  • *Users: 0
  • *Guests: 51
  • *Total: 51
Author Topic: 12v power supply for map light  (Read 684 times)
Offline Skysurfer170
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Vernon
  • Home Location: Edinburgh
« on: January 14, 2019, 01:18:16 PM »
Hey guys,
I’m wanting to purchase the FDS map light and also the dimmer unit. Does anyone recommend a good 12v power supply for this? Not sure what i’m looking for and i’m not electrical minded.
Appreciate the help.
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: 12v power supply for map light
« Reply #1 on: January 14, 2019, 06:24:24 PM »
Get any PC Power supply new, or better second hand, in shops that do computer maintenance. Around  $20 . You will get 5V (red wires) 12V (yellow) ground (black) To make it work you need to
Join the green wire (there is just one) with any ground.
Piece of cake!
  • Forum GURU
« Reply #2 on: January 15, 2019, 04:15:10 AM »
Will i cut off the additional wires from it? Also what if i need longer wires?
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #3 on: January 15, 2019, 08:59:54 AM »
Hi Vernon,
A computer power supply has connectors normally for internal connections. However, to use it for your needs, do as Jack suggested, but only cut the connectors off the wires you need. For myself, I'd just remove the connector and wire it to whatever I need it for.
As for extension wires, use those that are about the same size as the ones your cutting the connectors off of. If you look at the wires on the power supply, they might have the sizes written on them. Look for AWG and a number, that is the wire sizing, then head off to a hardware store and buy some spools of wire of that size...
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #4 on: January 15, 2019, 09:41:08 AM »
The best is to cut off all terminals and arrange your PSU so that you can use it for other applications
Something in that vein.
Besides, the FDS lights use LEDs, AWG 20 is more than enough
« Last Edit: January 15, 2019, 09:42:20 AM by jackpilot »
  • First Name: John
  • Home Location: WI
« Reply #5 on: January 15, 2019, 10:08:58 AM »
What Jack is doing looks very nice and neat, plus he's using wiring blocks/connectors with fused sections. Having things like this is much safer and makes it easier later on to find errors with power and fix them; a lot of other builders use block connectors as well.
Here is a really old book (pdf link), yet still good enough to use today, if you know little about electronics. Go through it and even try some of the examples...
https://archive.org/details/Radio_Shack_-_Basic_Electronics_Share_Me_Self_Help_Ebook_-_Pdf1/page/n1
Offline awdoman
  • Forum GURU
  • First Name: Eric
  • Home Location: Plainfield,il
« Reply #6 on: January 15, 2019, 01:11:00 PM »
Another way than mentioned above where you dont have to cut any wires, is to buy what is call a Breakout board.  Amazon has this version or there are others.  Check it out, it may help you as well.
https://www.amazon.com/Electronics-Salon-20-pin-Supply-Breakout-Module/dp/B01NBU2C64/ref=sr_1_5?ie=UTF8&qid=1547575967&sr=8-5&keywords=computer+psu+breakout+board
  • First Name: John
  • Home Location: WI
« Reply #7 on: January 15, 2019, 02:34:14 PM »
Good find Eric! I will order some of these for myself...thank you!  :idiot:
  • Forum GURU
« Reply #8 on: January 15, 2019, 03:51:29 PM »
Thanks alot guys.
That breakout board looks awesome, i may purchase one of those and a ATX PSU to connect it to.
Now i have a question - If I decide to purchase this board do I connect the dimmer and the phidgets relay card i will be using to it
  • Forum GURU
« Reply #9 on: January 15, 2019, 04:03:26 PM »
Hey guys i just drew this with a normal PSU
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #10 on: January 15, 2019, 05:13:35 PM »
Use the relay to switch the positive side, and also use the Normally Open contact (NO) you have it shown  wired to the Normally Closed contact
  • Forum GURU
« Reply #11 on: January 16, 2019, 04:37:10 AM »
Now i’m conf With all this electrical stuff
Offline bernard S
  • Forum GURU
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #12 on: January 16, 2019, 10:17:24 AM »
no offence     buy book understanding electronics and electrical curcuits    be a great help to you
  • Forum GURU
« Reply #13 on: January 17, 2019, 06:05:37 AM »
Offline fordgt40
  • First Name: David John Bullock
  • Home Location: Chelmsford UK
« Reply #14 on: January 17, 2019, 07:35:27 AM »
Buying from Opencockpits their prices exclude VAT and postage will be dear. Ebay is your best bet
Offline Joe Lavery
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #15 on: January 17, 2019, 07:45:52 AM »
You could pick up a second hand one that would be fine for a fraction of that price, even buying a broken PC would be better. There are so many bits you can get from so called scrap equipment.
