April 25, 2024, 01:27:14 AM
362 Guests, 0 Users
  • Online today: 407
Guests: 362
Total: 362
New Sim Computer
Started by sagrada737, May 19, 2021, 09:02:04 AM
Hello All,
I have been testing my Sim in various operating modes with the new Optoma ZH406ST Laser projectors.  I finally settled on some settings that allow inputting 4K (3840 x 2160 each of three projector)resolution, for a 11,520 x 2160 total resolution for the NVIDIA Surround Display that is processed by Pixelwix for use with P3D v4.5.
The 4k display data is downscaled by each projector to HD quality, resulting in a really nice HD 210 degree wrap-around display.  However, this is a lot of graphics data for my single i7 Sim computer to process -- even with the new  NVIDIA RTX-3090 GPU installed.
As a result, I am seeing an occasional and random disengagement of one of the projected displays, which results in an image shift of about 1" on the projection screen.  This "glitch" typically occurs during a turn on the ground or in flight.  It does quickly correct itself, and comes back into proper warp/blend alignment.  If you are not looking for this glitch, it is easy to miss.
However, this behavior was a little disappointing.  Having tested this setup in different configuration modes, I now have it where this display glitch is minimized, but not good enough...    What's the solution?  Spend more money... :)
I have wanted to upgrade my Sim Computer, so this was the excuse I needed.  My single i7 Sim Computer has been a limiting part of the Sim system, considering everything I am running -- hence the computer upgrade.
Here are the specs of the new Sim Computer for those interested:
- Intel Core i9-11900KF 5.3GHz 8-Core CPU
- CPU with Turbo Boost Max
- 32 GB DDR4 4600 MHz RAM
- 2 TB WD SN850 NVMe SSD (very fast read/write)
- 4 TB Seagate IronWolf HD (for VEEAM Backups)
- 8TG WD HD for scenery and other Sim apps
- GigaByte Z590 Vision D Motherboard with WiFi 6
- EK 360 Liquid CPU Cooler
- NVIDIA RTX-3090 GPU
- 1000 Watt Power Supply
- Windows 10 Pro Operating System
This CPU will allow me to run at 5.3 GHz single core under Temp control, with some cooling assist from the IP Cooler I have near the Sim, located in front of the 6dof Motion Platform.  Benchmarks on this CPU setup show that I should see about a 40% speed improvement over my current Sim computer.  In addition, the RTX-3090 was designed to preform best with the newer processors/motherborads, so there may be some improvements there as well.
I should have this new computer installed in the Sim in a couple of weeks.  Hopefully I will be able to report some good news on the actual performance of this new Sim computer setup.
Mike...
You are in the search for the Holy Grail!
But I wish you luck and sincerely hope it makes a step-function difference.  I'll be the first one to duplicate it all if it does!
Awesome new system Mike, and looking forward to you letting us know how things turn out.
My favorite thought, you gotta "Love the White Rabbit"! ;D
Hello All,
I finally have the new Sim Computer completed and integrated into my 737-800 Sim and its 6dof Motion Platform.
I changed the specs slightly on the CPU and installed an Intel i9-11900K CPU instead of the KF version.  This allowed better support of the graphics, which included using a 4th monitor off the Motherboard.
I expected an improvement in performance, and I was not disappointed.  The entire system is new, which allows for a cleaner integration of the systems, eg. CPU, RAM, SSD Storage, GPU, etc.
I ended up running the Intel i9-11900K at 5.1 GHz, which when running P3D v4.5x utilizes about 60% of the CPU, with temps well within acceptable range.  The Nvidia RTX-3090 GPU is running at about 38% utilization, with temps around 46 deg C.
During actual flight tests with, and without the Motion Platform operational, there were significant performance improvements.
The 6dof Motion Platform software has a great deal of operational interaction with P3D, and seems to place a moderate load on system performance.  In any case, compared to my previous i7 computer system, the new computer seems to be running everything smoother.
