May 15, 2024, 07:54:07 PM
724 Guests, 0 Users
Guests: 724
Total: 724
CP Flight WXR Panel / Cargo Fire panel questions
Started by AngeloC, March 02, 2017, 07:35:44 AM
AngeloC
Hey guys, running FSX-SE, Project Magenta and have the CP Flight MCP Pro with WXR and Fire Panel connected. For some odd reason the Cargo Fire Aft Arm button sends pause (P) command to the sim.
Prior this on the WXR panel there was a small white square button that was assignable to any function you would want and I am fairly sure that is where pause used to be. I would like to make an assignment there for a key board press.
I contacted CP Flight for assistance and they said they don't know and seek PM for help. Tried PM but no reply so far, can anyone help me out? Ive looked and looked and cant find anything on how to set any instructions on the CP equipment.
I don't own any cp flight equipment but if its sending a keystroke directly to FSX then wouldn't it be possible to just change the key assignments directly from within the controls/button key presses page or via Fsuipc?
In the PM manual there should be a list of keystrokes/offsets also. As I have never used cp flight equipment Im just guessing here.
AngeloC
FSUIPC doesnt see it as a button though. I can press anything on the CP Flight gear and its not being seen by FSUIPC or yes I would of done that. I am not sure how this even got set as so, no clue where to look to change it either...
Scratching my head.
Please post your mcp.ini text file and I will look at...
Also, read and check this:
http://www.cpflight.com/sito/dettagli/pm.asp
Did you by chance recently update your PM programs or any Windows updates? If so, that could be where the changes started. Therefore, either rollback your files or you hunt the problem down.
For the hunt, I looked at my MCP.ini text file and there are some entries you need too look at on yours:
                              / For CPFlight 737 MCP hardware www.cpflight.com
ForceHardwareLight=Off
UseInstLight=Off
IgnoreBattery=Off
                              / Avionics (Battery)
IgnoreAvionics=Off
DisableFSMessage=Off
                              / Window
NoMenu=Off
PauseMetric=Off
                              / sets Pause
????????????????CargoReset=Off
                              / Console only)
CargoPause=On
                              / (CP Center Console only)
CPFlightIO=On
CPFlightComm= 4????????????????
My questions:
1. In between my finger pointers, you will see the CargoPause= ...is yours On or Off?
2. Does your CPFlight MCP work normally right now?
3. What is your number for CPFlightComm= ...port number?
4. Your FSUIPC interface screen is not going too see these buttons, but FSUIPC is there in a different way, did you checkout the link I posted in the previous reply?
5. The small white button on the WXR panel that was assignable before, how did you assign it in the past...what method?
That is about as much as I can say, without seeing your files. The main thing is, if everything was working and it changed, we need too find out what cause the change along with fixing it; otherwise, this will happen again and could be much worse.
AngeloC
Quote from: blueskydriver on March 02, 2017, 09:54:20 AM
Here is the .ini and I see what you are saying now.
[Project Magenta MCP]
Build#515
[Display]
Title=On
Menu=Off
WindowName=MCP (Active) Press Ctrl-L for Logger, Esc For Menu
Topmost=Off
FSWindow=Off
Minimized=Off
                              / Starts up minimized
NoMinimize=Off
[User]
Log=On
SerialLog=Off
CycleMilliSeconds= 50
                              / set to 50-70 ms
Top= 0
Left= 0
                              / program
Width737= 2400
Height737= 570
Width747= 15360
Height747= 3345
Width777= 11925
Height777= 2460
                              / various types
MCPType=737
Intervent737=On
                              / for the 737
ClassicEFISSel=Off
                              / APP/VOR/MAP/PLN ARC and CTR
DelayMouseClick=On
                              / to On
Font=mcpfont
FontFactor= 1.27
[VNAV]
DescentSpeedControl=On
                              / speed with the throttle
[Aircraft]
[PROJECT MAGENTA 737-800 PAINT1 (DEFAULT)]
[D:\STEAM\STEAMAPPS\COMMON\FSX\SIMOBJECTS\AIRPLANES\PROJECT MAGENTA 738\PMX737-800.AIR]
MinIAS= 100
                              / Minimum selectable airspeed
DefaultIAS= 100
DefaultAltitude= 10000
                              / on startup
AutoHDG=On
AutoVS=Off
MachAltitude= 0
                              / 23450), 0 disables
AutoCRS=Off
AllowStabTrimOverride=Off
StabTrimDeflect= 6000
StabTrimOverrideActive=Off
                              / be active
Rollout=On
DisableAdd20Kts=Off
                              / TOGA if set to On
