May 16, 2024, 07:02:45 AM
737 Guests, 0 Users
Guests: 737
Total: 737
Servos vs. Stepping Motors
Started by EAL727Capt, July 10, 2010, 12:31:47 PM
EAL727Capt
I've gutted most of my steam instruments for the B727, dumping the synchro mechanisims and am looking for opinions on whether to purchase RC-type servos or stepping motors to drive them.
I'm looking for the smoothest, most realistic operation (who isn't?) am hoping for some advice.
Based upon personal experience, which works better?
Thank you very much,
Jay
KPTA
Keep the pointy end up and forward.........
727/737Nut needs to jump in here!! He has been down this street.
Yep, he's your 727 guage man for sure.
I wanted something faster so I'm using minitors behind my MIP.
Go with servos, these servos will fit inside a 2" gauge with ease, smooth and programmable to boot!
http://www.servocity.com/html/hs-5045hb_servo.html
servocity.com has the gears you need as well to get more than 180deg movement.   What i did was press a nylon gear on the stock synchro shaft, epoxy a small standoff in the gauge to mount servo to. Takes 30mins to an hour and worrks great using SIOC and oc servo card.
EAL727Capt
Gents, and, in particular, Rob.
Thank you, as always, for the replies.   Based upon what I've researched thus far and on Rob's recommendation, it looks like servos are the way to go.
When would there be an instance when stepping motors should be used?  With very limited knowledge on the subject, I'd say for 360-degree operations (like altimeters, ADF/RMIs, etc.).  Can anyone confirm?
Thank you again,
Jay
KTPA
No need to then either,  you need to buy an electric altimeter and convert it or use a 5 turn pot and thru gearing it acts a regular altimeter. Every 10K feet = 1 turn on the pot   I have gutted servos, desoldered the motor and pot and just used the electronics with great success!  :)   Servo's are the esiest route or some facsimile of them.
