May 16, 2024, 07:36:35 AM
743 Guests, 0 Users
Guests: 743
Total: 743
B737 DIY Gauges servo gears ??
Started by ifeliciano, November 08, 2017, 06:13:23 AM
ifeliciano
What size/ratio gears are most using on your servos for your DIY gauges?
Most gauges I convert  I use 12t/24t gears, so 2:1.   Most servos only have 180 degrees of travel, but the needles need roughly 270-300 degrees depending on the gauge.  2:1 gives you enough travel and avoids using the area near the endstops.
Some need more, like the Diff pressure gauge, where the needles go almost 360 degrees, for that i used 15t/40t
Sweet! I will convert all my gauges like this.
ifeliciano
ifeliciano
To expand on this topic. What type servo are you all using? Digital or Analog(ue)? Does it matter?
In my experience, digital ones are more stable & accurate, but draw more power and tend to be a bit noisier.
Also digital ones tend to have more travel than analogue ones
ifeliciano
Mick,
Looking at the picture you attached previously, it seems the gears already have splines to mount directly to the servo. Is that correct or were the gears drilled and glued to the servo?
Quote from: ifeliciano on November 25, 2017, 06:52:01 AM
Mick,
Usually the centre hole is drilled out and The star shaped servo horn is pressed into it and secured with epoxy
Quote from: Bob Reed on November 25, 2017, 07:08:48 AM
So where does one buy these gears?
I get mine from RS components. They are made from Delrin.
You can get cheaper ones on EBay etc but they are much lower quality and harder to drill etc.
ifeliciano
Bob,
A lot of robotics web sites sell gear sets.
Bob,
I've bought lots of small bits from technobots: have a look here!
https://www.technobotsonline.com/plastic-model-gears.html
ifeliciano
Quote from: mickc on November 25, 2017, 11:31:43 AM
What P/N gears do you "normally" use? Allied Electronics is the RS Components rep in the US.
Quote from: ifeliciano on November 25, 2017, 10:17:29 PM
This is the RS series I use
https://www.alliedelec.com/gears/gears/?navigation=4294708323&customfilter=Brand%2fSeries%3a285537+Series
ifeliciano
