May 19, 2024, 07:12:35 PM
45 Guests, 0 Users
  • Online today: 46
Guests: 45
Total: 45
fsx undocking window how do you remove aircraft panels?
Started by stinger, August 25, 2013, 11:37:18 AM
stinger
trying to get my three projector setup working at the moment I am simply stretching the fsx image but its giving me stutters especially on the ground now I've been looking on ivar hestnes pdf about visual setups but I have a question I understand how to undock the individual windows then he says press left arrow key and shift key to get your side view! trouble is I can't seem to then remove the aircraft window frames which are in the way any ideas? I know in the front view if I right click on cockpit then cockpit again then close the window I get my clear view but this doesn't seem to work on the side views it must be easy I just can't find the keys to press :huh: thanks.
You need to go into the aircraft folder in fsx, then panel folder if remember correctly, and the put two "//" in front of "panel=737-800 or interior=737-800 or something like that.
Long time since I did it, so cant remember exactly the filename, but is pretty  easy to do when you find it ;-)
stinger
thanks ivar still not quite sure so I need to go into the configuration file to do this then? :huh:
Assuming that your FSX is located in C:\FSX and you are using default 737-800 plane, then:
Open folder
C:\FSX\SimObjects\Airplanes\B737_800\model
Open file model.cfg in Notepad.
change the last line like this:
[models]
normal=B737_800
//interior=B737_800_interior
Save file.
stinger
