May 12, 2024, 04:19:10 PM
507 Guests, 0 Users
  • Online today: 570
Guests: 507
Total: 507
Teensy LC Fuel Panel A (top)
Started by kurt-olsson, July 23, 2019, 12:48:35 PM
Code for Fuel Panel.
With good datarefs, the code looks clean. I like this...
const int PIN_KORRY_LIGHT_PUSH_TO_TEST = 9;
const int PIN_KORRY_LIGHT_PUSH_TO_TEST_2 = 4;
const int PIN_KORRY_LIGHT_LEFT_FILTER_BYPASS = 20;
const int PIN_KORRY_LIGHT_RIGHT_FILTER_BYPASS = 16;
const int PIN_KORRY_LIGHT_VALVE_OPEN = 17;
const int PIN_KORRY_LIGHT_LEFT_FUEL_VALVE_CLOSED = 10;
const int PIN_KORRY_LIGHT_RIGHT_FUEL_VALVE_CLOSED = 3;
const int PIN_SWITCH_CROSS_FEED = 13;
FlightSimFloat xPlane_cross_feed_pos;
FlightSimFloat xPlane_eng1_valve_closed;
FlightSimFloat xPlane_eng2_valve_closed;
FlightSimFloat xPlane_bypass_filter_1;
FlightSimFloat xPlane_bypass_filter_2;
FlightSimFloat xPlane_crossfeed;
void setup() {
  xPlane_cross_feed_pos = XPlaneRef("laminar/B738/knobs/cross_feed_pos");
  xPlane_eng1_valve_closed = XPlaneRef("laminar/B738/annunciator/eng1_valve_closed");
  xPlane_eng2_valve_closed = XPlaneRef("laminar/B738/annunciator/eng2_valve_closed");
  xPlane_bypass_filter_1 = XPlaneRef("laminar/B738/annunciator/bypass_filter_1");
  xPlane_bypass_filter_2 = XPlaneRef("laminar/B738/annunciator/bypass_filter_2");
  xPlane_crossfeed = XPlaneRef("laminar/B738/annunciator/crossfeed");
   pinMode(PIN_KORRY_LIGHT_LEFT_FILTER_BYPASS,OUTPUT);
   pinMode(PIN_KORRY_LIGHT_RIGHT_FILTER_BYPASS,OUTPUT);
   pinMode(PIN_KORRY_LIGHT_VALVE_OPEN,OUTPUT);
   pinMode(PIN_KORRY_LIGHT_LEFT_FUEL_VALVE_CLOSED,OUTPUT);
   pinMode(PIN_KORRY_LIGHT_PUSH_TO_TEST,OUTPUT);
   pinMode(PIN_KORRY_LIGHT_RIGHT_FUEL_VALVE_CLOSED,OUTPUT);
   pinMode(PIN_KORRY_LIGHT_PUSH_TO_TEST_2,OUTPUT);
   pinMode(PIN_SWITCH_CROSS_FEED, INPUT_PULLUP);
   //Serial.begin(9600); // USB is always 12 Mbit/sec
void loop() {
  FlightSim.update();
  analogWrite(PIN_KORRY_LIGHT_PUSH_TO_TEST,255);
  analogWrite(PIN_KORRY_LIGHT_PUSH_TO_TEST_2,255);
  analogWrite(PIN_KORRY_LIGHT_LEFT_FILTER_BYPASS,mapfloat(xPlane_bypass_filter_1, 0,1,0,255));
  analogWrite(PIN_KORRY_LIGHT_RIGHT_FILTER_BYPASS,mapfloat(xPlane_bypass_filter_2, 0,1,0,255));
  analogWrite(PIN_KORRY_LIGHT_VALVE_OPEN,mapfloat(xPlane_crossfeed, 0,1,0,255));
  analogWrite(PIN_KORRY_LIGHT_LEFT_FUEL_VALVE_CLOSED,mapfloat(xPlane_eng1_valve_closed, 0,1,0,255));
  analogWrite(PIN_KORRY_LIGHT_RIGHT_FUEL_VALVE_CLOSED, mapfloat(xPlane_eng2_valve_closed, 0,1,0,255));
  if (digitalRead(PIN_SWITCH_CROSS_FEED) == LOW && xPlane_cross_feed_pos != 0)
    xPlane_cross_feed_pos = 0;
  if (digitalRead(PIN_SWITCH_CROSS_FEED) == HIGH && xPlane_cross_feed_pos != 1)
    xPlane_cross_feed_pos = 1;
  //put a small delay here otherwise the processing is so fast. Lots of read/write that dont have to be so fast.
  delay(20);
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
2 queries Kurt;
Are you not using the separate ENG and SPAR valve lights for the NG?
Also how are you handling the dim/brt states for valve position disagree ?
Hi Mick.
Unfortunatly i have annolder fuel panel from the classic, so there is only fuel valve closed korrys and no eng/spar annunciators. These are differences from the NG i will ignore in my build for now.
Regarding the logic of dim states i only read from xPlane values of 0.0 - 2.0 (mosty 1.0). So the logic is allready there so i just read it.
Hope i understood your last question and anssered it. :)