 :2cw:
www.pcpilot.net
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #16 on: January 17, 2019, 09:15:34 AM »
PC repair shops are full of them.
They will sell you a good one for some $20 flat.
Offline 757Simulator
  • Forum GURU
    • Fantasy of Flight
  • First Name: Mike
  • Home Location: CVG
« Reply #17 on: January 18, 2019, 02:55:13 AM »
  • First Name: John
  • Home Location: WI
« Reply #18 on: January 18, 2019, 07:49:31 AM »
Hey Everyone,
That link I posted for the older hand written book for Radio Shack is actually a very good read. I used mine (in book form) when first starting my sim project. I already knew electronics somewhat, but not enough of the "why" for this or that.
Anyhow, you can download and print out the PDF version, just scroll down the web page then choose PDF download. I just tested this and it was fine with no errors or viruses... :idiot:
Happy Soldering,
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
For Sale: Jetmax 737 TQ - Texas, USA
by MistyBlue
[Today at 02:19:22 PM]
by MistyBlue
[Today at 02:17:28 PM]
FSUIPC 5 Button Limitations
by GyverX
[February 18, 2019, 05:33:55 PM]
Operating System Blues
by Joe Lavery
[February 18, 2019, 02:47:27 PM]
Virtual FO software
by fsaviator
[February 18, 2019, 02:36:20 PM]
Join me on Vatsim Tonight
by Trevor Hale
[February 17, 2019, 01:48:52 PM]
Throttle
by 727737Nut
[February 17, 2019, 09:14:54 AM]
737 NG Throttle Levers
by mickc
[February 17, 2019, 05:02:01 AM]
For sale: A set of faceplate panel for pedestal
by mickc
[February 17, 2019, 05:01:07 AM]
FlyAB Simparts: A new supplier for your OEM needs
by Trevor Hale
[February 16, 2019, 10:51:54 PM]
B737-800 Flight Sim for sale $85,000.00
by Rob_b
[February 16, 2019, 12:47:11 AM]
by iwik
[February 15, 2019, 06:47:11 PM]
by Joe Lavery
[February 15, 2019, 05:39:06 PM]
Anyone seen OEM 737-900 ER Throttle Quadrant?
by Fly_AB
[February 15, 2019, 10:32:18 AM]
For Sale: P&P Opencockpit VHF, Transponder, and ADF
by Fly_AB
[February 15, 2019, 09:08:24 AM]
737 DIY MIP For Sale
by Trevor Hale
[February 14, 2019, 11:03:35 AM]
New supplier for your sim
by Fcoq
[February 14, 2019, 12:18:44 AM]
For Sale Prosim 737 v2.03 License
by mdavenport
[February 12, 2019, 04:00:00 PM]
by navymustang
[February 10, 2019, 12:50:48 PM]
[February 10, 2019, 09:31:17 AM]
Revolution Simproducts out of business?
by fsaviator
[February 09, 2019, 12:18:30 PM]
For sale: CPFlight MIP737SE
by Fly_AB
[February 08, 2019, 11:29:26 PM]
For sale: Engravity sixpack pairs --- SOLD
by Fly_AB
[February 08, 2019, 08:32:04 PM]
by MjTom
[February 08, 2019, 08:00:54 AM]
by Trevor Hale
[February 08, 2019, 07:41:50 AM]
737 Demonstrator For Sale
by Trevor Hale
[February 08, 2019, 07:39:34 AM]
Looking for B737NG or A320 SIM for Home Use
by KingAviation
[February 08, 2019, 03:17:35 AM]
Zibo 737 FlightControl Dataref/Commands
[February 05, 2019, 05:34:35 PM]
by FredK
[February 05, 2019, 12:58:20 AM]
Flight Control Panel A Side
[February 04, 2019, 04:34:38 PM]
