  • *Users: 0
  • *Guests: 64
  • *Total: 64
Author Topic: How to install DZUS fasteners?  (Read 466 times)
Offline helloo
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Mike
  • Home Location: KAPA
« on: June 18, 2019, 05:03:04 PM »
I have some Dzus fasteners that I need to install but it appears that something (tool?) is needed to do this.  I am installing blank plates in areas where I do not have anything and need to get these Dzus into the plates.
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: How to install DZUS fasteners?
« Reply #1 on: June 18, 2019, 08:01:40 PM »
Just drill the plates so that the bottom part of the Dzuz gets in and tighten 1/4 turn.
The only difference with properly seated Dzus is that they are not attached to the plate when you unfastened them, but the end result is the same.  :D
PS: if you use real blancs without Dzus installed just enlarge the hole so that...
« Last Edit: June 18, 2019, 08:04:31 PM by jackpilot »
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
  • Home Location: Arlington, Texas
« Reply #2 on: June 19, 2019, 08:15:21 PM »
You need a specific sized hole ans a special flaring tool to "crimp" the fastener to the sheet metal. Look at the PDF linked here. Bottom right of first page.
https://www.southco.com/static/Literature/D5.en.pdf
Offline peterkwu
  • Forum GURU
    • fly737ng.com
  • First Name: Peter
  • Home Location: Vienna, VA
« Reply #3 on: June 19, 2019, 08:24:00 PM »
Search "Dzus fastener tool" on eBay to find what you're looking for at reasonable cost
Check on my progress at
http://www.fly737ng.com
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #4 on: June 19, 2019, 09:12:08 PM »
In my humble opinion, no need to spend a penny on that for a few plates.
Actually, if your plates have no holes, the challenge is the precision of the hole drilling so that it fits the rail ( the tolerance is really thin) . The fact that the dzus is not crimped to the plate is non important. The dzus fastener will just do its job when you tighten it as it garbs the rail wire and keeps the plate fastened.
« Last Edit: June 19, 2019, 09:15:56 PM by jackpilot »
Offline helloo
  • Forum GURU
  • First Name: Mike
« Reply #5 on: June 21, 2019, 11:10:17 PM »
Sounds like a plan.  Thanks.
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #6 on: June 21, 2019, 11:31:44 PM »
If you are handy with a lathe you can quickly whip up a pair of tools to use in a hand press, or even a hammer.
I did 2 full overheads with these 2.
Offline Buster99
  • Forum GURU
  • First Name: Marc
  • Home Location: the Netherlands, Heerlen
« Reply #7 on: June 22, 2019, 04:12:34 PM »
Hi Mick,
That is exactly what I did, it took a few tries but works quite nicely.
Marc
COUNTDOWN TO WF2019
Free Jet Ranger.
by geneb
items/oem from overhead
by gufau
Hi everyone!
by jskibo
Shipping Woes
by Caflyt
Official WF 2019 Route
by dougsnow
by Trevor Hale
More ?'s - annunciators?
by kattz
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
My next sim?
by fsaviator
by blueskydriver
by navymustang
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
