Microsoft FSX => FSX - General Discussion => Topic started by: shaneb on January 02, 2012, 05:43:28 PM
Hey guys,
I have been trying for a while now to get the fuel xflow working and did an internet search to see if anyone had a solution to the xflow issue with the default Lear 45 and seems no one has a solution, or at least one I could find
Last night, I accidentally found a workable solution while playing around with a GA aircraft. I found that the offset that you would think controls the Lear 45 will not. I did find that offset 3880 (reciprocating engine 1 tank selector) will control the selection of left, right and center fuel tank on the Lear with parameters (2) being left, (3) being right, and (1) being all tanks. This allows me to "better simulate" fuel xflow in the Lear . .it is not 100% correct but closer . .at least it simulates it and I can control fuel "use" from specific fuel tanks.
I thought I would share this in case this is an issue with any other default FSX jets. Seems I read somewhere that the default 737 has an issue with xflow, but I do not know the operation of the 737 or if this may apply to that aircraft. I know most of you use addon aircraft but thought it might apply to someone.
