X-PLANE (Laminar Research) => X-PLANE - Utilities Discussion => Topic started by: jGACaptain on March 17, 2015, 03:08:47 AM
Title: Problem with X-Plane connecting to Pokeys57E
Post by: jGACaptain on March 17, 2015, 03:08:47 AM
Hi Guys,
I have a frustrating problem!
I have loaded the latest pokeysplugin into appropriate resourses/plugin folder, have the latest firmware version on Pokeys57E, but cannot get the connect status to recognise the Pokeys57E in X-Plane.
Here is my pokeys.txt file in the Xplane root dir.
_POKEYS57E
[22421]
Pin1=OUT,0,,sim/cockpit2/engine/actuators/throttle_ratio_all,f,0,0.5
Pin2=OUT,0,,sim/cockpit2/annunciators/master_warning,i,0,0
Pin3=IN_1,0,,sim/cockpit/switches/no_smoking,i,0,0
Pin4=IN_1,0,,sim/cockpit/switches/no_smoking,i,0,1
Pin5=IN_1,0,,sim/cockpit/switches/no_smoking,i,0,2
and here is the log response from X-Plane:
Configuration file opened...
Counting lines...
Correcting ,,...
Reading configuration...New device configuration:  Device NOT FOUND!
Device not present, skipping...
Configuration load complete...
Loaded: C:\X-Plane 10/Resources/plugins/PoKeysPlugin/64/win.xpl (public.xplane.plugins.pokeys).
The device name in the config  matches the pokeys57E device name, and the serial no. matches.
Any clues as to what is wrong?
Title: Re: Problem with X-Plane connecting to Pokeys57E
Post by: 727737Nut on March 17, 2015, 06:19:47 AM
Try reading this informative link
http://forums.x-plane.org/index.php?showtopic=62459&page=7 (http://forums.x-plane.org/index.php?showtopic=62459&page=7)
Hopefully you can get some help thru the forum there.
