May 22, 2024, 08:48:56 AM
717 Guests, 0 Users
  • Online today: 728
Guests: 717
Total: 717
Instructor Station - Luis Gordo
ISLOGO
What is Instructor Station ?
In flight simulation, an Instructor Operator Station (IOS) is designed to assist the instructor in controlling the simulation training environment and monitoring all aspects of pilot/crew performance in the simulator. The instructor can control, via this software, all functions such as aircraft position and systems, meteorological, environmental, and situational parameters.
The Instructor Station is meant to assist Aviation Professionals, Flight Simulation Enthusiasts and Home Cockpit Builders using Microsoft® Flight Simulator (FS) 2004™, FSX™ and ESP™, Lockheed Martin Prepar3D® and X-Plane®.
The Instructor Station allows setting the aircraft on an approach to a runway of choice under any weather conditions, start-up and shutdown network computers (fully customizable), program or set aircraft system failures at any moment, calculate the amount of fuel required for a flight and load it to the aircraft, record flight performance (approaches, manoeuvres, landings, take-offs, etc.) and plot it graphically, and many other things!
Compatible with all types of aircraft! It is also a great tool for anybody who wants to control the flight simulator externally.
Many features are also available for Project Magenta users (pmSystems, Glass Cockpit, CDU/MCDU, MCP/FCU), AST & FMGS JeeHell users.
Developed by a pilot, engineer & flight simulation enthusiast.
TRY THE DEMO AND ORDER YOUR LICENSE TODAY !!
Luis Gordo Instructor Station 3.01 Compatibility with XPlane 10.30
Started by rehickok, October 15, 2014, 04:12:53 AM
rehickok
I am trying to use Gordo Instructor Station 3.01 with XPlane 10.3.  I run Xplane and Instructor Station on the same PC.  Interested in the General System and Panel Failures with General Avaition Aircraft like the C172 etc.. There is nothing that describes each failure and what to expect, or which ones are simulated and which ones are not. The only failure that seems to work is engine failure.  Has anyone had success using IS with XPlane?
luisgordo
Hit there,
Sorry for the delayed response.
You are right in that the iStation manual does not currently describe each and every offset for all the failures presented in the software.  Most of the ones you describe are purely what FSX offers as standard possibilities, so your best bet would be to look for failure offsets in the FSUIPC offsets manual.  From there, rate of success depends on whether the functionality (i.e. specific failure) is implemented in XPlane or not.  Also, the related offset needs to be included in XPUIPC.
As you can see, there is no short answer... will try to get more specific info onto the manual for this section onto the next release.
Luis Gordo
Instructor Station
www.iStationGordo.com
Flight Data Recorder Mobile
http://www.istationgordo.com/instructorstation/fdr
