  • *Users: 2
  • *Guests: 45
  • *Total: 47
Author Topic: Overhead: Where to mount interface cards?  (Read 579 times)
Offline helloo
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Mike
  • Home Location: KAPA
« on: April 23, 2019, 11:25:30 AM »
I have an FDS overhead.  Where should the IBL boards and FDS SYS1 board be mounted?  Thanks.
Offline Jon Boe
  • Forum GURU
  • Junior Builder
  • First Name: Jon
  • Home Location: Centennial, Colorado USA
Re: Overhead: Where to mount interface cards?
« Reply #1 on: April 23, 2019, 11:53:32 AM »
I put them in the overhead to keep the wiring short.
B747 Driver
FDS Modules, Real Boeing interior
205 degree FOV screen, 3-HD projector visual
system.  Aerowinx PSX as simulator.  P3D V4.5
for visuals
Offline helloo
  • Forum GURU
  • First Name: Mike
« Reply #2 on: April 23, 2019, 12:30:21 PM »
That is my plan but there does not appear to be any particular place to attach them to.  Did you have to make your own mount to attached the boards to and then place in the overhead?  Any pics?
I do not have my cockpit shell yet so the overhead is just attached to a wood frame I made to hold it vertically while I wire it up.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #3 on: April 23, 2019, 05:08:22 PM »
Go and check with FDS (short Hop)
Seeing it in the flesh is better than any description.
The space between OVH and shell is limited on the 73.
I personally installed the SYS1 outside on top of the shell protected by a box.
Easy access and leaves room for other cards (relay) and wiring.
If you choose to keep it inside, you may also attach it under the shell ceiling with simple stand-offs.
Offline bernard S
  • I may as well be Staff!
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #4 on: April 24, 2019, 09:45:11 AM »
my 2 cents  i think you thinking  in single problems may I suggest think at end game for a solution and have x1 central.location for everything get yourself a server rack   from middle Atlantic products ..part number WR_37-32    roughly 1800 bucks put all your cards power supplies etc on quick dis connects everything in one central place .. you will thank me later for this tid bit cost of entry some may consider high   ease of maintence and use   priceless
« Last Edit: April 24, 2019, 09:49:02 AM by bernard S »
Offline jskibo
  • Going Broke, one sim part at a time
  • First Name: John
  • Home Location: Florence Kentucky
« Reply #5 on: April 24, 2019, 09:54:54 AM »
If you go that route, look on craigslist and the Home Theater forums.  Got mine for $400 when I was building the last home theater.  It barely fit in an Acura MDX.
Commodore C64 / Dual 5 1/4 Floppy / Green Monochrome monitor / Sub Logic Flight Sim / FDS MIP / CDU / CPFlight EFIS MCP
Offline bernard S
« Reply #6 on: April 24, 2019, 12:27:30 PM »
you miss the point of this one   this server racknis not fixed position internally it pulls out and rotates .. making life easy 😁..
Offline jskibo
  • First Name: John
« Reply #7 on: April 24, 2019, 02:00:42 PM »
Yeah exactly what I used as it was mounted under the stairs
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #8 on: April 24, 2019, 03:21:41 PM »
If you don't need the pull and rotate model, go to  Public Surplus com. They have all kinds of them and go for $1 each up to ? I got 10 of them for $100 total... :idiot:
PS That pull and rotate model is awesome though!
Offline helloo
  • Forum GURU
  • First Name: Mike
« Reply #9 on: April 25, 2019, 11:46:07 PM »
Thanks for the input.
Aurora is Aurora, Colorado.  Not Canada:)
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #10 on: April 26, 2019, 08:53:57 AM »
OOOps !
Offline 757Simulator
  • Forum GURU
    • Fantasy of Flight
  • First Name: Mike
  • Home Location: Fort Mitchell, Kentucky
« Reply #11 on: April 27, 2019, 03:57:29 AM »
Jack,
Hillary had a sale on these server racks back in 2016. We should have bought them all.  :laugh:
COUNTDOWN TO WF2019
Looking, second-hand B737 ICS MIP panels with subpanels
by fairchild
[Today at 10:57:07 AM]
items/oem from overhead
by mickc
[Today at 10:14:16 AM]
X-Plane 11 multi-monitor & Fly Elise-ng - tuto
by blueskydriver
[July 20, 2019, 05:33:45 AM]
FOR SALE: CA & FO Cockpit Seats with J Rails
by Philip
[July 19, 2019, 04:23:24 PM]
For sale
by TNT
[July 18, 2019, 07:57:29 PM]
by Philip
[July 17, 2019, 06:47:22 PM]
[July 17, 2019, 02:55:53 PM]
Boeing 737 Dual Linked Yokes
by tennyson
[July 16, 2019, 08:59:28 PM]
by patiju
[July 16, 2019, 02:01:48 PM]
by Mach7
[July 16, 2019, 04:52:26 AM]
Korry 318 gets hot.
by Joe Lavery
[July 16, 2019, 03:49:14 AM]
by blueskydriver
[July 14, 2019, 10:25:43 AM]
by blueskydriver
[July 13, 2019, 03:46:30 AM]
by blueskydriver
[July 12, 2019, 10:53:12 PM]
by fsaviator
[July 10, 2019, 08:35:14 PM]
PM MCP.ini Question...
by ScottThePilot
[July 10, 2019, 12:56:38 PM]
Stab Trim Indicator...
by ScottThePilot
[July 09, 2019, 12:56:42 PM]
Teensy LC Throttle Quadrant
[July 08, 2019, 08:09:41 AM]
[July 08, 2019, 08:05:27 AM]
Anders Simparts - Summer info
by archen
[July 07, 2019, 03:30:31 AM]
by kattz
[July 03, 2019, 09:26:22 PM]
by ifeliciano
[July 02, 2019, 09:58:37 AM]
by mickc
[July 01, 2019, 08:01:04 PM]
Happy Canada Day
by jackpilot
[July 01, 2019, 10:09:40 AM]
MH 370 Article
by FredK
[June 30, 2019, 07:28:41 PM]
by kattz
[June 30, 2019, 06:08:50 PM]
International shipping?
by jackpilot
[June 27, 2019, 08:29:07 AM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
by jackpilot
[June 25, 2019, 08:19:42 AM]
by blueskydriver
[June 24, 2019, 02:29:16 PM]
