Hi all,
I'm working on the side walls of my home sim. The one area I'm having issues finding online is the document holder.
Does anyone have a link to buy as a pair or single?
Looking online, I have only seen you can purchase them as part of a package along with the rest of the sidewall accessories.
Any help would be much appreciated.
Thanks, Gareth :)
Not sure what you are talking about ..picture?
I am sure he is referring to this...
Try these? Make your own..
https://www.amazon.com/Clipboard-clips-Rubber-Holds-Paper/dp/B01HLP0JGG/ref=sr_1_2_sspa?ie=UTF8&qid=1513178341&sr=8-2-spons&keywords=clipboard+clips&psc=1 (https://www.amazon.com/Clipboard-clips-Rubber-Holds-Paper/dp/B01HLP0JGG/ref=sr_1_2_sspa?ie=UTF8&qid=1513178341&sr=8-2-spons&keywords=clipboard+clips&psc=1)
(https://images-na.ssl-images-amazon.com/images/I/613bDVwR5bL._SL1080_.jpg)
Sorry, I don't think I made it clear enough. I was referring to the holder next to the cup holder actually built into the sidewall. I believe it may be called the 'Document Holder'?
Thanks, Gareth
Gareth,
Maybe you could save the attached image and point to it with an arrow in Paint and then post it back here..
That area has undergone many variations
Sorry. Attached. Gareth.
Used to be available, like the window handles...
Did a quick search but no results.
Put your thinking cap on, browse your local hardware shops
and make it out of something obviously not intended for that ! :D
Small paper bin, mailbox slot, etc etc
Or 3D print one.
Check last line of the text and scroll down for picture
http://www.flightdecksolutions.com/forum/viewtopic.php?t=5631&postdays=0&postorder=asc&highlight=printed&start=37 (http://www.flightdecksolutions.com/forum/viewtopic.php?t=5631&postdays=0&postorder=asc&highlight=printed&start=37)
http://www.flightdecksolutions.com/forum/viewtopic.php?t=5631&postdays=0&postorder=asc&highlight=printed&start=47 (http://www.flightdecksolutions.com/forum/viewtopic.php?t=5631&postdays=0&postorder=asc&highlight=printed&start=47)
So far, I just cut, glued and made it from drawing paper, grey duct tape and piece of PVC table mat :)
Like this:
(https://lh3.googleusercontent.com/cZXYeyoxlPbc_W59leVLK3puPbBVi2LHvKvjx6jDfASbOHKGXvlcaxxYW_ROvu6uEmU4s5BXY40z5F5LGn3uOvtnVYYqOktvS-KNMY-cJ_401PV4yZ04IaJOx4x0QJHTzZWtklq_cK5lRW_m4MXQspy1v2-iotkojqwLf06uHconvvt7NyIDdSRxKeLzKrT-ZD3_2rAW0bQDhV6fqXy8VM7n0XKSmvfbIYw5Pzui0hrtvyZQM_zBqNG3tlXepaP4q_fkD6kniglgcyjKyIc7omYzX4JMft4i47XEVw05A9DM1ilvn1WzDXMepFH1iCm2G3wbJXtL9aKRnh45epwbCSQGROlmxfQHwEagBVfBNJfw1YZndUuVjwQ9mJh-q9BZQFRE6uuerTtD8vpkCSwVI5wdlr_vC3-K5lYqODRM4Snu2GWrlUs7PRSdrZYTr0Ol043_EkDZ9aFQw0ErRGRH1_c8WYV1uDZltd2t_982Z28OguWPWV1p-mu7kGP6fe1bfFe861ySucGzWBTlyitGSvXeBC9-w-Fp4M_B0Hw-qrajsLTi0PhGPBmPet1KtYpkW-G9bUVN-lnLxLSNUGnbpVfoyhDddYY8L-Q55vOTYw=w1387-h781-no)
You really don't need anything more in a dark cockpit. :angel:
:2cw:
I have made many of these in PVC, painted in RAL7011 for AUD $30.00each + shipping.
Cheers Gwyn
Hi Gwyn,
Do you have any pictures please?
Gareth
Hi Gareth,
Here they are installed in my sim.
[smg id=1367]
[smg id=1368]
External faceplate size = 175mm x 50mm
Internal pocket size = 143mm x 32mm & 122mm deep
I can make custom sizing if you wish.
Cheers Gwyn
