May 21, 2024, 12:04:20 PM
722 Guests, 0 Users
  • Online today: 748
Guests: 722
Total: 722
Pictures of my real 727 eng. gauges working
Started by 727737Nut, April 23, 2010, 05:11:07 AM
The EPR gauge is servo driven, Fuel Flow is driven by servo on a pot producing a 0-5Vdc output driving an old gauge set-up from Beta Innovations. The digital mechanical N1, N2, and EGT are driven off the PIC boards Mike Powell and I built and designed. VSI gauge is stock internals with a gutted servo driving the stk dc motor w/ feedback from the stk pot in gauge. All are interfaced thru OC servo cards and SIOC. ALL are working flawlessly now with over 100hrs of operation. The wiring is a little messy as this is a temp set-up in my apartment.
Nice work! When you can mass produce these conversions gimme a holler! I'll take a set of 15.  ;)
Thanks guys! I'll get a video up one of these days. Need to get me a flaps gauge and the other 2 EPR gauges.  Keep your eyes out for me please.
Michael,
I can make your gauges come to life fairly easy, get a set together, with the servo's and i'll build them and write the code. Pm if interested in more details.
jameas
This is a very impressive set up you have.
You talk of using standard servo internals to drive the VSI, does the board handle the increased motor size on the VSI, and what voltage are you driving it with.
thanks
J.
Quote from: jameas on April 24, 2010, 05:56:08 AM
thanks
J.
I am using 5vdc and yes, the cheap servo i gutted has handled the motor fine. Remember, all aviation gauges are set-up to pull low current to reduce overall  current draw on the aircraft.  It actually is more efficient and pulls less amps than the original servo motor!
727Steve
Steve
EAL727Capt
Hey, Nut.......
If you're PM'ing your secrets, PM 'em to me, too.  I'm in the process also.
Great looking work thus far.   Congratulations!
Jay
KTPA
Keep the pointy end up and forward.........
Quote from: EAL727Capt on April 26, 2010, 01:20:33 PM
Hey, Nut.......
Jay
KTPA
Hi Jay,
No secrets, i'm here to help as much as can just like others helped me. :)  What do you need to know?
EAL727Capt
Heya, Rob and thank you for the offer.
I guess, like so many others, I'd like to know exactly which wires go to which components.
My 727 will have the standard 'steam' gauges and not the 'glass' cockpit gauges that you have.
Currently, I'm working on the wiring for the 727-200's landing gear control panel; there's a 16-pin connector and without a proper wiring diagram, its trial-and-error.  I've made a block diagram using Photoshop and am using it as a basic guide in an attempt to determine which wires control the seven (7) Korry switches.   Once I have it all figured out, I'll post it here.
Thank you again for all your help.
Jay
Rob may have already posted that when he and Mike Powell were discussing that here..  Let me see if I can dig up the link to that thread.
Here is the only one I could find.
http://www.cockpitbuilders.com/community/index.php?topic=474.msg3398#msg3398
