  • *Users: 0
  • *Guests: 49
  • *Total: 49
Author Topic: Creality CR-10S 3d printer.  (Read 505 times)
Offline Mach7
  • Forum GURU
  • Aviation Enthusiast
  • First Name: james
« on: February 27, 2019, 09:38:05 PM »
I have found a solution that I would like to share for those of you who have 3D printers.
I have been doing a lot of printing lately and keep running into the same problems that everyone else has, and that is trying to get the object to stick to the building platform during the process.
I have tried glues, tapes and just about everything you can imagine. I have even tried running higher temps on the build plate and increased the brim width in an attempt to get a quality product...however one thing is certain...if you don't have good initial adherence then the construct will be flawed.
I have probably discarded more PLA then I care to mention...occasionally I get a good print, but mostly I end up stopping the print during the initial stages when I see the tell tale signs of a print going south....until now.
I usually place masking tape over my glass build plate, as this always seemed to be the  best option for me, however I noticed that...when it was time to take the tape off...the tape would not peel off easily and the tape I did take off would leave a sticky residue behind, which I would clean off prior to applying the fresh tape for the next build.
Last week, I removed the tape when the plate was still hot as opposed to my previous method of cleaning the pate when it was at room temperature. to my surprise, the tape came off easily but left the glue behind on the build plate.
I decided to try a build on the residue alone, and to my surprise I can now achieve perfect builds...however you have to drop the plate and the material in a sink full of water in order to separate the object from the glass.
Now....I place masking tape on the build plate, run the bed up to 90 degrees, whilst ensuring the tape is pressed firmly in place, then after 10 mins I remove the tape and begin my build.
Works every time!!!
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
Re: Creality CR-10S 3d printer.
« Reply #1 on: February 28, 2019, 02:13:10 PM »
Sounds to me Like a pain in the A$$.
Ensure your nozzle is leveled to the buildplate with a sheet of Paper.
Get yourself a sheet of Borosilicate glass (3mm) and stick a sheet of PEI (1mm) on it (Comes with 3m 2 sided tape on the PEI) attach the borosilicate glass to your buildplate with binder clips.
(Hot plate stuff sticks) (Cool Plate stuff releases)
Good Luck Sir.
Offline Mach7
  • Forum GURU
  • First Name: james
« Reply #2 on: March 01, 2019, 09:06:34 AM »
Thanks Trevor,
That actually sounds like a better mousetrap for sure.
The downside to my method is trying to get the build project released from the plate....I usually have to soak the whole package in soapy water overnight in order for the hold to relax enough in order to remove the items without damage.
Offline Trevor Hale
  • Administrator
« Reply #3 on: March 01, 2019, 09:54:34 AM »
That sucks...  I can only imagine the painful waiting for that.
For me, its on to the next print within minutes..  Watch the youtube videos on PEI sheets and you will see.  It took me 3 prints to get it figured out, and the temperature right.  Printing with PLA its 210 on the nozzle and 63 on the bed.
Offline IFLY3
  • CockpitBuilder
  • First Name: MIke
  • Home Location: ontario
« Reply #4 on: March 02, 2019, 07:16:10 PM »
what Trevor said,dialing in the bed is key,and remove the plate when removing objects.
Offline sagrada737
  • 737NG Home Cockpit:
  • I may as well be Staff!
  • N737CM - Keep your airspeed up !
    • Imaging The Heavens
  • First Name: Mike
  • Home Location: Las Cruces, New Mexico USA
« Reply #5 on: March 12, 2019, 07:57:11 PM »
Hi guys,
This is an interesting thread, as I have recently gotten into 3D printing.   I have two Creality CR-10S Pro printers.   I have spent about three months working out how best to utilize this technology to make viable parts for my 737 Sim.   In reality, there are limitations to 3D printing, however, it is a viable tool for many of our needs in building a flight simulator.
The most significant factor in 3D printing toward obtaining good print results, is understanding the limitations of the filament material one is using in relation to the part design desired to be printed.   This concerns itself mainly with dimensional stability and structural integrity.
The CR-10S Pro, like many of the low cost 3d printers uses FDM (Fused Deposition Modeling) technology.   This approach uses "layers" of filament material that gets extruded through a nozzle, to essentially "stack" layers of material to yield the design geometry required in the printed part.   In this regard, two critical factors are important to get right, or the print result will suffer.   These are:   1. Bed Adhesion, and 2.  Slicer Settings.