AllowAPOnGround=Off
NoModeAfterTOGA=Off
                              / after TOGA mode
UsePanel=On
PushButton=Off
                              / for SPD, ALT and HDG
SpeedProtect=Off
                              / modes
SELCurrentSpeed=On
                              / for the first time
TerrAlt=Off
                              / Alternate Terrain Mode
Flare= 20
N1ref= 95
N1TOref= 98.6
N1GAref= 95.1
N1CLBref= 91.2
N1CRZref= 93
ThrRedAlt= 1000
                              / only if no CDU detected
MaxROC= 6000
MaxROD= 6000
ClimbThrustLimiter=On
                              / during FLCH/LVLCHNG climbs
Climb2000Spd=Off
                              / of less than 2400 ft
FlightIdle= 10
ApproachIdle= 15
                              / (default 10% and 15%)
UsePMAutobrakes=On
                              / the same time
DisableAutobrakes=On
                              / System
DisableBrakes=On
                              / has to be off
BrakeFactor= 0
                              / 100%
BrkDiscPark=On
ParkNeedsBrk=Off
                              / Pressed to engage
UsepmNavSounds=Off
                              / Offsets
StbySets1200=Off
                              / standby is selected
SwapCRS=Off
                              / Swaps CRS 1 and CRS 2
[Input]
MouseWheel=On
MouseWheelInvert=On
FSBusWriteBack=Off
[Autopilot]
APProjectMagenta=Off
                              / the FS autopilot
APBankFactor= 70
APPitchFactor= 20
                              / the corrections
DynamicPitch=On
                              / the FS autopilot
DynamicUseLoHi=On
DynamicPitchLow= 20
DynamicPitchHigh= 11
                              / kts) values
DynamicPitchTAS=Off
                              / Currently Disabled
                              / and Bank modes
[Hardware Connections]
                              / e.g. enter = 2 for COM2:
                              / www.flypfc.com
PFCComm= 0
PFC9600=Off
CautionThroughPass=Off
                              / to 0x5534
UseInstLight=Off
IgnoreBattery=Off
IgnoreAvionics=Off
                              / Window
NoMenu=Off
PauseMetric=Off
                              / sets Pause
CargoReset=Off
                              / Console only)
CargoPause=On
CPFlightIO=On
CPFlightComm= 8
DisableMIP=Off
FDS_G1_Comm= 0
                              / On/Off
FDSGlare=Off
                              / For Daken IFS Hardware
DakenSkys_IFS_Comm= 0
                              / FSC MIP Hardware
FSCMIPComm= 0
FSCMIPInvertGear=Off
      /Inverts Gear Direction
FSCMIPInvertSixPack=Off
                              / FSC Throttle Hardware Comm
                              / http://www.flightsimulatorcenter.com
FSCThrottleQuadrantComm= 9
FSCNOTMotorized=Off
FSCTQMotorDisable=Off
FSCTQTrimMotorDisable=Off
FSCTQTrimSpeed= 30
FSCTQInvertTrim=Off
      /Inverts Trim Motor Direction
FSCTQInvertTrimWheel=Off
FSCTQTrimOffset0= 60
FSCTQTrimOffset10= 142
FSCTQInvertSpoiler=On
FSCTQInvertSpoilerMotor=Off
FSCTQCalib= 0
FSCTQAdjust= 0
FSCSplArmPos= 208
      /Sets Spoiler Arm Position
FSCRevPct= 35
FSCThrottle1Min= 54
FSCThrottle1Mid= 128
FSCThrottle1Max= 243
FSCThrottle2Min= 54
FSCThrottle2Mid= 128
FSCThrottle2Max= 241
FSCReverser1Min= 0
FSCReverser1Max= 151
FSCReverser2Min= 0
FSCReverser2Max= 122
FSCSpoilerMax= 249
FSCSpoilerMin= 0
FSCSingleThrottle= 0
FSCSingleReverser= 0
FSCThrIntervent=Off
                              / FSC Throttle Hardware Ver 3
                              / Cockpitsonic EHID
                              / http://www.cockpitsonic.com
EHIDComm=Off
                              / or IP Address
                              / ELAN MCP hardware
ElanComm= 0
ElanBaudRate=
                              / Aerosoft 747 MCP hardware www.mcp747.com
AerosoftComm= 0
AerosoftFPV= 14
AerosoftDHRST= 0
/EicasButton1=???
                              / EicasButton10=87)
[EPIC]
DisableRemoteMCP=Off
                              / via FSUIPC
                              / axis
[Extra]
NoFSCOptions=Off
Okay now that we know this, my actual plan was to use the white button on wxr radar to send a key press of CTRL+SHIFT+A to clear UT2 traffic. Is this possible at all
Secondly I have never been able to fully trust the PM AutoPilot so I use the default for  now, what are the best values to get realisitc AP operation where it doesn't hunt the localizer or oscollate up and down on the GS?
Right now for best results I am using the FS Autopilot as well. The PM Autopilot just hunts way too much.
Hey Angelo,
Hang in there, I will get some more answers for you soon... Tell me what you figured out about the cargo button and the WXR white button, if anything thus far.
