Main => General Discussion Board. => Topic started by: jackpilot on May 14, 2010, 12:33:53 PM
Title: Network question
Post by: jackpilot on May 14, 2010, 12:33:53 PM
My oldest computer (Win 2000)plays tricks,others are XP
He behaves like a server having access to other computers but not allowing them to acess shared documents without logging on. A little box opens asking for User name, if I type administrator he opens the gates.
All computers are on the same group and all shared files are allowed for "Everyone"
At one point I shared the HD "C" on that computer and it solved the problem. Without any change, it does not work anymore even if the HD is shared ???
I 'm not "fluent" in that domaine.. any help?
Title: Re: Network question
Post by: Efe on May 14, 2010, 02:06:40 PM
Have you tried giving full access to all other computers explicitly (by name) as opposed to just granting it to everyone? That might do it.
Post by: Bob Reed on May 14, 2010, 02:51:48 PM
Quote from: jackpilot on May 14, 2010, 12:33:53 PM
Try turning the guest account on. I am trying to think way back but I think that is what you are looking for.
Post by: jackpilot on May 14, 2010, 03:46:59 PM
aouhh dou aï  dou zat???
Post by: XOrionFE on May 14, 2010, 04:32:05 PM
In you network adapter properties make sure you have file and printer sharing still installed and checked.  Also make sure in the servIces section in control panel that the "server" service is running.  You also should make sure that for the shared folders that the share permissions as well as the file and folder permissions are set to Everyone Full Control.
If none of those work let me know and we can continue troubleshooting.
Post by: jackpilot on May 14, 2010, 06:26:00 PM
Fiouuuuu!
will be over and out for the week end...
Will report on monday
Gone fishing  ...yes.. ice is getting thin way up here.
Cheers friends.
JP
Post by: jackpilot on May 17, 2010, 02:21:02 PM
Thanks Scott: was all ok . Grrrrr
But in the meantime, as I was checking everything related to the word "Network"I found out what the "Client account" was and activating it solved the problem....Thanks Bob!!
Thank you friends...one thing less to worry about. ;D
