  • *Users: 0
  • *Guests: 55
  • *Total: 55
Author Topic: Flooring Installed!  (Read 551 times)
Offline Mach7
  • Forum GURU
  • Aviation Enthusiast
  • First Name: james
Flooring Installed!
« on: June 18, 2019, 08:27:54 AM »
Finally installed the carpet in my pit. Was initially looking at close to 400 dollars for 60 square feet of carpet tile, as I assumed this would be the easiest to install due to the angles and curves. Purchased a 6 x 8 foot outdoor/indoor floor mat from Home Depot @ 24 dollars cdn, then made a paper template and cut to fit.
It actually turned out pretty good!
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
Re: Flooring Installed!
« Reply #1 on: June 18, 2019, 11:27:45 AM »
Nice!
I am also going with the black mat option for my cockpit.
Offline helloo
  • Forum GURU
  • First Name: Mike
  • Home Location: KAPA
« Reply #2 on: June 18, 2019, 05:00:50 PM »
Looks good.  Can you tell me about possible static electricity issues that might arise or how to mitigate it?  I also want to do carpet, but that has me hesitant.
Offline bernard S
  • I may as well be Staff!
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #3 on: June 18, 2019, 05:17:19 PM »
black    make sure have vaccum handy 😉
Offline Mach7
  • Forum GURU
  • First Name: james
« Reply #4 on: June 18, 2019, 05:41:16 PM »
@helloo
Not too much to worry about on the inside of the sim regarding static electricity.
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #5 on: June 24, 2019, 02:25:53 PM »
Hey Mike,
I did carpet and the static electricity mainly came from my hands, but it would also come from my knees when wearing shorts. Anyway, I just attached a simple wire to the pedestal and from there a 3 prong outlet adapter with ground wire. The plug adapter wire will provide the grounding...as long as the actual outlet is grounded correctly.
Have you thought about the coin shaped mat that is used by some airlines? I purchased 2 rolls of this:
https://www.homedepot.com/p/Husky-7-5-ft-x-17-ft-Coin-Grey-Universal-Flooring-HK70CN717SGRHD/205185022
Yes, it cost more then cheap carpet, BUT how much are your sim components worth? Carpet, static, zap, and new part! It will happen, just a matter of time. Go with the mat; I had mine delivered too my house through Home Depot.  :idiot:
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #6 on: June 24, 2019, 08:17:12 PM »
100% agree, go rubber.
Offline bernard S
« Reply #7 on: June 25, 2019, 09:24:43 AM »
I was not aware the 73 had carpet on floors   as for mine I have honeycomb floor and carpet directly over top of that
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #8 on: June 25, 2019, 10:05:00 AM »
Rubber Carpet from Costco
  • First Name: John
  • Home Location: WI
« Reply #9 on: June 25, 2019, 11:24:59 AM »
From what I've seen it's been the coin shaped rubber matting in both the 727 and 737, but this was in the UA and NWA planes. However, if it's carpet in the real planes, it'll need too be cleaned often...likely the same for simulators.
Frankly, whatever works for your budget is fine, just plan ahead for the static issues, drink or food spills, and if you have a pet(s). Pet hair will cling to everything because it gets statically charged from the animal itself; much like humans do...lol...dragging your feet.  :idiot:
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #10 on: June 25, 2019, 11:55:47 AM »
Not trying to emulate, just my own preference... :D
« Last Edit: June 25, 2019, 11:56:18 AM by jackpilot »
Offline navymustang
  • Simulation Engineer
  • First Name: Jim
  • Home Location: KMCO
« Reply #11 on: June 25, 2019, 12:58:14 PM »
Nothing like a good old aluminum floor   :)
Offline helloo
  • Forum GURU
  • First Name: Mike
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #13 on: June 25, 2019, 05:49:57 PM »
Carpeting is a pain to keep clean (dust, stains, shows areas of traffic after a while etc) whatever it is made of.
My 2 cents ;)
COUNTDOWN TO WF2019
[Today at 02:19:07 PM]
Looking, second-hand B737 ICS MIP panels with subpanels
by fairchild
[Today at 10:57:07 AM]
items/oem from overhead
by mickc
[Today at 10:14:16 AM]
X-Plane 11 multi-monitor & Fly Elise-ng - tuto
by blueskydriver
[July 20, 2019, 05:33:45 AM]
FOR SALE: CA & FO Cockpit Seats with J Rails
by Philip
[July 19, 2019, 04:23:24 PM]
For sale
by TNT
[July 18, 2019, 07:57:29 PM]
by Philip
[July 17, 2019, 06:47:22 PM]
Boeing 737 Dual Linked Yokes
by tennyson
[July 16, 2019, 08:59:28 PM]
by patiju
[July 16, 2019, 02:01:48 PM]
by Mach7
[July 16, 2019, 04:52:26 AM]
Korry 318 gets hot.
by Joe Lavery
[July 16, 2019, 03:49:14 AM]
by blueskydriver
[July 14, 2019, 10:25:43 AM]
by blueskydriver
[July 13, 2019, 03:46:30 AM]
by blueskydriver
[July 12, 2019, 10:53:12 PM]
by fsaviator
[July 10, 2019, 08:35:14 PM]
PM MCP.ini Question...
by ScottThePilot
[July 10, 2019, 12:56:38 PM]
Stab Trim Indicator...
by ScottThePilot
[July 09, 2019, 12:56:42 PM]
Teensy LC Throttle Quadrant
[July 08, 2019, 08:09:41 AM]
[July 08, 2019, 08:05:27 AM]
Anders Simparts - Summer info
by archen
[July 07, 2019, 03:30:31 AM]
by kattz
[July 03, 2019, 09:26:22 PM]
by ifeliciano
[July 02, 2019, 09:58:37 AM]
by mickc
[July 01, 2019, 08:01:04 PM]
Happy Canada Day
by jackpilot
[July 01, 2019, 10:09:40 AM]
MH 370 Article
by FredK
[June 30, 2019, 07:28:41 PM]
by kattz
[June 30, 2019, 06:08:50 PM]
International shipping?
by jackpilot
[June 27, 2019, 08:29:07 AM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
by jackpilot
[June 25, 2019, 08:19:42 AM]
by blueskydriver
[June 24, 2019, 02:29:16 PM]
