Cockpit
* User Profile
Welcome, Guest. Please login or register.
Who's Online
  • *Users: 1
  • *Guests: 51
  • *Total: 52
Our Discord
Author Topic: PC upgrade-build-or buy advice??  (Read 817 times)
Offline Slacker
  • CockpitBuilder
  • Aviation Enthusiast
  • First Name: Stephen
  • Home Location: Howell
« on: February 11, 2019, 03:11:30 PM »
PC Advice :-    So I have an off the Self ASUS ROG G20CB  16 gig ram. GTX1070 video card I think its I7 but could be I5 1TB hard drive. had it for almost 2 years.     SO it is working fine but I cant turn up my graphics to where I want them. Also I am only running 2 monitors. 1 with the flight sim and a second with either a nav program or just the internet for whilst im flying.     even tho its a pretty good spec its not enough for flight sim so Im thinking of either upgrading this by adding ram lowest cost and I doubt will get me what I want. Or Buy or BUild.        I want to be able to run my flight sim on 3 screens and maxed out graphics with a good frame rate and extra performance so it will last for a few years.   suggestions??    Build ?? Buy??    dual graphics cards ??      Im currently running FSX steam and xplane 11.   but i am probably going to go with P3D as I have already invested in a tone of Orbex and add on planes weather etc that work with FSX and should transfer to P3D I believe.         So let the PC opinion help begin please.    Oh also I am working on building a cockpit probably a generic GA cockpit that will work across multiple planes.
Offline Slacker
  • CockpitBuilder
Re: PC upgrade-build-or buy advice??
« Reply #1 on: February 11, 2019, 09:13:12 PM »
So Im thinking I need to do a lot more research before I spend a penny.  Just had fsx open flying around the Portland Oregon area with my Orbex scenery.  graphics not completely maxed out but pretty close.  Pulling a whopping 15 to 20 FPS.    yet when I look at the performance monitor im only using 50%CPU  40% memory  40% graphics card.      so I either got some settings issues going on or maybe  the read write speed of my hard drive is not fast enough.   ether way I should be able to tune my current system to run better with some more research.
Offline n4208t
  • Forum GURU
  • First Name: Steve
  • Home Location: Eagan, MN
« Reply #2 on: February 12, 2019, 10:27:58 AM »
Howdy,  IMHO you have enough computer to more than run what you are describing.  I would hold off on buying or building a new rig until you tweak what you already have.  Your PC could be either an i5 or an i7 and while the i7 is better, the i5 is more than capable.  Knowing all of your pc's stats would help to make any recommendations.
It is hard to go into a lengthy discussion here because the number of tweaks and adjustments can be large and dependent on how you already have your computer set up.  Your video card is fine and the 1070 typically has 8GB of vram.  16 gb of RAM is fine for what you are running.  32 bit programs really cannot take advantage of large amounts of RAM anyway.
FSX is 32 bit and not the most efficient.  FSX-SE handles memory a bit better but, personally, I hate Steam.  P3Dv3 is similar to FSX but a bit better and, of course, P3Dv4 is a 64 bit program which is a major improvement but may cause some issues with any/some of your add-ons.
Don't get hung up on frame-rate.  If the sim flies smoothly and does not hang and you are satisfied with the performance, then don't worry what the numbers show.  At 15,000 feet in a clear sky they will be much higher.  You can also always turn the graphics down but you can also tweak the settings of the GTX 1070 to get the best performance for your system.
Try it.  Cannot hurt anything and just keep copies of original files or settings.  AVSIM's P3D tweaking guide is really helpful too.
Feel free to PM me if I can help.
Steve (N4208T)
Offline KyleH
  • Administrator
  • Forum GURU
  • B763!
  • First Name: Kyle
  • Home Location: Ontario
« Reply #3 on: February 12, 2019, 10:43:08 AM »
If your staying with FSX, I'd suggest googling 'FSX Bible' by Nick N. If your going to change to P3D, then his hardware selection and OS setup comments are still valid, but setting up the flight sim has changed.
Offline FredK
  • I may as well be Staff!
  • 737NG Cockpit Builder
  • First Name: Fred Kurasiewicz
  • Home Location: Williamsburg, Virginia, USA
« Reply #4 on: February 12, 2019, 02:49:02 PM »
If your objective really is “to run 3 screens with maxed out graphics” that is no where near possible with a single computer.  You would need to consider a mult-channel (multi computer) setup to approach that. There are many threads in this forum that you can search related to that.
Boeing 737NG-800, Prepar3D v4.3, Sim-Avionics, WideView multi-channel (curved screen), Optoma 1080GTDarbee projectors (3), Fly Elise warping, FSGRW weather, FDS OH panels and CDUs, SimParts MIP, FDS SysBoards (OH), CPFlight MCPPro and pedestal panels, FI Gauges, PFC controls, converted motorized TQ (SIOC), Weber seats
Offline Slacker
  • CockpitBuilder
« Reply #5 on: February 12, 2019, 03:41:56 PM »
Thanks for the info guys.
I am definitely doing more research before spending anything.    the 3 screens is a long term goal.
right now I just need to learn more with this set up and try different changes to see how it works.
