Microsoft FSX => FSX - General Discussion => Topic started by: karijno on August 30, 2011, 01:57:53 AM
Title: Flight Control Replay Voice Edition (Voice Command Recognition and record voice)
Post by: karijno on August 30, 2011, 01:57:53 AM
Flight Control Replay Voice Edition (Voice Command Recognition and record voice as an overlay to the recorded flight)
Newly available exclusively via simMarket, Fabio Merlo's Flight Control Replay Voice Edition is the follow on to Version 1.1 of the author's tool which, amongst other things, allows you to record and play back flight situations with a wide variety of components monitored and recorded, additionally allowing playback in Google Earth if you prefer. In addition to the previos functionality, the Voice Edition will now allow you to not only control the software using your voice, but also to record your voice as an overlay to the recorded flight.
The software is available for Microsoft Flight Simulator X only, and it might be worth noting that Windows XP is not listed as a supported operating system. For a complete run down of features and to purchase your copy, please visit the product page at simMarket, here. There's an upgrade price option for users of the aforementioned Version 1.1 as well.
Flight Control Replay main Features are:
- Voice Command Recognition for all record and play features of FCR. Now you can speak to software and it records, play, go forward and go backward according with your voice command. (NEW!)
- Record a flight situation and also your voice during flight. ( NEW!)
- Enable / Disable Voice recognition directly with a button in main User interface.
- Flight simulator X Connection
- Record a flight info with unlimited length (Aircraft model , position, heading, bank etcetc).
- Export all recorded Flight situation for view it in Google Earth 3D and Google Maps 2D.- Simulation Variables recorded:
Plane Latitude
Plane Longitude
Plane Altitude
Plane Pitch Degrees
Plane Bank Degrees
Plane Heading Degrees True
Flaps
Gear
Brake Position
Engines Throttle Position
Fuel Tanks Level
World reference position
- Play / Pause saved Recorded flight in original Flight Situation (if available).
- Fast forward backward play.
- Start flight from an entry point of a recorded flight that user can define.
- User can choose sample rate for record a flight (6 times per second , 1 time per second, Visual Frame per second, every 4 seconds and Automatic ).
- Zoom In and Zoom Out flight simulator point of view from FCR client.
- User can change camera view from FCR client.
- Stop playback at any position to continue manually with FCR yellow slider.
- Show time stamp inside Flight simulator during play.
- User can define an hardware shortcut for start / stop recording, start / stop playing and forward and backward (this is useful if users use full screen FlightSim option)
- User can choose custom file path where FCR put file with flight recorded (.FCR and all Microsoft Flight Simulator files attached)
