  • *Users: 1
  • *Guests: 49
  • *Total: 50
Author Topic: Computer / Projector Combo  (Read 186 times)
Offline jmlohrenz
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Jason
  • Home Location: MN, USA
« on: April 14, 2019, 08:39:12 PM »
I currently have one 8700k overclocked to 5ghz with a 1080ti.  I want to bump up to a three projector setup.  Do you think if I setup another computer similar to my main one, with same CPU and Vid card that I can run two projectors off of one of the computers, and another off the second?
Should this setup work OK?
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • First Name: Jim
  • Home Location: KMCO
Re: Computer / Projector Combo
« Reply #1 on: April 14, 2019, 09:11:02 PM »
I would run all three from one computer. The frame rate may be slightly less, but the overall appearance will be better because of the total synch of each window rather than relaying on something like WideView to make an attempt to synch multiple computers.
I have built systems running 4 projectors running on a very high-end graphics card on a single computer with great success.
In fact I have a client who runs two computers, one for the cockpit displays and one for the visual. P3D only runs on the visual and all three projectors are running from there, along with Prosim and supporting utilities. He is very satisfied with the results. One major advantage of this approach is the ability to use GSX and all the fun results of animated jetways, ground vehicles, etc.
Offline jmlohrenz
  • Forum GURU
  • First Name: Jason
« Reply #2 on: April 14, 2019, 09:21:35 PM »
So should I look to add a second 1080ti to my existing computer and run two displays off one video card and the third off the second?
Is the math still accurate as far as each display will cut the frames down, so if I run 3 views from 3 projectors my frames will be about a third of what I get with one view and one projector?
Just trying to manage that.
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #3 on: April 15, 2019, 07:19:38 AM »
Just a tidbit for you (With experience).
If you run 3 displays on one card or 3 displays on 3 cards, your frames will drop aprox 30% for each display you add.  More cards doesn't equate to same frames on each card.  Especially with P3D.  Your still sharing the CPU with each display.
You won't see an economical benefit by adding another 1080ti. Maybe 5 frames.
Offline jmlohrenz
  • Forum GURU
  • First Name: Jason
« Reply #4 on: April 15, 2019, 01:27:19 PM »
Ok that's what I thought.  Right now with one I bottom out in the upper 50s...so I can assume with two views I'd be 25fps plus which is acceptable. Think I may look at the second computer then for the third display.
With that being said is wideview the best option to link them
Offline Trevor Hale
  • Administrator
« Reply #5 on: April 15, 2019, 02:20:47 PM »
I have a I7-8700K with a GTX 980 Video card <-- OLD and I get 20-25 on the Ground at a FSDreamteam Airport, 50-60 at FL260 with 4 Undocked Windows. main front is large, then the two side windows are about 19" the 4th undocked is a tiny outside view camera.
 I have had to reduce Active sky to 2 cloud layers which made a big difference because Frames would tank with overcast skies and REX Skyforce. Mind you I am not running at 4K resolution, but just a thought.
I would try all on one card if I was you before I would delve in the the multiple machine realm, that will significantly increase the costs, especially because you have to buy 2 of every scenery and 2 of every software.
Just saying.
« Last Edit: April 15, 2019, 02:23:16 PM by Trevor Hale »
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #6 on: April 15, 2019, 02:50:24 PM »
It will be nice when the day comes to only use one outside view that would have 3d vector handles and an ability to place them anywhere you want on the edges. Thus, changing the shape of the view to match whatever curve your projector or monitor(s) shape is.
IMHO, the real problem with frame rates after all these years is the running of 4 window views (docked or undocked) from within the sim program. If it were only one view that was shapeable, there would be no need for multiple pc setups or multiple anything really.
Whoever creates software or hardware to do this without costing an arm and a leg will be the history maker, but mind you I am talking about use for the home/semi pro cockpit builders, not about the big time stuff that is already out there costing thousands or millions of dollars...ah, too dream!
In the mean time, listen to Trevor because that is what a lot of us are doing for the time being... :idiot:
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
Wanted: FDS 737 CDU, EFIS, MCP
by jskibo
[Today at 05:27:20 AM]
by 757Simulator
[Today at 04:35:43 AM]
Overhead: Where to mount interface cards?
by helloo
[April 25, 2019, 11:46:07 PM]
Where to buy/what size is this connector?
by helloo
[April 25, 2019, 11:44:19 PM]
[April 25, 2019, 04:43:15 PM]
by jskibo
[April 25, 2019, 02:25:50 PM]
by blueskydriver
[April 24, 2019, 03:30:03 PM]
unfinished project 737
by LORENZO
[April 23, 2019, 06:29:47 PM]
747-400 Yoke Color
by bernard S
[April 23, 2019, 04:39:55 PM]
737 MAX Sismo soluciones (SPAIN)
by kkoutoulas
[April 23, 2019, 02:53:50 PM]
TV Screen Position
by iwik
[April 22, 2019, 07:53:38 PM]
Question on B737NG center pedestal instrument availability
by navymustang
[April 22, 2019, 05:05:09 PM]
Wanted - Jetmax B737 TQ
by kattz
[April 22, 2019, 12:57:09 AM]
Multi-Projector color calibration
by jmlohrenz
[April 21, 2019, 05:33:40 PM]
Bernard...info
by FredK
[April 20, 2019, 06:29:17 PM]
by fsaviator
[April 20, 2019, 04:25:12 PM]
by blueskydriver
[April 20, 2019, 11:26:43 AM]
Old Projector(s)
by fsaviator
[April 20, 2019, 10:53:59 AM]
by Karl737
[April 19, 2019, 09:56:23 PM]
by patiju
[April 19, 2019, 06:14:33 PM]
by Steenos
[April 19, 2019, 03:22:12 PM]
by Joe Lavery
[April 19, 2019, 04:59:21 AM]
Teensy LC Throttle Quadrant
by RayS
[April 18, 2019, 03:38:14 PM]
by navymustang
[April 18, 2019, 08:25:11 AM]
by 757Simulator
[April 18, 2019, 04:20:53 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
