May 22, 2024, 06:58:36 AM
710 Guests, 0 Users
  • Online today: 727
Guests: 710
Total: 710
3 monitors
Started by car727, May 26, 2011, 03:25:00 AM
car727
I have a new computer i5 2500K with a EVGA GTX 460 @WIN video card. The video card suppoorts 3 monitors, which I have up and running. I use FS9 and when I undock and move a diplay in windows mode, as soon as I go to full screen the undocked dispays move back to the main screen, or one of the other screens. Thanks for any help.
saabpilot
You cannot use "full screen mode" with 3 displays attached.
Bjorn
Fly Safe - Low and slow
wledzian
Not true... you can use full-screen with multiple monitors - with a catch.
The sim will maximize to whichever display (note: I didn't say 'screen') the FS window is on.  All the windows, undocked and otherwise, will relocate to that display.  They can be moved to other displays, but the positions won't be remembered.
I believe the NVidia cards have display configuration modes which allow you to treat multiple monitors as a single logical display - to have your main FS window automatically maximize to more than a single monitor, you must have them configured in this mode.
edward57
I have 2  separate 3 screen simulators using 2 different sets of hardware and maybe can shed some light on this..
The flightsim one uses ATI 5870 card, and 1 card supports FSX in widescreen (5760X1280) called eyeinfinity.
all the monitors can be different brands/model/sizes/resolution, but it will set the resolution to be the equivelent of the smallest monitor.
eg. if the LHS screen is 1024X768, then all the 3 screens will be 1024X768 regardless of what they are.. so final res will be 3072x768.
The racing sim uses Nvidia cards..
You need 2 graphics cards (configured in SLI) 200 series and up, and generally speaking all the monitors have to be the same brand /model /resolution.
Currently there is no support from either ATI or NVIDIA to support 2 monitors in widescreen - minimum is 3
ATI's new range of cards now support 6 screens (2 rows of 3)
One thing though, If you do not have a physical cockpit (like me!).. ATI only supports Virtual Cockpit on widescreen, you end up with a BIG BLACK SQUARE where the 2D cockpit should be if you try and use it, and the continuous PC busy mouse symbol.. (documented failure)..
Never tried FSX on the Nvidia system to see if it is the same
Building the 737 cockpit around my 3screen sim is my next journey!..  why I signed up to this forum this morning!..
Let the fun begin!
bussgarfield
I have 3 monitors for outside visuals and at present a fourth for the PDF and MDF screens in my MIP. I am running FSX on Vista and have 2 Nvidia GT 9800 video cards (I have a 3rd card but that is not working). Each card has 2 sockets for 2 monitors. I have set up multiple display through the Nvidia software.
I start FSX (on the centre monitor) and load my plane and flight plan and click 'fly now'. When the plane is loaded, the centre screen shows the cockpit and the other 3 screens are black. I right click anywhere on the centre screen to get a menu option, click on hide tool bar and the tool bar appears at the top.
Go into View/Newview/cockpit/virtual cockpit and drag that new window to the right screen and do the same for the left screen. I then click on View/Newview/instruments/PDF (and then MDF) and drag those new views to the screen in the MIP.
It is then just a case of resizing and zooming to get the views you require.
After shut down, the next time I load a plane, it automatically goes into multiple display mode with the black screens but I still have to reload the individual windows from the View on the tool bar.
I have FsXPand but I need a more powerful computer for FsClient to get the MIP screens the way I want them so I am at present stuck with just the windows instrument views.
I hope that has been explained ok. It works fine for me.
Gary Buss
car727
Thanks for all the quick help. I fly using FS9, and only in the 2D mode. In the past with two monitors I would go to windows mode, undock and move what I wanted, and when I went back to full screen everything stayed put. Now with the new computer and video card undocked dispays move when I go to full screen. In addition when I fly my Dreamfleet 727, In windows mode when I select a display to move nothing shows up.
How about doing all the screen placements, load an aircraft and place it at an airport, then save that flight, and then check the default flight box and now ok (save).
When you open FS9/FSX back up later on the next time you fly, you load that previous saved flight and the window placements should be where you left them. Then just change the airplane, airport, weather & etc to what you want it to be (if different) and save it (if needed). These saves are known as name.FLT (name being whatever you name it).
In other words, you will be effectively doing what the guys with three projector screens are doing to keep their windows in the same places (because three projector setups use 4 flight simulator windows). Yes, you are not using projectors, but the screen positioning fixations are the same...
BSD
