  • *Users: 2
  • *Guests: 11
  • *Total: 13
Author Topic: Rack and Spur Gear - Help with Maths!  (Read 647 times)
Offline RPPerry3
  • Forum GURU
  • One step at a time...
    • Paul's Flight Deck
  • First Name: Paul
  • Home Location: South Carolina
« on: January 25, 2019, 12:05:55 PM »
I need help calculating the correct diameter of spur gear so that my potentiometer gets near 300 degrees rotation as it travels the length of a 300mm rack.
I'm building a custom flight yoke and this is for Yaw control.  As I push the yoke shaft in or pull back the carriage will have the Potentiometer with spur gear that rolls down the rack gear as input.
« Last Edit: January 25, 2019, 12:20:54 PM by RPPerry3 »
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • First Name: Jim
  • Home Location: KMCO
Re: Rack and Spur Gear - Help with Maths!
« Reply #1 on: January 25, 2019, 01:44:11 PM »
I assume you meant pitch control  :)
Have you thought about using a string pot instead of the gear assembly you described. So much easier to build with.
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #2 on: January 27, 2019, 08:36:45 AM »
You could also use a slide pot. That just slides in and out with the elevator pitch control
A lot less complicated.
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #3 on: January 27, 2019, 01:34:02 PM »
Jim's suggestion is spot on. I've been using the same string pots for many years in my TQ. So, those would be great for a Yoke setup, or like Trevor suggests, the slide pots will work just as good... :idiot:
Offline Aerosim Solutions
  • Simulator part supplier
    • Aerosim Solutions
  • First Name: Gwyn Perrett
  • Home Location: Perth, Western Australia
« Reply #4 on: January 29, 2019, 08:17:43 PM »
Diameter would have to be 115mm
360/300(degree ratio) = 1.2
1.2 x 300mm = 360
360mm/Pi (3.142) = diameter 114.57mm
Cheers Gwyn
Boeing 737NG using Prepar3D v3.35, Prosim737, FDS SYS cards, FDS CDUs, CP Flight EL MCP & EFIS & Aerosim Solutions hardware of course!
Check out my website here -
http://www.aerosimsolutions.com.au
Offline Trevor Hale
  • Administrator
« Reply #5 on: January 30, 2019, 06:15:05 AM »
1.2 x 300mm = 360
Cheers Gwyn
Gwyn, This is amazing.. you described it perfectly.  Thank you.
COUNTDOWN TO WF2019
Display Glare FDS w/Pic
by jackpilot
[Today at 03:45:11 PM]
Dispatch and Career Add-on
by Bob Reed
[Today at 12:15:37 PM]
Free Jet Ranger.
by geneb
items/oem from overhead
by gufau
Hi everyone!
by jskibo
Shipping Woes
by Caflyt
Official WF 2019 Route
by dougsnow
by Trevor Hale
More ?'s - annunciators?
by kattz
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
My next sim?
by fsaviator
by blueskydriver
by navymustang
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
