Hello,
I´m currently working on the sidewalls but something does go wrong.
(https://www.cockpitbuilders.com/proxy.php?request=http%3A%2F%2Ffs5.directupload.net%2Fimages%2F151104%2Ftemp%2Ffjh6bhyp.jpg&hash=8b776746454b4b9c74bd2dda6f1fca25e88d4f47) (http://www.directupload.net/file/d/4161/fjh6bhyp_jpg.htm)
I´m not able to transfer measures from cockpit-pictures to my homecockpit.
Cupholder, oxygenmask etc. are incorrectly positioned.
Perhabs somebody will be so kindly, to have a look at my measures.
.....where is bug?
(https://www.cockpitbuilders.com/proxy.php?request=http%3A%2F%2Ffs5.directupload.net%2Fimages%2F151104%2Ftemp%2Fcgs4fkdk.jpg&hash=46496fd6d435290803d9f3605664013a1fb285be) (http://www.directupload.net/file/d/4161/cgs4fkdk_jpg.htm)
thank´s and so long, Thomas
Hello Thomas,
One thing is the Oxygen Mask boxes, dimensions of the real ones is 147x114mm (top panel).
The other dimensions I do not know for certain.
HTH,
Marc
Hi Marc...
.....that´s a good first indication to clarify some of the inconsistencies!
I´ll going to test it immediately.
thanks
Hello Thomas,
I hope that you get it figured out :)
In case you need other dimensions for the oxygen mask boxes, just let me know.
Marc
Thomas,
the best sidewall dimensions can be found here:
http://www.fagerjord.org/images/cockpit/boeing_737_sidewall_construction.pdf
Andreas
Hi, Andreas
That was the plan, I build the sidewalls. I was realy happy, to find this side.
Slowly, it comes light in the dark.
- the measures from cupholder must be bigger than 150mmx155mm, perhabs 185mm x 185mm.
- document pocket might be 160mm x 50mm.
- the post might be 80mm x 50mm
(https://www.cockpitbuilders.com/proxy.php?request=http%3A%2F%2Ffs5.directupload.net%2Fimages%2F151105%2Ftemp%2F9i4ozkbo.jpg&hash=9882ea8341fd886157042ce31b0c13696df01a49) (http://www.directupload.net/file/d/4162/9i4ozkbo_jpg.htm)
Now it looks more realistic, the hope is increasing.
I will show you the result after painting....so long, Thomas
In my setup, the cupholder measures 150 x 150 mm.
Andreas
That´s exactly one of my problems.
I have a (bad) picture from a B738 and when the measures of cupholder are 150mm x 150mm
the measures from the sidepanel are wrong.
Can you please check measure a and b?
(https://www.cockpitbuilders.com/proxy.php?request=http%3A%2F%2Ffs5.directupload.net%2Fimages%2F151105%2Ftemp%2F3evrzlph.jpg&hash=86604916606d69859c6c34329486693ac327b676) (http://www.directupload.net/file/d/4162/3evrzlph_jpg.htm)
another picture from the PMDG:
(https://www.cockpitbuilders.com/proxy.php?request=http%3A%2F%2Ffs5.directupload.net%2Fimages%2F151105%2Ftemp%2Fucz2vm8t.jpg&hash=125855d56b18d83b1759ba7490732ee375334685) (http://www.directupload.net/file/d/4162/ucz2vm8t_jpg.htm)
Forget the PMDG for measurements!!!
Andreas
Thomas,
the measures for both a and b are 170 mm.
Do you come to Lelystad this weekend for the FSWeekend?
Andreas
Quote from: andthiel on November 05, 2015, 04:09:36 AM
Thomas,
ok, some measures from fagerjord-plans semms different.
170mm x 170mm makes sense and looks good.
my sidewalls must move ~6cm forward. Than, the rear sidewall looks also better.
Thomas,
.....no way this time.
edit: so it will look after modifikation:
(https://www.cockpitbuilders.com/proxy.php?request=http%3A%2F%2Ffs5.directupload.net%2Fimages%2F151105%2Ftemp%2Fqcz2sw5r.jpg&hash=da8358ceaed73306e067154856ea9ae14e25a76f) (http://www.directupload.net/file/d/4162/qcz2sw5r_jpg.htm)
Have somebody the measures from the document-pocket ?
I need it for better positioning the post.
so long, Thomas
