May 21, 2024, 03:11:38 AM
738 Guests, 0 Users
  • Online today: 748
Guests: 738
Total: 738
Administrator Rights?
Started by Boeing Skunk Works, November 30, 2009, 11:52:33 PM
There's no OS forum so I thought I'd just put this in here for a question.
Why, in XP Home if I try to download a random file from the internet it says "access restricted" or "You must be logged on as an Administrator to perfom this function", etc., etc. It doesn't do this all the time and hasn't happened in awhile. It did it when I tried to install the 'Eye of IVAO'. (It's a program allowing you to see controller positions and flights. Similar to the old ServInfo.)
I AM logged on as an Administrator as the Owner Admin. In Safe Mode I'm able to download these type of files logged in as the 'real' admin.
This is what pisses me off about XP Home. There is not even an option to log on at the Welcome screen to log on as the 'real' administrator.
If it auto-logs me on as the Owner (administrator), why can't I perform the same functions as the Administrator account found in Safe Mode, and why isn't there an option to log-on as this at the Welcome screen?
GGGRRRRRRR!  >:( >:( >:(
Is there a registry hack or other setting I can use to be permanently, and always logged on as the 'real' administrator?
Hey Mike,
At the Run menu Did you type
control userpasswords2
this allows you to select which user to configure to "Always log into the computer with"
and will also allow you to bypass the "User screen" If you like.
What happens if I remove the 'User' member? I don't want to use passwords since I'm the only one who uses these systems.
If I remove the 'User' (admin) will it default to the 'real' administrator at boot?
When I look at Administrator members under 'Groups', User is in there, but being logged on as this still doesn't grant unrestricted access to all fuctions all of the time. Mostly for installing random files or programs.
It says in the Administrator Group that those in this group have unrestricted access to the entire computer system, but that doesn't seem to be true.
Why does it do this?
Untill we understand how your users are configured, I would not delete any users! You may find yourself locked out of your own computer. Never ran into this in home, but I only own one copy of that. Looking.
I'll post more on this later. I'm heading out for Bratislava. There is a controller exam in just a bit.
