X-PLANE (Laminar Research) => X-PLANE - General Discussion => Topic started by: RayS on February 11, 2016, 11:50:38 AM
I installed the Teensy x64 PLugin (Windows Version) for X-Plane yesterday.
While it does work, it also crashes X-Plane on exit. The Teensy at this point doesn't do much other than blink the on-board LED based on the Transponder 'Ident' light dataref.
When I remove the plugin, all is well. I also removed ALL my other plugins... same problem.
Has anyone else experienced this or found a way to fix it?
I don't run Beta updates in X-Plane, only public releases.
Ray,
I wish I had some good news but I don't Never have had any issues on my win7 machine with the Teensy plugin. You might try searching this thread,
http://forums.x-plane.org/index.php?showtopic=55952 (http://forums.x-plane.org/index.php?showtopic=55952)