I'm running some HD airports and some of ORBX TrueEarth scenery, all of which run smoother than before.  If I shut-down the Motion Platform, performance further improves.
As I mentioned, I am using the Optoma ZH406HD projectors for a 3-projector 210 degree wrap around display.  The strategy of feeding P3D 4k display resolution and allowing the projectors down-scale the display to true 1080p HD resolution has worked out nicely.  I am very pleased with the display quality.  Below are a couple of photos taken with my phone camera to give you an idea of the projection quality as seen from the cockpit.  Of course, the display is much more dynamic when sitting in the cockpit.
Now, it is back to working on the AFT part of the flight Deck.
By the way...   The 6dof Motion Platform is robust and powerful enough to allow four adults to sit in the cockpit during a full-motion flight.   This makes it kind of nice to share the Sim with others.  The motion cues are fairly well refined at this point, and I have yet to have anyone get "Sim Motion Sickness".  Once the AFT part of the flight Deck is completed, access will be cramp and somewhat restrictive.  The main isle Observer Seat blocks the exit to cockpit door.  When all this is completed, I'll have to take a fresh look at how best to populate the cockpit.
A follow up to my previous post on the new computer status.
After talking with Fred about Affinity Masks (AM), I decided to play around with AM settings with the new Intel i9 11900K CPU.  My efforts did not yield any improvement in performance.  I subsequently read a post by one of developers on the P3D team.  He stated that with P3D versions 4.4 and higher, that they did not see a need for any use of AM, and that it did not make too much difference if Hyper-Threading was enabled or disabled.
I also tried selective assignment of certain apps to specific Threads.  That did not work well at all, resulting in significant Display stuttering.
At this point, I am not using any Affinity Masks, and I have Hyper-Threading disabled.
To be quite honest, I am not an expert with applying AM to the Sim Computer now running P3D v4.5x, so it may be that there is a combination of AM settings and P3D settings that will help to improve overall performance.  In this regard, I will continue to "tweak" P3D settings.  Like all custom computer/Sim setups, there is no cookie cutter solution, with trial and error the best course of action.
Having said all that, The Sim is fundamentally running very stable with Sim-Avionics as the 737-800 flight model.  I do however notice that the 1080p HD display performance is slightly affected whenever I have the 6dof Motion Platform operational.  In the near future, I am planning on installing P3D v5, which I am told offers performance improvements.
A note on having the Motion Platform operational on a flight...   There is no doubt that the 6dof Motion Platform adds significantly to the Sim Immersion experience.  I must state however, that when flying in turbulent weather conditions, the Motion Platform is true to form, and it can be a rather bumpy flight.  This is not too bad with mild turbulence, but in or near a thunderstorm, much like in the real world, it is a bit too much movement and wears on one's senses during the flight.  Fortunately, I can place the Motion Platform at any time in its "HOLD" position and spare the flight crew during the rough part of the flight.
Lastly...   Any constructive comments on Affinity Masks and Hyper-Threading with Intel's 11th generation CPUs would be appreciated.
n4208t
I have not verified this but a friend of mine who runs a computer store building custom machines said his research showed that these settings make no difference in P3D because P3D essentially only uses a single core.
I personally found that P3dv5 does have some performance improvement but, at least for me, the scenery in v4 and all of the add-ons I have still make 4.5 preferable.
I pretty much fly exclusively in VR these days and VR is definitely the weakest compared to X-plane and FS2020.  At least for me, I cannot get rid of stuttering and CTD's in P3D using an HP Reverb, i9, 3080 and 64 gb of ram.  FS2020 is smooth, stable and the graphics are gorgeous in VR.  I still get a bit of momentary stuttering with some head movement but I think that is due to the head tracking of the Reverb and not the sim.
Steve
Neil Hewitt
Quote from: n4208t on July 13, 2021, 03:50:09 AMI have not verified this but a friend of mine who runs a computer store building custom machines said his research showed that these settings make no difference in P3D because P3D essentially only uses a single core.