BED ADHESION is peculiar to the type of material being printed.   The most common filament material is PLA, which is fairly easy to print, and fairly easy to achieve good bed adhesion.   However, PLA is not the best choice for structure parts, as layer separation can be a factor, which may cause the part to break apart.   PLA is not the best choice for dimensional stability.   Things like Bezels for gauges can easily be made from PLA.   However, other filament materials that offer greater strength, may have other issues -- bed adhesion being one of them.   Nylon and ABS filament materials are an example of materials that have demanding bed adhesion issues.
In my experimentation with 3D printing, I have found that a simple glass mirror plate works the best for PLA type of materials, including PLA-Carbon Fiber (CF) filaments.   For other filament materials, I have found that Kapton sheet or tape is excellent for bed adhesion, with a water based glue stick for PLA/PLA-CF and Nylon/Nylon-CF.  For ABS filament, using the Kapton tape and an acetone/ABS slurry makes for excellent bed adhesion.
SLICER SETTINGS are important as well to obtaining a good print result.   The Slicer is essentially the post-processor between the Solid Modeling CAD program (I use FreeCAD) and the 3D Printer.  The Slicer is where all the settings are made, which results in the GCode file that the 3D Printer can understand for printing the part.  The "magic" is done in the Slicer, and getting the setting correct for the type of material being printed.
Bottom line is...   Get the Bed Adhesion right, and the Slicer settings right, and you can achieve printing a good part.   Get either one of these screwed up and you will have nothing but problems getting good results from your 3D printer.  That said, the world of 3D printing opens up a whole new opportunity for the Sim Builder, with many opportunities for making various parts for our Sims.
For example...   I used my 3d printers to make Projector Supports for my three Optoma GT1080HD projectors.   In this case, I used a PLA material.   I have used the PLA-Carbon Fiber material effectively to make Bezels and Cases for various assemblies, etc..  The filament material I am liking the most now, is PETG-Carbon Fiber.   It has good dimensional/strength qualities.  Where strength is required, Nylon-Carbon Fiber is a good choice.   However, each of these materials requires special consideration with respect to part design, bed adhesion, and Slicer settings.  Again...   Get all that right,and you get good parts.
P3d v3.x with Sim-Avionics (two computers), FDS MIP, 3-Optoma HD GT180 projection display driven by a single nvidia GTX980.
Looking, second-hand B737 ICS MIP panels with subpanels
by fairchild
[Today at 10:57:07 AM]
items/oem from overhead
by mickc
[Today at 10:14:16 AM]
X-Plane 11 multi-monitor & Fly Elise-ng - tuto
by blueskydriver
[July 20, 2019, 05:33:45 AM]
FOR SALE: CA & FO Cockpit Seats with J Rails
by Philip
[July 19, 2019, 04:23:24 PM]
For sale
by TNT
[July 18, 2019, 07:57:29 PM]
by Philip
[July 17, 2019, 06:47:22 PM]
[July 17, 2019, 02:55:53 PM]
Boeing 737 Dual Linked Yokes
by tennyson
[July 16, 2019, 08:59:28 PM]
by patiju
[July 16, 2019, 02:01:48 PM]
by Mach7
[July 16, 2019, 04:52:26 AM]
Korry 318 gets hot.
by Joe Lavery
[July 16, 2019, 03:49:14 AM]
by blueskydriver
[July 14, 2019, 10:25:43 AM]
by blueskydriver
[July 13, 2019, 03:46:30 AM]
by blueskydriver
[July 12, 2019, 10:53:12 PM]
by fsaviator
[July 10, 2019, 08:35:14 PM]
PM MCP.ini Question...
by ScottThePilot
[July 10, 2019, 12:56:38 PM]
Stab Trim Indicator...
by ScottThePilot
[July 09, 2019, 12:56:42 PM]
Teensy LC Throttle Quadrant
[July 08, 2019, 08:09:41 AM]
[July 08, 2019, 08:05:27 AM]
Anders Simparts - Summer info
by archen
[July 07, 2019, 03:30:31 AM]
by kattz
[July 03, 2019, 09:26:22 PM]
by ifeliciano
[July 02, 2019, 09:58:37 AM]
by mickc
[July 01, 2019, 08:01:04 PM]
Happy Canada Day
by jackpilot
[July 01, 2019, 10:09:40 AM]
MH 370 Article
by FredK
[June 30, 2019, 07:28:41 PM]
by kattz
[June 30, 2019, 06:08:50 PM]
International shipping?
by jackpilot
[June 27, 2019, 08:29:07 AM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
by jackpilot
[June 25, 2019, 08:19:42 AM]
by blueskydriver
[June 24, 2019, 02:29:16 PM]
