2" thick - 12.7mm
Back section:
Front section:
Online kurt-olsson
  • First Name: Peter
« Reply #4 on: December 03, 2018, 12:50:17 AM »
Thank you so much Mick!
This means that i can use 10mm MDF + 2mm vinyl and end up with correct size.
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #5 on: December 03, 2018, 04:01:35 PM »
Kurt,
I am lucky to owner a actual copy of a NG glareshield, exactly like Micks drawings. only difference with mine are the "plastic" parts being made from polyester/fibreglass and not some other strong composite material like the real thing.
I took some pics of the front of the glare showing the lip where the lightstrip sits behind. I think its about 5-6mm deep then add the tickness of the panel (2 mm). The mounting holes for the lightstrip are sunken inside the top cover (if this makes sense...)
There is about 5-6mm of space between the MCP lightplate and the top cover. MCP is cpflight pro V2, it fits the mounting nut plates without any modifications.
Hope this helps, and i am sure a couple of mm of difference wont matter.
Michael
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #6 on: December 03, 2018, 04:51:36 PM »
You may consider using a PVC (various thickness) thermo bendable
Can be textured painted any color
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #7 on: December 03, 2018, 04:51:47 PM »
You may consider using a PVC sheet (various thickness)
Thermo bendable
« Last Edit: December 03, 2018, 04:54:06 PM by jackpilot »
Online kurt-olsson
  • First Name: Peter
« Reply #8 on: December 06, 2018, 08:43:02 AM »
I really like the feel of the black vinyl.
Hopefully i can get some help from a local company that provides routing service so i can install the LED diffuser in my MCP.
Offline Joe Lavery
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #9 on: December 06, 2018, 01:13:54 PM »
Hey Kurt you don't need to spend a fortune on a Router, shops like Aldi and Lidl sell them regularly for under £25.00. Just look around your DIY stores the larger ones will generally offer cheaper units. You could even route than small a slot with a Dremel.
 :2cw:
www.pcpilot.net
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by MjTom
[Today at 11:01:18 AM]
by navymustang
[Today at 08:25:11 AM]
Teensy LC Throttle Quadrant
by ElStino737
[Today at 06:56:37 AM]
by 757Simulator
[Today at 04:20:53 AM]
Old Projector(s)
[Today at 02:34:54 AM]
[April 17, 2019, 05:10:03 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:02:26 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
TV Screen Position
by Trevor Hale
[April 15, 2019, 07:17:07 AM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
Aerosoft Australia 747 MCP
by 737simAdelaide
[April 14, 2019, 05:16:58 AM]
CPFlight 737 EL MCP For Sale
by 737simAdelaide
[April 14, 2019, 05:12:54 AM]
CPflight radios B737.
by avan1001
[April 14, 2019, 04:12:07 AM]
Anyone can recognize this material?
by 757Simulator
[April 14, 2019, 03:21:26 AM]
F18 military trainer cockpit for sale
by navymustang
[April 13, 2019, 10:19:06 PM]
by patiju
[April 13, 2019, 01:02:33 PM]
FLIGHT ILLUSION gauges
by patiju
[April 13, 2019, 12:58:25 PM]
wanted FDS CDU
by 757Simulator
[April 13, 2019, 03:35:00 AM]
CAD assistance
by Timothy Denner
[April 12, 2019, 11:30:41 PM]
737 MAX
by mickc
[April 12, 2019, 07:20:35 PM]
Cpflight MCP737PRO
by Trevor Hale
[April 12, 2019, 09:12:36 AM]
95% finished Diamond DA62 build
by jskibo
[April 12, 2019, 09:01:31 AM]
Building a 737 MAX
by KennethGreene
[April 11, 2019, 05:37:23 PM]
Prosim and RSP TQ interfacing
by Lomaric
[April 11, 2019, 05:33:46 PM]
PCFlights.com?
by Trevor Hale
[April 11, 2019, 03:11:27 PM]
