May 17, 2024, 01:06:23 PM
502 Guests, 0 Users
  • Online today: 736
Guests: 502
Total: 502
Instructor Station - Luis Gordo
ISLOGO
What is Instructor Station ?
In flight simulation, an Instructor Operator Station (IOS) is designed to assist the instructor in controlling the simulation training environment and monitoring all aspects of pilot/crew performance in the simulator. The instructor can control, via this software, all functions such as aircraft position and systems, meteorological, environmental, and situational parameters.
The Instructor Station is meant to assist Aviation Professionals, Flight Simulation Enthusiasts and Home Cockpit Builders using Microsoft® Flight Simulator (FS) 2004™, FSX™ and ESP™, Lockheed Martin Prepar3D® and X-Plane®.
The Instructor Station allows setting the aircraft on an approach to a runway of choice under any weather conditions, start-up and shutdown network computers (fully customizable), program or set aircraft system failures at any moment, calculate the amount of fuel required for a flight and load it to the aircraft, record flight performance (approaches, manoeuvres, landings, take-offs, etc.) and plot it graphically, and many other things!
Compatible with all types of aircraft! It is also a great tool for anybody who wants to control the flight simulator externally.
Many features are also available for Project Magenta users (pmSystems, Glass Cockpit, CDU/MCDU, MCP/FCU), AST & FMGS JeeHell users.
Developed by a pilot, engineer & flight simulation enthusiast.
TRY THE DEMO AND ORDER YOUR LICENSE TODAY !!
remote PC start up
Started by Jurgen, May 30, 2011, 09:25:43 PM
Jurgen
Hi, I am having problems getting the remote PC start up/shut-down working. the istation runs on a client PC widefs and FSUIP being connected.
Jurgen
saabpilot
Well - it seems a bit tricky to implement. Maybe someone can shed a bit of light on how?
I am using PM CDU shutdown instead and it works flawlessly.
But it would be nice, but maybe not 100% necessary, to have a remote-start-up.
Bjorn
Fly Safe - Low and slow
Efe
The way we implemented it (if I'm not misunderstanding what the topic of conversation is) is by having the remote startup scripts for the other PCs on the startup procedures list of the server. So you physically turn on the main computer, which in turn triggers the other PCs to turn on around relatively the same time. It also adds to the effect if you change the opening background images of the PCs to a company logo or your personal design, so during startup (till the PM visuals kick in) the MIP has the company logos.
__________________
Efe
saabpilot
Hello Efe !
Just what I need, but does not know how to do it  :-[
Do you use "Wake on LAN" for the clients ?  I have never managed to get that working.
( A bit Computer illiterate  :D )
Bjorn
Efe
__________________
Efe
What Jurgen is talking about is getting the Instructor Station (IS) working on a remote computer using FSUIPC and WideFS.
Did you install the IS program according to the instructions? Re-read the Remote Startup Portion that is used with IS on pages 15 and 16 of the instructions. Then you look at the bottom of the tab for the log to see what happens.
From instructions: "At the bottom part of the tab, there is a log window, in which different messages related to the Network and other important program actions are recorded. You can save this to a file (tech support) or discard if wished"
Also, if you're doing the wake-on-lan (WOL) functions right on the remote PC's. Check to make sure the Network Interface Card (NIC) has the correct settings turned on. And, remember there are settings in the BIOS to check, as well as that not all NIC cards have WOL functions. So, be sure they can support it first. Download FUSION WOL (free or demo mode) to check that the WOL works on the cards first, before trying to do it with IS. That way you know it's not your cards causing the problems...
@Bjorn, Efe is running what sounds like a batch file program to initate the WOL of the remote PC's. That is what IS can do; however, Efe what program are you using exactly to start the remotes? Also, Bjorn are you having the sim related programs (like PM, WideFS) start-up when you power on your remote PC's, by placing a copy of the program Icons in the Start-Up folder(s)? You could do it that way and then use a WOL program to start the remote PC's for you...
BSD
saabpilot
Hi BSD,
Thanks for the update - have d/l the WOL program now and will give it a try.
All my FS programs auto starts (via a batchfile) when the PC:s are powered on.
Best,
Bjorn
luisgordo
Hi folks,
Glad to see you are figuring things out.  Let me know if you need any help.
Instructor Station
www.iStationGordo.com
Flight Data Recorder Mobile
http://www.istationgordo.com/instructorstation/fdr
