  • *Users: 1
  • *Guests: 50
  • *Total: 51
Author Topic: PSU works once but not twice  (Read 669 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« on: January 28, 2019, 02:44:19 PM »
Everything works. i can turn my PSU on/off how many times i want.
If i just connect the FlightControl Panel backlight with nothing else i can turn on my PSU ONCE, but then it goes into shutdown mode. Just like if you had a shortcircuit.
I reset my PSU and it works again, but only ONCE.
Remove the 5V backlight of my FlightControl Panel and i can turn on/off how many times i want.
What on earth can this be?
Offline kurt-olsson
  • First Name: Peter
Re: PSU works once but not twice
« Reply #1 on: January 28, 2019, 02:54:51 PM »
It seems like it is some sort of overhead/overload protection going on.
I changed my FlightControlPanel and added the Windows Heat panel and it is the same problem with that panel, so there is nothing wrong with my panels.
If i disconnect another panel it all works again.
Maybe you can only push a certain amperage through each red cable on the PSU.
the PSU says 30 Amps and i am nowhere near that...
Offline kurt-olsson
  • First Name: Peter
« Reply #2 on: January 28, 2019, 03:14:59 PM »
Its definently a overload problem.
When connecting all the panels i get this problem, remove a big one, T-panel FlightControlPanel or BleedAirPanel and it works.
Isnt 5V supposed to handle 30 amps?
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #3 on: January 31, 2019, 09:55:36 PM »
Kurt,
On any of these panels are there any Solenoids that are energized at power up?
Also any Large Value Capacitors connected across the 5v line.
The problem maybe a spike on power up that trips o/current.
You are using OEM panels and as we dont know exactly what you left in from original.
Just a couple thoughts i had.
Offline kurt-olsson
  • First Name: Peter
« Reply #4 on: February 01, 2019, 01:43:36 AM »
Thanks Les.
Yes, the OEM contains Solenoids but no big capacitors that load up any current.
But my next thing is to buy an ampmeter so i can actually see how much current that is being drawned. But even with 12-15 small bulbs / panel i think it should be a problem. Well well time will tell. :)
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #5 on: February 01, 2019, 04:03:00 PM »
My FDS Overhead  panels are using the same bulbs as the OEM stuff.
You need a strong PSU
Mine is a 900 watts
Offline kurt-olsson
  • First Name: Peter
« Reply #6 on: February 02, 2019, 08:56:23 AM »
Do you know the total ampdraw of your overhead Jack?
I have a 650w PSU if not misstaken.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #7 on: February 02, 2019, 01:15:02 PM »
for the backlighting only 650 should be good
You must have other things sucking the amps
Offline kurt-olsson
  • First Name: Peter
« Reply #8 on: February 02, 2019, 01:55:07 PM »
It was only 400w but this should be enough anyway...
maybe its busted. Will get another one and do some testing together with a new ampmeter
Offline kurt-olsson
  • First Name: Peter
« Reply #9 on: February 03, 2019, 11:50:47 AM »
Update!
This is a safety feature!
When capacitors load up with lots of current you need to switch it on off also using the green/black cable.
It wont start again by turning the on-off switch!
Offline kurt-olsson
  • First Name: Peter
« Reply #10 on: February 03, 2019, 12:10:19 PM »
Just to confirm:
Switch at the back: always on.
Use green / black cable to turn on off.
It now works turn on off with all the panels!
COUNTDOWN TO WF2019
For sale
by TNT
[July 18, 2019, 07:57:29 PM]
by Philip
[July 17, 2019, 06:47:22 PM]
[July 17, 2019, 02:55:53 PM]
Boeing 737 Dual Linked Yokes
by tennyson
[July 16, 2019, 08:59:28 PM]
by patiju
[July 16, 2019, 02:01:48 PM]
by Mach7
[July 16, 2019, 04:52:26 AM]
Korry 318 gets hot.
by Joe Lavery
[July 16, 2019, 03:49:14 AM]
by blueskydriver
[July 14, 2019, 10:25:43 AM]
by blueskydriver
[July 13, 2019, 03:46:30 AM]
by blueskydriver
[July 12, 2019, 10:53:12 PM]
by fsaviator
[July 10, 2019, 08:35:14 PM]
PM MCP.ini Question...
by ScottThePilot
[July 10, 2019, 12:56:38 PM]
Stab Trim Indicator...
by ScottThePilot
[July 09, 2019, 12:56:42 PM]
Teensy LC Throttle Quadrant
[July 08, 2019, 08:09:41 AM]
[July 08, 2019, 08:05:27 AM]
Anders Simparts - Summer info
by archen
[July 07, 2019, 03:30:31 AM]
by kattz
[July 03, 2019, 09:26:22 PM]
by ifeliciano
[July 02, 2019, 09:58:37 AM]
by mickc
[July 01, 2019, 08:01:04 PM]
Happy Canada Day
by jackpilot
[July 01, 2019, 10:09:40 AM]
MH 370 Article
by FredK
[June 30, 2019, 07:28:41 PM]
by kattz
[June 30, 2019, 06:08:50 PM]
International shipping?
by jackpilot
[June 27, 2019, 08:29:07 AM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
by jackpilot
[June 25, 2019, 08:19:42 AM]
by blueskydriver
[June 24, 2019, 02:29:16 PM]
by Buster99
[June 22, 2019, 04:12:34 PM]
by kattz
[June 22, 2019, 12:40:51 PM]
by jackpilot
[June 20, 2019, 12:26:51 PM]
by kevinsayre
[June 19, 2019, 03:57:33 PM]