I am reading the FSX bible thread. its a long one :)    I will also try the Avsim one because I think I am going to end up going to P3d at some point.
Offline n4208t
  • Forum GURU
  • First Name: Steve
« Reply #6 on: February 12, 2019, 03:56:29 PM »
FYI - AVSIM has an FSX Setup guide too.  They are pretty much the same but not identical.
Offline 727737Nut
  • I spend way too much on this forum!
  • 737-300 Using Real parts and X-Plane 10
  • First Name: Rob Archer
« Reply #7 on: February 13, 2019, 09:41:02 AM »
Just my  :2cw:,   My PC, I5 6600k OC to 4.3G,  1060GTX 6g Video, 16G 2400mhz ram, middle of the road mobo,  750w psu, 250g SSD for windows and x-plane and 3TB hdd for scenery
I run can run 3,  50" TV's and maintain 30+ fps with setting one notch below max no problem.  Sometimes in heavy clouds i'll see 22-24 but its still smooth.   I also have 35 usb interfaces communicating as well all on one lonely PC.
So to tell someone it can't be done is not totally true.  ;)
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
  • Home Location: Christchurch New Zealand
« Reply #8 on: February 13, 2019, 06:01:46 PM »
Rob,
What are you using for usb hubs>
Les
Offline 727737Nut
« Reply #9 on: February 15, 2019, 02:19:46 PM »
Rob,
Les
Les,
Just make sure you get TT rated usb hub and you'll be fine.  I got mine from amazon for 18$  4 port hubs and I stack them where needed.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #10 on: February 15, 2019, 06:47:11 PM »
Thanks Rob,
Yes i previously used two such hubs. Can you provide a link to the ones you used. Your
price looks more attractive than the $70 i paid.
Les
COUNTDOWN TO WF2019
WORLDFLIGHT TEAM USA
Recent Posts
For Sale: Dual Linked Rudder Pedals RSP
by Philip
[Today at 06:47:22 PM]
737-800 Arduino X-Plane Build
by kurt-olsson
[Today at 02:55:53 PM]
Boeing 737 Dual Linked Yokes
by tennyson
[July 16, 2019, 08:59:28 PM]
Flyengravity desktop MIP (SOLD)
by patiju
[July 16, 2019, 02:01:48 PM]
Flight deck solutions FDS-B737NG-PRO-MX- rudder pedal
by Mach7
[July 16, 2019, 04:52:26 AM]
Korry 318 gets hot.
by Joe Lavery
[July 16, 2019, 03:49:14 AM]
by blueskydriver
[July 14, 2019, 10:25:43 AM]
Where to find or how to make this switch guard?
by blueskydriver
[July 13, 2019, 03:46:30 AM]
NIB 747-400 ThrottleTek + FDS CDUs x2 [SOLD]
by blueskydriver
[July 12, 2019, 10:53:12 PM]
FDS 5V IBL Dimmer and Expansion Board / Pokeys 57E (SOLD)
by fsaviator
[July 10, 2019, 08:35:14 PM]
PM MCP.ini Question...
by ScottThePilot
[July 10, 2019, 12:56:38 PM]
Stab Trim Indicator...
by ScottThePilot
[July 09, 2019, 12:56:42 PM]
Teensy LC Throttle Quadrant
by kurt-olsson
[July 08, 2019, 08:09:41 AM]
Multiple Teensys, sketch upload question
by kurt-olsson
[July 08, 2019, 08:05:27 AM]
Anders Simparts - Summer info
by archen
[July 07, 2019, 03:30:31 AM]
Group buy - Oshino OL-2405BP lamps - interested?
by kattz
[July 03, 2019, 09:26:22 PM]
Prosim737 Ver 2 license for sale
by ifeliciano
[July 02, 2019, 09:58:37 AM]
Anyone have this connector and possibly a clamp as well for the yoke?
by mickc
[July 01, 2019, 08:01:04 PM]
Happy Canada Day
by jackpilot
[July 01, 2019, 10:09:40 AM]
MH 370 Article
by FredK
[June 30, 2019, 07:28:41 PM]
Calling any B747 mechs... please help
by kattz
[June 30, 2019, 06:08:50 PM]
International shipping?
by jackpilot
[June 27, 2019, 08:29:07 AM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
How much room between center pedestal and seat?
by jackpilot
[June 25, 2019, 08:19:42 AM]
2020 Microsoft Flight Simulator - new at E3 2019
by blueskydriver
[June 24, 2019, 02:29:16 PM]
How to install DZUS fasteners?
by Buster99
[June 22, 2019, 04:12:34 PM]
Desert Air Spares - Trustworthy?
by kattz
[June 22, 2019, 12:40:51 PM]
Wanted - 737 Audio Panels - OEM
by jackpilot
[June 20, 2019, 12:26:51 PM]
Throttletek 737 Throttle For Sale
by kevinsayre
[June 19, 2019, 03:57:33 PM]
For sale - rudder pedals and linkages - SOLD - thanks, Craig!
by Caflyt
[June 19, 2019, 07:49:14 AM]
