(https://www.cockpitbuilders.com/proxy.php?request=http%3A%2F%2Fsimflight.com%2Fwp-content%2Fuploads%2F2009%2F12%2Fnp-panels-b777_main_mfd-250x187.jpg&hash=80c0593ae514a219d77a3d651bb3b4ea98722fc9)
According to Simflight.com. Nikolay Poriazov has published his ‘Boeing B777′ panel under the NPSimpanels brand name. From what they are reporting, you basically get 3 detailed B777 panels, a camera file, custom animations, a photoreal 2D panel and more. Using a single PC solution, with multiple monitors you would be able to un-dock the instruments and drag them to your selected monitors.
Main Panel
- 3 detailed Boeing 777-200ER,777-200LR 777-300 Panels
- Camera
- Custom Animations,2 Overhead Panels
- Photorealistic 2D panel including multiple views:Overhead,Pedestal,Radio audio.fmc.F/O Efis panel
- Multi-Primary Flight Display,True Mode Switch North referenc,Autobracke,Brake Accumulator
- Captan-F/O Multi-Function display:Engine,STAT,HYD,ELEC,DOOR,GEAR,FCTL,Camera,Electronic checklist Atc.,
Virtual cockpitOverheadSimulated systems : APU, engine startup, air conditioning,Hydraulic System,
Fuel System, Electrical System, Bleed Air Condition cabin altitude control panel, Lights control panel,
Pedestal Eng-Secondary - Multi-Function display STAT,HYD,ELEC,DOOR,GEAR,FCTL Atc.,Engines Masters, Engines Starter,
Rudder Trim, Parking brake lever, flaps and spoilers levers
Flight Management Computer
- IDENT Aircraft POS INIT Inertial Reference System position initialization
- PERF INIT Performance initialization â€" aircraft weights, fuel reserves, cruise altitude
- THRUST LIM Selecting reference thrust limits, reduced and derated thrust.
- TAKEOFF REF Takeoff VNAV profile, takeoff reference speeds
- APPROACH REF Approach reference speeds
- ACT RTE 1 ICAO code of origin-destination airport
- FlightPlan data FSX
- AFT AISLE
- 1.AUDIO PANEL Transmit comm1,Transmit all,Transmit comm2 ATC; Ident VOR L VOR R ADF L ADF R.MKR.
- 2.RADIOPANEL VHF L R(COM1 2) (COM2)This mode displays Active and Standby VHF LR (COM1 2 )frequency. Tuning knob changes Standby frequency, which canbe swapped into Active window by pressing Swap Button.
- 3.Transponder
Find Out More HERE (http://secure.simmarket.com/npsimpanels-boeing-b777-panel.phtml)
