  • *Users: 0
  • *Guests: 53
  • *Total: 53
Author Topic: items/oem from overhead  (Read 688 times)
Offline gufau
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Guy
  • Home Location: Lille
« on: July 23, 2019, 10:03:55 AM »
Hello,
I am looking for OEM part for my B737 frame
I would only need the 2 panels "control and lights" (vertical and horizontal)
Thank you in advance,
Guy
« Last Edit: July 23, 2019, 10:05:03 AM by gufau »
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #1 on: July 23, 2019, 10:14:16 AM »
What model frame do you have
Sent from my Pixel 3 XL using Tapatalk
Offline gufau
  • Forum GURU
  • First Name: Guy
Re: items/oem from overhead
« Reply #2 on: July 24, 2019, 01:50:44 AM »
I think it's a 737-300 but i beleve it's possible to manage the adaptation :
https://zupimages.net/up/19/30/0fd2.jpg
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #3 on: July 24, 2019, 10:44:02 AM »
You will have a hard time locating those two lightplates , many differences.
The other panels would fit no prob.
Can be done though, check with Nick at APHIS
https://www.oncealoft.com/
Offline mickc
  • First Name: Mick
« Reply #4 on: July 24, 2019, 11:03:29 AM »
As Jack said, many differences.   As well as a different number of holes, some are in a slightly different spot.
Attached is a pic of the NG frame for comparison.
You can get them, Phil from Simvionics makes NG ones to fit the classic frame.  Not a cheap or quick exercise though.
Offline gufau
  • Forum GURU
  • First Name: Guy
« Reply #5 on: July 24, 2019, 12:44:37 PM »
Oui, c'est un projet compliqué
Nick n'a pas ces panneaux
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #6 on: July 24, 2019, 03:38:22 PM »
Phil's panels are the Rolls Royce of panels  :2cw:
Offline mickc
  • First Name: Mick
« Reply #7 on: July 24, 2019, 07:00:32 PM »
That they are ;)
Offline gufau
  • Forum GURU
  • First Name: Guy
« Reply #8 on: July 25, 2019, 01:05:40 AM »
<  some are in a slightly different spot >
Which holes are you referring to ?
Offline mickc
  • First Name: Mick
« Reply #9 on: July 25, 2019, 01:53:54 AM »
I cant post a drawing because its not mine to post, but these are the holes in question
Mounting screw hole next to CALL annunciator
CALL Annunciator mounting hole
Attend & Ground call button holes
Equip cooling switches
Backlight connector hole
And obviously the rain repellent switches are gone
Offline gufau
  • Forum GURU
  • First Name: Guy
« Reply #10 on: July 25, 2019, 05:03:56 AM »
It is true that it is not obvious but I thought maybe remove the buttons too, remove the holes of fixations, etc.
I'm going to contact Phil although I would not want to put too much money that even ...
Otherwise, I will resell this frame or mount the other elements and leave as such left to continue to seek the true panels
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #11 on: July 25, 2019, 07:32:07 AM »
I might have the lightplates you search, but in very rough condition. Will send you some pics in a couple of weeks.
As i have 2 frames i decided to sacrifice one frame by cutting out the sections with switch holes and make a aluminum backpanel for the replica lightplates to fit. This solution works out great for me in my current replica panel setup.
Michael
Offline gufau
  • Forum GURU
  • First Name: Guy
« Reply #12 on: July 25, 2019, 09:22:06 AM »
You have frames of the same model as me or are the panels that correspond to mine
I can not wait to see your images
Guy
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #13 on: July 25, 2019, 10:16:32 AM »
I really think my frames are the same type. With the same amount of holes on the same locations.
As i said earlier, very rough condition. I think one also has a crack.
Shoot me a PM in about 3 weeks, so i dont forget.
Michael
Offline gufau
  • Forum GURU
  • First Name: Guy
« Reply #14 on: July 25, 2019, 11:03:52 AM »
ok Michael
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #15 on: August 09, 2019, 10:18:21 AM »
I remembered by myself...
Pic of the lightplates.
They are in way better shape then i remembered. no cracks and paint is good also.
The one lightplate has a coating that is comming loose, behind the coating nice paint.
Just the mounting hardware that is fixed to the lightplates is pretty much missing/damaged on all positions.
The “lights” plate should fit without problems.
The other plate has the “lavatory” light, you dont have the cutout in your frame.
Shoot me a PM for further comms
Michael
Offline gufau
  • Forum GURU
  • First Name: Guy
« Reply #16 on: August 09, 2019, 12:06:59 PM »
pm sent
COUNTDOWN TO WF2019
Hi everyone!
by jskibo
[Today at 08:05:33 AM]
[Today at 03:35:11 AM]
Shipping Woes
by Caflyt
Official WF 2019 Route
by dougsnow
by Trevor Hale
More ?'s - annunciators?
by kattz
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
My next sim?
by fsaviator
by blueskydriver
by navymustang
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
by gufau
[August 09, 2019, 12:06:59 PM]
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
