May 22, 2024, 04:46:49 AM
727 Guests, 0 Users
  • Online today: 726
Guests: 727
Total: 727
1" Boeing Gauges
Started by iwik, June 29, 2016, 12:17:46 PM
Can anyone who has these gauges tell if it is easy to change the
scale. I am in need of a 1" gauge for my Cessna project. This being
a dc operated one makes the job easy. I have a real gauge from
a Cessna but to fit a drive motor is quite messy.
Hi Les,
Not that difficult at all, once it is out of the case, you can just stick something over the original back plate.
I will pop one open tonight and send you a couple of photots
Im assuming this will be for the suction gauge?
Thanks Mick,
Some pics would be great. Yes i have to get two, one for suction and
the other for fuel pressure. Are all the 1'' gauges of the same construction?.
Hi Les,
Here are a couple of pics from the inside of the 1" gauge.
http://imgur.com/a/pC9m0
As you can see it would be quite simple to apply another scale to it, and this is lit form above, bit behind , so no dramas with backlighting.
The only thing you may need to consider is that there are positive end stops at each end of the scale, so you wont be able to simulate the way the Cessna suction gauge drops off to the bottom of the gauge after the engine shuts down.
If you need any specific shots, just let me know.
Mick
Thanks Mick,
Much appreciated, i am not a perfectionist so it does not have to
work 100%. Will see what i can do when it arrives.
On another point, have you ever tried to convert a dual needle
gauge like Cessna use for their MP/Fuel Flow one. This had small
bellows for each gauge and you you know they are highly geared
as they move so little to drive the gauge. Trying to work out what
to use to drive this gearing or what else as the space is limited.
Hi Les,
No problem mate,  I have converted both dual needle and bellows driven instruments.
Bellows are virtually impossible to drive accurately in a sim environment, so driving via servos & gearing is the easiest option.
Dual needles aren't too difficult to do either as long as the gauge has room inside it to work with.
As mine were Boeing gauges, i had to make everything fit inside the original casing because they slide into the panel from the front
Have a look here to see some info on how I did both types:
https://www.facebook.com/Micks737/posts/728598037249532   Bellows
https://www.facebook.com/Micks737/posts/787008744741794   Dual Needle
Thanks Mick,
Yes i came to the conclusion that gears and a servo is the way to
go. Though in my case space is really limited. But you have given me something to think about.
Mick.
How have you mounted this gauge. I see it has threaded portion and
suspect there was some sort of ring that screwed on. Any tips would be appreciated. Thanks
Hi Les
There is no threaded section, the outer bezel has grooves cut into it that provide grip when pulling the gauge out of the panel.
You need a clamp like this :
http://www.avionicsmounts.com/MS28042.php#round1
Nick at AHPS usually has these second hand
Thanks Mick,
Ah i see, looks like a clamp from a chassis mounting electrolytic
cap should do the trick. I thought it might have been like the Cessna
ones which had two threaded rings to mount.
Hi Guys,  this looks like it would do the trick...
http://www.justradios.com/clamps.html
Just $3.49 for a 2" and $1.99 for a 1"
Joe