No. P3D uses all the cores in your system, or at least up to 6 cores. Yes, the 'main thread' which is where most of the work and in particular the rendering gets done is on a single thread and therefore a single core, which is why you'll generally see one core at 100% all the time, but the other cores are used for some other tasks, primarily loading terrain and textures.
AM is a dark art that some claim can transform your sim. That's not my experience. But if you have Hyper Threading on, the main thread (usually on Core 0) can get blocked by threads running on the second Logical Processor on Physical Core 0 and this can slow the sim down. So, with HT on, it makes sense to use an AM to keep P3D off the second LP. But it makes more sense to use something like Process Lasso to keep *all* work off both LPs on Core 0 so that P3D can have the core to itself.
If you have six physical cores or more, then some people believe it makes sense to turn HT off altogether, as P3D will gain no benefit from running on more than six cores (supposedly; apparently beyond six terrain-loading threads the main thread can get blocked), and six physical cores are better than six LPs on three physical cores, if you see what I mean.
Personally I have HT off on the CPU I have that supports it, and my other CPU is a 6-core without HT support. In neither case do I use an AM or Process Lasso any more, and I am seeing just as good performance as I was when I used both.
But of course YMMV.
FSAddon_boss
Hi Mike, very interesting posts, even for a newby like me  :o
I was wondering how many projectors you have and how did you make your projecting screen (assuming it is a curved screen?).
Kind regards,
Francois
Francois
Francois A. 'Navman' Dumas
retired
Hello Francois,
Thanks for asking about the projectors and screen.  I am using three projectors that are arranged about 60 degrees apart, in a direct projection layout, projecting on a 12 foot diameter curved screen.
The projectors I am using are Optoma ZH406HDR Laser projectors (replaced by the GT1090HDR).  These have the ability to receive up to 4K graphics data, and down-scale it to 1080p HD resolution.
The 12' diameter projector Screen is home-made.  After experimenting with various screen materials, I chose to go with a Formica material, which was available in 12' x 5' size.  I bought two sheets and joined them to create the roughly 22' length that I needed for a 210 degree wrap-around screen.  After experimenting with various screen paints, I ended up using ordinary Kiltz Whit Primer, which yielded very good performance.
One of the reasons why I chose Formica, was that it was inexpensive, at around $150 per sheet.  It is light weight, and when curved, it becomes very strong and stable.  The stability of the projector screen was very important due to the movements of the Motion Platform.  Any "flutter" of the screen is very noticeable in the cockpit, and highly distracting.
There are lots of good choices for Sim Displays.  Do a lot of research before tackling a projection system.  For many folks, using multiple LCD monitors is a far better choice, as the display quality is excellent, and the installation is more compact.
Good luck with your Sim Project.
FSAddon_boss
Thanks Mike !!!! Great info ! I also saw the many large tv screens, but those are very expensive here in Italy. I think 3 projectors with a homemade screen will be cheaper..... and provide a wider space as well. I have lots of space ! Will research further  :)
Francois
retired
#10
Hello Francios,
Definitely more research on your part is needed -- respectfully speaking.
Actually, going with a three LCD monitor system would be a lot cheaper, compared to a three projector/screen setup.
I would say that in your case, where you are just getting started with your Sim Project, that you should start with a single LCD monitor.  Use that as you build up/debug the rest of your Sim.  Once you have the Sim close to being fully operational, then it may be better timing to consider a more complex Display System.
Moving straight into a multi-projection display system is asking for added difficulty -- especially if funds are tight for your Sim Project.  There is no free lunch in the Sim world.  Building a full-scale Sim is just plain expensive.
FSAddon_boss
Yes, you are right. The display system is the last phase of my project. But it does make a difference for space requirements, so that is the main reason I am looking into it already. Three monitors will certainly make things more compact.
But don't worry, I am not the one jumping to decisions anytime soon.... just trying to get an idea of all the things I will need to consider, now and down the road.
Francois
retired
